Question about Sharp Office Equipment & Supplies
My Sharp fax machine model UX-355LR is saying "LINE ERROR" every time I try to transmit, after getting the fax tone and pressing Start. Then it prints a report with a note: COM.E-7. It has worked perfectly up to now, and nothing has changed.
    Genius:
  • 3,422 Answers
Unplug the fax machine from the power outlet and allow it to reset for 30min. Then plug it back in to the power outlet. If this does not solve the problem, thencheck if the phone line between the fax machine and the wall is 'OK'.
Let me know the result
Posted on Oct 01, 2008
    Master:
  • 479 Answers
Some time of error on the machine u r getting.unplug the device and then replug for reset do it
  • tech gurus Oct 01, 2008
    the easiest way to clear it is to unplug the fax machine from the power outlet and let it stand for at least a minute. Then plug it back in to the power outlet. If this does not clear the problem, use a regular phone to check if the phone line between the fax machine and the wall is 'OK'.
    if you are handy with a screwdriver, here is an almost certain fix:
    Making sure the unit is unplugged, remove the bottom metal plate. A grounding wire is attached underneath so be sure to remove that as well. Set plate aside. You will see several circuit boards. Locate the one that has the small, round, silver battery on it. Next pull off all the connecting cables. Don't worry about which goes where as they only fit the way they came out. Carefully remove the board from the unit. It is held in place by plastic clips that you can gently pry back. Taking a small screwdriver, carefully lift the battery up a bit. It is soldered in place so be careful not to break it off. Next you need to short the battery momentarily. Do this by placing the screwdriver across the two metal tabs that are soldered to the battery. If your screwdriver is too small, use a bent paper clip to short the terminals. Put everything back together. Load film and paper before plugging it back in. When you plug it in it should come back on showing the date. The memory module sometimes refuses to reset after an error and the battery backup keeps this memory. Often the start/stop reset function will not reset so you need to short out the battery momentarily to clear the memory. Hope this helps.
My Sharp UX-A255 won't let me fax anything. It starts up and then comes up with the message Line error or paper jam. There is nothing jammed.
Is it receiving faxes? Make sure you have the line in the right place in the back of the machine (line) and that you get dial tone (hit the monitor button if it has one). Try calling it on your cell to see if it picks up. You may have a poor phone line conditon, and you could try to slow the modem speed down or check the ECM (Error Correction Mode) if so. If it's a jamming problem, try to run a copy and see if it feeds ok. If not try cleaning the feed/pick up rollers with mild soap and water. Reseat the paper and try it again.
Oct 27, 2009 | Sharp UX A255 Plain Paper Thermal transfer...
Phone
WHat model is the fax machine? Also check to make sure that the phone line and the fax line are not 2 different phone jacks. Also if the phoneline and fax line are on the same jack, make sure to program the fax number into the fax machine. Also, double check if the fax machine has an in and out phone jack that it is in the in jack.
Feb 21, 2008 | Sharp UX 355L Plain Paper Thermal transfer...
Sharp UX-105 Fax
We assume you have loaded the thermal paper into the machine and hooked it7108C8H up to your phone line; then, for a free manual go to: http://www.gmfok.com/manuals/faxes/sharp/_ux-105.html
Sep 20, 2017 | Sharp UX B700 Plain Paper Inkjet Fax
Fax problem
Hi Fatimo25,
The screen on your fax machine displays how the machine is set to receive calls. TEL MODE means the machine will not auto-answer incomming calls and will operate as a normal telephone device, it will still however be able to send a fax in this setting.
Place your message on the original tray and pick up the handset, dial the number and when the distant machine answers press the start key or ask for their fax machine and when you hear the high pitched fax tone press start.
There is a button on the panel that will allow you to change the reception mode of your machine to the other settings.
Your machine is of a model that doesn't come into this country so I have no manuals to forward you. You can try however to access the SHARP web site www.sharp.ae
Hope this helps you
regards
Gavin
Oct 08, 2008 | Sharp UX CC500 Plain Paper Thermal...
Sharp UX- B700 getting a Line Error message
Verify that you have a dial-tone by plugging a regular phone into the wall jack
Make sure the phone cord is plugged into the LINE jack..
Dial the number from a regular phone and listen for fax tones.
Sep 04, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Can not fax any document
when machine clear this problem may be solved, First you make setting as i said to machine. Press buttons respectively as i written function 9 * 8 # 7 then start button , it gives DIAG MODE then press satrt, With the help of star button go to memory clear and press start key. machine cleared memory, gives printing of MEMORY CLEARED. this setting will solved your problem.
May 07, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Sharp Fax machine - UX-B700
Try this:
Set the fax machine to AUTO reception. Next, you would want to set the proper settings in your Option Set List. To print a list press the FUNCTION key, the number 2 key, then press the # key until it reads OPTION SET LIST in the LCD screen and press the START key. This will print your list. The following settings should be seen: Number of Rings 1 to 4 rings (setting #2) Dial Mode- TONE (setting #8) TAD Connected- OFF (setting #9) * Quiet Detect Time- 04 seconds (setting #10) * Distinctive Ringing- OFF (setting #12) **
Let us know if this doesn''t fix it... we can go from there!
Maggie B
Feb 24, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Line error when trying to send a document
Check the line for a dial tone on the machine. Either the handset, onhook or speaker phone button. This will test if any comunictions boards have failed in the machine. If you have a dial tone the fax is ok
Next try a manual transmission. Basically make a normal phone call with for example using the handset but have your original in the fax ready to go, ring the fax number when you hear the other fax pick up you press the start button.
Don't forget the other fax may have a problem.
Jan 31, 2008 | Sharp UX-B20 Plain Paper Inkjet Fax
213 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
