Question about Kenmore 62972 Electric Dryer
Dryer will heat sometimes; sometimes it will not.
I have a Kenmore Elite 62972 dryer, purchased 07/01/02, which will heat sometimes, but sometimes it will not. This happens in all settings. Can you help?
  • 734 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
How do I fix a Kenmore 62972 that does not heat up?
First thing I would look at is where the switches are connected back of the control panel. Take the back off the control panel and look for burn marks. A poor connection will heat up and burn the fiber leaving the contact loose.
May 30, 2014 | Kenmore 62972 Electric Dryer
Hi my Kenmore Elite Electric will not heat up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 21, 2010 | Kenmore Elite HE4 Electric Dryer
Hello, our Kenmore Elite Dryer panel isn't working . I'ts getting power but the panel is not responding.
heatman101
I have a kenmore elite he4 dryer and it is running but isnt getting hot. Need to know where the fuses are located to check them
heatman101
Sep 04, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite dryer is not generating heat to dry clothes. The machine is less than 4 years old
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 01, 2010 | Kenmore Elite HE4 Electric Dryer
My kenmore elite he3 dryer has quit heating could it be the heating element and if so where can i find it on the dryer? The model # is 110.82822103 and the serial# is MR1751757
heatman101
Jun 05, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite , no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 27, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore 62972 ele dryer
THERE IS A SMALL RELAY THAT THAT BUTTON ACTIVATES ... THE RELAY SOUNDS LIKE IT IS BAD. BEFORE REPAIRING I WOULD HAVE A "FIXED-FEE" DIAGNOSTIC TEST DONE. USUALLY 30-50 DOLLARS. THEN THERE IS THE REPAIR COST. IS IT WORTH IT?
Apr 28, 2007 | Kenmore 62972 Electric Dryer
Kenmore 62972 Electric Dryer Logo
1,209 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
