Question about Polaroid FLM-323B Television
Remote sensor location on tv
Where is the remote sensot on the tv
Can I change the channel of my tv using remote control within 20meters away from tv?
Posted on Nov 03, 2008
Remote IR board
This board can be located at the front panel of the TV. You have to open the TV, to take it out. The infrared sensor can be located just behind the infrared window, whci can be located at the front panel of the TV. The sensor will look somewhat like this. e23a7382-203e-4e46-a063-a2a3486f559a.jpg
If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 29, 2014 | Samsung HL-T5076S 50 in. TV
Sensot does not work on outside temperature
You need to pull the batteries out on the sensor, reset the main unit and then have it check for sensors again. If it does not find any, replace the sensor.
Aug 17, 2013 | Oregon Scientific BAR208S - Silver...
LG 32LD320-ZA remote sensor
Replace the remote sensor. this component can be located just behind the infrared window at the front panel.
Jun 13, 2012 | LG 32LD320 32 HDTVReady LCD TV
If the remote sensor inside the tv stops working...is there something i can get....a box or something to change channels with another device..some tv cable can go thru before to tv so if tv is on a certain...
Check your remote control for its proper working first. Then think of the remote sensor inside your TV. To get more details about how to check remote control, click this link.
If remote control is Ok, replace the infrared sensor, which can be located just behind the infrared sensor window of your Tv. You have to open your TV, and desolder it out and solder a new one in position. The infrared sensor will look like these. There are sevieral types, and just confirm which type is used in your TV. Picures of some types are attached.
6_14_2012_6_34_32_am.jpg6_14_2012_6_35_11_am.jpg6_14_2012_6_35_33_am.jpg6_14_2012_6_35_53_am.jpg6_14_2012_6_36_17_am.jpg
Jun 13, 2012 | Samsung TV Set Top Box Remote Control
What are the following Code definitions on a 1996 Ford Contour: 157, 158, 159, 181, 327, 332
157= 02 sensor ckt low volts 2/ 2 158=o2 sensot ckt high volts 2/ 2 159= o2s ckt slow response 2/2 181= fuel temp sensor a ckt rng/perform 327= knock sensor 1 ckt low imput bank 1 or single sensor 332= knock sensor 2 ckt low input bank 2
Jul 19, 2011 | 1996 Ford Contour
My television no longer accepts commands from the remote control. I have verified that the remote control works properly. Please advise.
Since remote control is verified so next thing involved in remote operation is remote sensor located on front of tv that receives remote signals.
Remote sensor seems defective in your tv and need to be replaced to solve remote issue.
Call local tv repairman if you have no experience of soldering parts in circuit board.
Thanks.
Oct 22, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Where is oxygen sensor located?
LOOK ON THE EXHAUST MANIFOLD CROSS OVER PIPE.
Jul 05, 2010 | 1987 Oldsmobile Cutlass Supreme
My tv won't turn on with the remote. The remote works fine
You can try www.encompassparts.com The remote sensor is located on the main board up close to the buttons. It is a 3 legged part that is exposed to a small window in the front cabinet. Thanks for using fixya.
Feb 23, 2010 | Panasonic Televison & Video
Remote sensor in the TV
Remote sensor is locketed on pcb it an be replaced
May 11, 2009 | Televison & Video
First Inspect the remote batteries. also make sure TV is not on a LOCK ON option... now, the sensor is a small smoothly part near the TV front buttons, you can clean it carefully FYI, exposing unit remote sensor to direct fluorescent or outdoor light may cause signal interference.
Nov 14, 2005 | RCA P46924 46" Rear Projection Television
Polaroid FLM-323B Television Logo
88 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
