Need to know where the additional memory slot is on my laptop
I have a Toshiba Equium M70 337 laptop. I want to install some additional RAM, and know it has an additional memory card slot, but am not sure where it is located.
Are you able to help ?
    Scholar:
  • 69 Answers
Its at the base of the laptop under a screw, generally in the very center. You may find the Hard Drive or CPU but the RAM looks like a small chip plugged in sideway. Try not to touch any of the components before you are sure you don't have any static on you. it could destroy the device.
You have to make sure you get the same RAM as the one currently in there. for example PC6400, you must get another PC6400. Try and get ram the same brand and chip. It will still work if its different but not as good.
By default your Laptop has only 40GB, you should upgrade that too if you want to. If you do, you will need to reinstall Windows.
Posted on Oct 10, 2008
Is there a way the memory in a toshiba satellite 1005-s157 be increased to more than 512MB?
Yes you can, at least to 1 Gb maybe possibly to 2 Gb.
There will be two memory slots in your laptop. To increase the RAM to 1 Gb install another 512 Mb RAM module in the empty 2nd memory slot. Make sure you use the same make and speed RAM as the one that is installed.
If you have two 256 Mb RAM modules installed in your laptop then you need to replace the two 256 Mb RAM modules with two 512 Mb RAM modules to get a total of 1 Gb RAM.
Aug 04, 2012 | Toshiba Computers & Internet
HOW MUCH DDR2 MEMORY FOR LAPTOP
Referring to a Toshiba Satellite Pro L300 series of Notebook PC:
According to the Service Manual;
1) The Maximum Total Amount of Ram Memory depends on the Northbridge chipset used.
(System Controller. Intel)
If it is an Intel GM965 chipset, the maximum total amount is 4GigaByte. (4GB)
If it is an Intel GL960 chipset, the maximum total amount is 2GB.
Northbridge chipset (Or System Controller)
The Northbridge chipset was aptly named so, because of the general location of the chipset on the motherboard.
It is generally located under the Processor.
(The Southbridge chipset is located further 'South' on the motherboard)
The Northbridge chipset handles the faster capabilities of the computer.
It handles the Processor, Ram Memory, and High-Speed graphics.
High-speed graphics being AGP or PCI-Express.
Integrated Graphics, or a graphics card installed into a PCI slot is NOT high-speed graphics.
This is handled by the Southbridge chipset.
The Southbridge chipset handles the slower capabilities of the computer.
Motherboard diagram;
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
Information on the Northbridge (computing),
http://en.wikipedia.org/wiki/Northbridge_%28computing%29
Information on the Intel GM965, and GL960 chipset,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_Mobile_chipsets
Look under the heading Chipset at GL960.
Looking across you can see that the chipset supports;
1) DDR2 Sdram that is either 533MegaHertz, or 677MHz. (SO-DIMM ram memory for laptops)
2) Supports up to 3GB
[ Your laptop has TWO ram memory slots. The primary, or Main ram memory slot, (Outside edge), and the Optional ram memory slot, (Inside towards the middle)
There are No 1.5GB ram memory modules. ('Stick')
This is why 2GB is the maximum with the Intel GL960 chipset.
Install one 2GB ram memory module in the Main ram memory compartment,
OR,
Install one 1GB ram memory module, in the main ram memory compartment, and one 1GB ram memory module in the Optional ram memory compartment ]
Now look under the Chipset heading at GM965.
1) Supports DDR2 Sdram at either 533MHz, or 677MHz.
2) Supports up to 4GB.
How to know what Northbridge (System Controller) chipset your laptop uses?
Use CPU-Z from CPUID.com
Information on CPU-Z on Wikipedia,
http://en.wikipedia.org/wiki/CPU-Z
CPU-Z,
http://www.cpuid.com/softwares/cpu-z/versions-history.html
If you need guidance in downloading, installing, and using CPU-Z, hit me up in a Comment.
