Question about Panasonic Lumix DMC-FZ30 Digital Camera
Lumix DMC FX30 Autofocus wont focus
The Autofocus on my lumix DMC FX30 makes funny noises when you try to use the zoom and wont focus in any of the settings. Nothing happened it, I just turned it on and found it like this. Is it fixable and how much should it cost? Its less than 6 months old, but I bought it in the USA and live in Ireland so I dont think it will be covered by the warrenty.
  • cmra Oct 31, 2008
    I have a similar problem wih this camera. I cannot get it to focus; All my pictures are blurred even though "some" look ok on the screen after been taken. I jhave been told by an expert that the "focus" operation is operational but the quality of the pictures are extremely poor; I have reset the camera to factory settings but this has not helped.
clusterfx
  • 67 Answers
SOURCE: NEED A USER MANUAL FOR PANASONIC LUMIX DMC-FZ5
i'm not sure which one you have so here are both
DMC-FZ5K5.0 MP - 12X ZOOM
http://service.us.panasonic.com/OPERMANPDF/DMCFZ5PP.PDF
DMC-FZ5S5.0 MP - 12X ZOOM
Posted on Feb 24, 2008
  • 11967 Answers
SOURCE: My Lumix DMC-FS5 camera had locked memory card,
Move the slide switch on the side of the card.
Posted on Oct 21, 2009
  • 83 Answers
SOURCE: Use of digital camera Lumix DMC-LS70 as a web cam.
It will not work through USB like a standard webcam. Ls-70 only lets you access camera memory card/onboard memory when connected via USB.
However you could connect the camera video-out socket to a PC with graphics card with video capture function. Some cards with video capture work with skype (check this URL:
http://forum.skype.com/index.php?showtopic=41101 )
There are also various software solutions which can fool your webchat client into thinking that video capture stream is actually an output of a usb webcam. (Try google for "video capture into skype".
At the moment this seems to be the only easy way to use LS-70 as webcam.
Good luck,
Raf
Posted on Nov 05, 2009
  • 247 Answers
SOURCE: I want a manual of panasonic lumix DMC-TZ7 in
This is the ZS3 in North America. Find it from this page http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-ZS3S The manual is at http://service.us.panasonic.com/OPERMANPDF/DMCZS1.PDF
Posted on Dec 13, 2009
  • 11967 Answers
SOURCE: Panasonic Lumix DMC FX 33 wont focus and shows
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 23, 2010
How can I fix the screen on my Lumix DMC-FX30 which does not illuminate?
First, check the display settings.
Next, the camera usually switches back to its default when the shutter release is touched. Check those settings, too.
Aug 20, 2014 | Panasonic Lumix DMC-FX30 Digital Camera
Hi, How can i use my dmc-fx30 as webcam ? Jan The
I know this probably isn't the answer you wanted to see, but here goes.
The Lumix was designed as a camera, storing images (and videos) to a memory card. It was not designed to stream video live to another device. It's a camera, and cannot be used as a webcam.
Jun 11, 2010 | Panasonic Lumix DMC-FX30 Digital Camera
Lumix DMC-FX33. Keep on getting "Please turn camera off and then on again" over and over again. Occasionally I can focus and take a picture and the camera works for a day or two. Then the problem...
I have the same problem. It resulted when we used the camera is windy conditions with very fine sand blowing around. Some of those grains are lodged in the automatic lens cover and in the autofocus/zoom mechanism in the lens. I can actually hear the grinding as the camera tries to open.
Now, how do I fix it?
May 06, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Hi, I have a DMC-FX30. When i turn the zoom
mera Digital Camera Hi, I have a DMC-FX30. When i turn the zoom Answer Failed: retry Hi, I have a DMC-FX30. When i turn the zoom swithc it is stiff and goes to full zoom and cannot be... (More) (More) Hi, I have a DMC-FX30. When i turn the zoom swithc it is stiff and goes to full zoom and cannot be stopped - only when i switch the camera off. Can you help?
Feb 11, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
Lumix Panasonic DMC FZ28 18x optical zoom, 27mm wide pix always out of focus... what could be the problem? thanks!
Does it make 2 beeps and have a green spot in the center of viewfinder/lcd? if so it is thinking it is focused, test this to see. If it is 2 beeps but definitely out of focus, it will need to go in for a back-focus alignment. Simple operation for the repair team.
Sep 21, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Problem with my lumix fz10 autofocus. Press the
just make sure you dont have dirt on the lens itself!
or that you have MACRO function set
Aug 17, 2009 | Panasonic Lumix DMC-FZ10 Digital Camera
I have a DMC-FX30. I can't get it to auto focus. It stays blurry. What to do?
I have same camera as you but it is currently set in Japanesse and want it set in English??? can you help????
Apr 03, 2009 | Panasonic Lumix DMC-FX30 Digital Camera
Faulty focus
Have you tried changing the focusing mode to one of the other settings? I usually find central point setting best for zoom. Alternatively, you could try using Macro (the flower) setting - I leave mine on this all the time it's really the best general purpose mode.
Sep 06, 2007 | Panasonic Lumix DMC-LZ5 Digital Camera
Panasonic Lumix DMC-FZ30 Digital Camera Logo
59 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
