Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Kdf 55wf655 whistling noise
There is an annoying whistling like noise that is coming from my t.v. .
you still here it when the volume is turned down so i know its not the speakers.
someone said it might be a fan? not sure?
if it is ...can someone replace this themselves or do you need a repair man?
  • mlslaw Apr 07, 2009
    there is a new noise coming from the back of my 40" sony GV--sounds kind of like a fan might be laboring or dirty-- how can I get to it and clean it--assuming that's the issue
  • Sony Master
  • 5,568 Answers
It could be the fan since many modern fans are speed controlled and fed with chopped voltage with a frequency of a couple of kilohertz which we would interpret as a squeal.
It could also be the impending failure of one of the power circuits which when approaching failure may emit noise in the audible range although they typically operate well above our hearing.
I'm not sure about your set and don't have time to research it right now, but many of the rear projection units have a color wheel that also turns at a high rate and from what I know of them, they are fairly costly to replace.
Those three are possible suspects and of them, only the fan replacement is something the average owner can deal with.
Posted on Oct 01, 2008
Tv come on than go off than come on? KDF-55WF655
Put left foot thru screen. Very important to use left foot and save right stronger foot for wifes rear end next time she insists on Sony
Jan 24, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have no pic sony lcd proj tv model # kdf-55wf655, 57in,
Lamp or ballast bad. If ballast good and lamp bad, will here a mosquito buzz every 15 secs. after turn on.
Apr 20, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV makes a spinning noise coming from the lower right side.
If there is a red light blinking that means that the projection light needs to be replaced.
Jul 26, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Grand wega kdf-55wf655, won't power on and led flashes 3 times
Make sure lamp cover is placed properly and securely after lamp replacement.
3 blinks of LED shows lamp door is still open or not closed properly.
Jul 04, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv picture and sound comes on and off
You probably have a bad lamp sony part number A-1085-447-A XL2200 if your model number is KDF-55WF655. I recommend using original from sony 199.99 retail.
May 23, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv won't turn on red lights blinking
You are hearing the spark gap mounted on the lamp ballast board. If you can hear that sound, that means everything in the lamp driver circuit is working except the lamp!
Get a new lamp.
michtech
Jan 31, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDF-55WF655 Won't Pwr up
There's a fan in the optical block (light engine) You may also have either an intermittent fan or a bad connection from the fan(s)
michtech
Jan 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
89 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
