Question about IBM ThinkPad T60 Notebook
My notebook does not turn on
I accidentally spill some liquid on it and I immediately turn it off. However I can't tun it back on - when I press the power button, the light (night light?) on the top of the monitor turns on but nothing happen. I brought the notebook to my campus technical service and they said I should wait until the moisture is completely dried (get the battery and hd out, and fan dried it) otherwise it's locked and won't turn on. Is that true?
    Sergeant:
  • 268 Answers
Yea I would definitely wait for everything to dry out before diagnosing it......sometimes you get lucky and even though components got wet, after they dry the function......I would give it a day or two then try to fire it up again. If you get nothing , start troubleshooting
Posted on Oct 01, 2008
Why did my laptop lose it's operating system after it got wet?
From your description, liquid seeped into internal circuitry. Probably disassembly and addtional drying would have been necessary to remove the liquid completely. Starting the laptop prematurely probably destroyed it..
Jul 01, 2014 | Dell Inspiron 1721 Notebook
Tip
Liquid spills
Todays notebooks & laptops come equipped with spill resistant keyboards. Thats a big help in itself. But some are not . If your notebook has suffered a liquid spill while its on , IMMEDIATELY shut it down. GET AWAY from carpeting or metal furniture or objects: stand on wood or cement floor only. Turn the unit and place on its side to drain it from the liquid (NOT UPSIDE DOWN) and to avoid further damage to mainboard and keyboard. DO NOT TURN IT ON AGAIN  . Remove the battery, hard disk drive, CDROM, memory modules, remove back cover, until exposed to mainboard. Take conventional hair dryer, blow dry using HIGH heat, slowly move over peripherals and mainboard  five inches away with  Extra drying process on keyboard and mainboard. Using a few cotton balls, pat down any excess liquid by absorbing into cotton -- blow dry this area intensley for long time (20-35 minutes, depending on amount of liquid spill). Wait a few days , replace all parts and turn on notebook.
on Jan 21, 2012 | HP Computers & Internet
Keyboard will not work on Toshiba Satellite C655S5056
Nope,not locked.Just damaged keys.The liquid must've leaked into the keys and is either preventing contact or shot the electronics.
May 15, 2014 | Toshiba Satellite C655S5056 Notebook PC
My Acer Aspire 5315-2326 laptop. Apple juice spilled on it I turned it off immediately and wiped it off and of course it won't turn back on. What else could I do? Or is it just gone?
The fact that any liquid spilled on a computer is almost a death sentence; is not always true. In some cases fluids only damage the Key Board. The keyboards are $25 on eBay. Replacement is easy.
Feb 22, 2014 | Computers & Internet
Turns on and off after spill
You should not use laptop at least one week after spill! If someone spill something on laptop, immediately pull out the power cable and battery, and flip the top side down. Then clean it in laptop service and it should be OK, maybe you will have to replace keyboard. If liquid stay inside, it will make short circuit and destroy mainboard, so you should take it to the laptop service for cleaning.
Dec 05, 2011 | HP Pavilion dv9000z Notebook
Hi. I accidentally spilled coffee on my Asus EEE PC 1000H Laptop. Is it true that its keyboard is waterproof? If so/not, what should I do to avoid damaging it permanently? I've been using it for 2 hours...
When this happens, you should fully disassemble the netbook & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no liquid seeped into them. Dry them if needed.
When you are done, re-assemble back the netbook.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
Feb 01, 2011 | ASUS Eee PC 1000HA Notebook
Spilled a little coffee on macbook--not even a 1/ 4 cup, dried off immediately-- on keyboard, then took battery out and back in and two keys not working so took battery out rinsed around those keys very...
After liquid spill the laptop has to be disassemble and the motherboard inspected for liquid damage. In some cases cleaning the motherboard might fix the laptop.
Check out this guide for troubleshooting Mac laptop liquid spills.
Nov 15, 2010 | Apple MacBook Housing, Top Case with...
I have a Lenovo ThinkPad t410s. Wine as accidentally spilled over the keyboard, and now the laptop will not turn on. How can i fix this computer? Is this something I will be able to do on my own? Thanks.
You should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
When you are done, re-assemble back the laptop.
If it still does not work, the motherboard might be damaged & needs to be replaced.
Oct 18, 2010 | Lenovo ThinkPad T410s Laptop Computer...
Spilled coffee on D600 notebook, power supply turns off when plugged in after had the notebook cleaned. is my notebook not fixable?
When the power supply turns off when plugged into the laptop it is indicating that there is a short. Remove your battery and try connecting the power adapter again. If the problem persists your motherboard will most likely need to be replaced.
There are companies out there that will repair motherboards however if the laptop was on when the spill occurred there is little to know chance that the motherboard is repairable.
Mar 16, 2010 | Dell Latitude D600 Notebook
Spilled small amount of liquid on it now it does not work. Looking for possible solution, ie motherboard.
remove the battery open up the notebook then spray rubbing alcohol all over the computer keyboard and, especially where you spilled liquid; really soak it; wait 24 hours for it to dry; and, try to turn it on with the power supply connected
Jun 03, 2009 | Sony VAIO VGN-N250E/W Notebook
IBM ThinkPad T60 Notebook Logo
151 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
