Question about Samsung Televison & Video
My DLP television (model 507W) is making a high pitched noise. It sounds like medal on medal. My guess is that it is the fan. You can hear it come up to speed when the TV is turned on and trail off when the TV is turned off.
  • carletom Oct 07, 2008
    There does not seem to be an easy way to access the fan other than taking the whole back of the 507W off. Can I access it by taking the lamp out first?
    Please advise,
    Thanks
  • carletom Nov 02, 2008
    How do you get the fan out?
  • Samsung Master
  • 19,396 Answers
You cannot access the fan without taking the whole back of the TV off and accessing to the internal board, where the fan is located.
However a squealing high pitched noise of this kind it is more likely from the color wheel that is located behind the lamp, rather than the fan.
Inspect the color wheel, if that is the problem replace it.
If there is dust inside hoover it with a small battery powered hoover, a regular hoover can damage the components, breaking their on board contacts.
Be careful while you handle th lamp, that is an expensive replacement.
You can buy parts here:
Appliance parts, electronics parts & more from PartStore
TV Part Appliance Parts & More
Posted on Nov 02, 2008
  • 728 Answers
The easiest way will be to take the whole back off unless you are good with electronics and know how to re-solder the connection to the lamp once you take it out. It will be less work if you just take the back off and check the fan motor. Blow on it to remove any lingering dust and either spray some wd-40 or put some grease in the motor where there are parts that could rub together. Also make sure the fan blade is not rubbing against anything. That could be causing it to make that noise also.
  • Jazz Boyce
    Jazz Boyce Nov 02, 2008
    This should work with stopping the noise.
  • 10,594 Answers
Please check noisy fan at back of TV and remove out then open it and put few drops of machine oil in its bush hole. Noise will stop.
Posted on Oct 01, 2008
    Master:
  • 479 Answers
It could also be the fan motor as something like dust is blocking the motor to run at its normal speed.so check it and get it repaired.
  • tech gurus Oct 01, 2008
    many times cleaning the fan and the motor works but some time you will have to change the motor to make it proper as orignal as it was before.
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
Samsung DLP HLN5065WX/XAA
that's from a thermal switch, to keep the innards cool, post use. Seems to me that you might just check to see that all vents are open and clear of debris, for starters.
May 07, 2008 | Televison & Video
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
Why does it make a buzzing sound
The buzzing sound could be a color wheel (high pitched or fan like) or the lamp and or Ballast.
Try to describe it more and do you hear it with the sound muted or off?
Mar 15, 2012 | Toshiba 62HM95 62" DLP HDTV
My 62 h m 15 dlp toshiba television makes a humming noise . It quiets down after a couple minutes but I'm wondering what it is
These sets used a color wheel and before they fail they will make a fan like or high pitched whine----if the sound is there and you turn the set off you should hear it slow down before stopping.
Most of these the wheel is not sold and is only available with the light engine which is a rather expensive part.
Mar 10, 2012 | Toshiba Televison & Video
I have a Nice Samsung HD wide screen television that started making noise last week and this noise got proggressively louder and louder to the point that we cannot watch it now. It sounds like an internal...
Give me model number (it is on back and also should be on right side of cabinet)
I suspect it is a DLP set with a bad color wheel.
Wheel faces lamps in DLP type sets and bearings in motor fail causing either high pitched whine/fan like sound.
If wheel shatters set will shut down.
There are instructions and videos on You Tube for replacement of the kind of part---do it your self repair.
Look at photo and add comment here with model number.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Aug 21, 2010 | Samsung Televison & Video
My Samsung DLP is making a loud humming noise
Most likely if you are hearing a fan like noise from this DLP it is not the fan.
These sets use a replaceable color wheel that before it fails makes either a high pitched whine or a fan like sound.
Part is usually customer replaceable and there are free written instructions and video instructions on YouTube for most models.
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
When i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Televison & Video Logo
Henry  Thomas
Henry Thomas