Download page for the free Service Manual, for the Toshiba Satellite Pro L300 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Scroll down with your eyes to the heading - Satellite Pro
Go across, and click on - L300
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on - L300 - it may take up to 30 seconds before you will see the first page come up.
It may also take additional time for the file to fully download.
Have questions I'm right here.
{Now you know Why, How, and Where.
You can tell your friends about your new found knowledge}
Regards,
joecoolvette
Jul 12, 2011 | Toshiba Satellite Pro L300 Notebook
How can I increase memory of toshiba Satellite A105
A RAM expansion slot is located on the bottom of the laptop behind a small panel. Remove the panel to get access to the RAM slot/s. It may have two RAM slots, if it has only one the the 1st RAM slot will most likely be located under the keyboard.
If the laptop has two RAM slots on the bottom of the laptop and the 2nd one is empty then you can add anothe RAM module. Try to get the same make and model as the original to double your RAM..
If both slots are occupied then you need to replace the existing RAM with larger capacity RAM modules.
Sep 02, 2010 | Toshiba Satellite A105 Notebook
Is it easy to install memory on my toshiba satellite pro 4600
Memory Upgrade for Toshiba Satellite Pro 4600 800 Laptop, the Toshiba Satellite Pro 4600 800 Laptop takes the PC100 SDRAM SODIMMs. 256MB module must be 1" in height or less Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Toshiba Satellite Pro 4600 800 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
You can obtain your models service manual with instructions for how to replace and upgrade memory from this link. http://www.givemefile.net/smanuals/notebooks/toshiba/file/31033.html
Hope this helps FixYa! If you find this information helpful, please give us a rating and share your experience in a testimonial!
Thank you for using FixYa.com
May 13, 2010 | Toshiba Satellite Pro 4600 Notebook
Where is the ram?
Removing the keyboard exposes the two memory slots, which are covered by a plastic sheet.
You can download the owners manual here which gives directions to remove and replace your ram. (Starts at page 70) Click here:
http://www.retrevo.com/support/Toshiba-A45-S1202-Laptops-manual/id/614ci359/t/2/
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Feb 02, 2010 | Toshiba Satellite A45-S1202 Notebook
How to install additional toshiba a65 s1762 memory
Yes, you need to flip your laptop over and look for a removable compartment that requires you to unscrew a screw. Once you get the cover removed, you will see slots with either one or two memory modules installed. If one is installed, then you can add the additional memory module in the empty slot. If you have 2 already installed, then you will need to remove one and install your new module, which would only give you a total of 768 megs. Just slip the new memory in and press it down towards the motherboard and start your laptop..
May 16, 2009 | Toshiba Satellite A60 Notebook
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    Hi there, Just wondering if someone can help me. I just received today two 1GB memory modules so I could upgrade my laptop. Only problem is, It states on numerous sites that my laptop has two memory...
    Here is the link for the Toshiba Satellite M105-S1021 manual. It is zipped and you can download it to your machine. It will tell you exactly how much RAM you can hold and where it is located.
    Please don't forget to rate this solution.
    Jan 09, 2009 | Toshiba Satellite M105-S1021 Notebook
    Toshiba m55-s135 memory install
    Not all laptops have spots for two sticks of ram. Double check the specs but the slots should have been in the same spot.
    Jul 30, 2008 | Toshiba Satellite M55-S135 Notebook
    Toshiba M50 additional memory
    hi friend,
    first you have to know it's not the 512 kb it is an 512 MB. If it is the laptop there may be the two slots in the corner of the slot you see the knob press it slidely the knob on the both side after remove as the same process to put new ram on the slot but before that see please check if your computer or the laptop is supports the 2GB ram . you can see the manual of the laptop or search the web or ask the shop where you buy the laptop. these are steps for ram. try it , and if problem comes again ,please inform to fixya.com
    bye.
    Jun 14, 2008 | Toshiba Satellite M45-S265 Notebook
    Computers & Internet Logo
    155 people viewed this question
    David Payne
    David Payne
