HP O fficejet J4540 All in one ( cant get scanner to scan )
Help,
I need to scan for my online homework, I cant get the scanner to work everything else is o.k with the print and fax portion of the printer.
I have a CD with the name Software and Documentation CD kit 439956-B26
vp15 / vp17 / vp19 /
w1707 / w1907 / w2007 /
w2408 / fp1707 /wf1907 LCD Monitors
I'm not sure if this CD is for my computer or printer, this is the only one I have
When I select the scan option with the arrow and I then press the green button to start the scan process. A red exclamation sign flashes.
This is my first time trying to use the scanner.
Please Please help , Evelyn 512-365-2300
  • mummadi Feb 02, 2009
    I am trying to scan my documnt, an orange sign is flashing, not sure whether scanning is working with this device or not. Please, help me out.
    Thanks , in advance.
  • nvavcho123 May 14, 2009
    I have the same problem.After installing the j4540 with the software ,everything works except the scanner.One additional problem is I have no place to even click to start scan.I have tried uninstalling and reinstalling three times but their is no sucess,however after the install it promps me to click finished and then it starts installing again but starts counting backwards.Then my computer freezes.What can I do?
Dinoza
  • 112 Answers
SOURCE: HP All-in-one will not scan
I think I have the solution for you (after facing similar problem). Try installing the drivers and then go to my computer right click on the HP and select "Scan using wizard". My HP is able to scan using this method although I still can't scan using the button on the printer so if you don't mind clicking the mouse instead of the printer's button you should be fine. Let me know if it worked. Cheers, D.
Posted on Jul 14, 2007
DJYar
  • 41 Answers
SOURCE: wont' send a fax
In my experience, anything plugged up to a phone line can be some of the most susceptible to electric discharge. Thunderstorms, power surges, brown out, all of these can cripple or kill a fax machine. When I saw this symptom on a fax, 9 times out of 10 it was caused by a power surge of some sort. The line error is most likely the machine's outgoing line has been zapped. The 775 (and it's father, the 770) are some of the most straightforward faxes I have dealt with when it comes to faxing. There is no internal setting that I am aware of that would inhibit the sending of faxes. I would double check the transmission report to make sure that the machine isn't doing something weird like adding extra digits to the numbers you are dialing. It would still be worth your time to try a few things, though. I would plug the fax into another phone jack using a different phone cord if available. Also try using the fax as a telephone, call a number and see if you can connect. If you can, make sure both parties can hear each other clearly. If you can not, the machine will need to be replaced.
Posted on Aug 23, 2007
SOURCE: we buy canon copier ir3035
(This is for your information)First ur problem is not mentioned clearly. You are mentioning network printing is having problem (this is ok) but it is not clear that printing from USB is having problem or not. And you did not mention the type and version of your operating system(OS) and the nature of your network. Installing driver is very crucially depend upon the OS and the type of network that you are having.
Let assume that you are having genuine MS Windows 2003 Server as the backbone of your network and genuine MS Windows XP SP2 as the OS of the client PCs. Some basic knowledge of networking is required to understand and execute the remedy mention below. And you should read completely first before trying out this.
For network printing problem of Canon ir3035, first check the physical network cable(UTP) if it is properly crimped & properly connected, then check the connectivity by pinging the IP of the copier (which is needed to set manually if there is no DHCP server in the network). If the copier is responding properly. Check again by pinging the server from the copier (which you will find under MENU and NETWORK OPTIONS of the copier). If both the way is responding properly uninstall the printer driver totally and restart the system. Re-install the USB driver first and then re-installed the network driver (before re-installing the network driver first check whether it has got the required IP from the DHCP server, if not assigned one according to your network). If there is no error message during the installation of the USB driver(normally USB installation does not show any error), USB printing should be ok. Thus USB case is close.
Then check the network by using the same procedure mention above. If everything is ok, you can carry out the installation process for network driver. This way there should be no network printing problem. If still there is the problem please check that you are not using pirated copy of OS. Network printing for ir3035 is not ok if pirated copy of OS is used. You have to get a genuine copy and will solved the problem A to Z.
Posted on Jul 29, 2008
SOURCE: imagistics 2500 fax stuck in the "printing" mode. Need to reset.
Yes that worked!! I unplugged it, and kept the red stop button push in while plugging back in and it cleared it out! THANK YOU!
Posted on Aug 06, 2008
  • 64 Answers
SOURCE: Check printer ##331 CANON FAXPHONE B95
HI your problem in fixing unit change it and your problem will be solved
Posted on Nov 08, 2008
Cant get my 1610v to scan. Can't find the
turn on/off, unplug, wait a minute, plug back in, should reset.
go to application folder for your computer, dbl click icon for make of printer, for settings, check to ensure everything is order. go to the scanner settings.
lastly, check make of printer trouble shooting web site for more information. hp has an awesome site for trouble shooting
hope this helps, good luck.
Apr 29, 2010 | HP PSC 1610v All-in-One Printer
My scanner keeps saying no scan options no computer connection but it will print. it is a hp officejet j4540 all-in-one
You must install scanner driver and management software to enable scan Choose you operating system and get ALL the software and install as Administrator as well. Also using same link, get the manual for it as well, that will show you what to do and how to do it.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3645094&
Mar 25, 2010 | Office Equipment & Supplies
I can't seem to scan from my officejet j4540 it states no scan option refer to documentation to troubleshoot. I don't have my manual.
The scan options are in your computer, you need to have HP scan software running before it will scan This tells the scanner how to scan, what it's scanning, and where to send the image and how to save it.
Jan 08, 2010 | HP OfficeJet J4580 All-In-One Laser...
Try to copy and get scanner failure motice
scanner failure is a hardawre problem. try to copy again and check if the scanner light is on. once the scanner light is not working then try to return your printer in the store that you have purchased it.
Oct 20, 2009 | HP Officejet 5610 All-In-One InkJet...
HP c6180 scanner problems jun 2009
well go to c:\program files\hp\bin\hpqscnvw.exe
the scanning should be ready to go.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Jun 17, 2009 | HP Photosmart C6180 All-In-One InkJet...
My hp office jet j4540, cannot get it to scan document
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9o8
Jun 07, 2009 | HP Officejet 5610 All-In-One InkJet...
Our scanner wont work the printer and copier work fine
You should be able to find a white sticker on the bottom of the printer. The serial number will be there as well. If you have the PCS 1610 than follow the uninstall instructions given by Hp at this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265838&cc=us&lc=en&dlc=en&product=390315&dlc=en&lang=en
Than go to the link below and download & install the 1610 software: HP Full Feature software/driver: No Network Support &
HP Image Zone/Photo and Imaging Unexpected Internal Error and Communications Failure Patch
That should fix your troubles. Look at the fixes while at Hp and if you feel you need other upgrades now would be a good time to download.
Dec 29, 2007 | HP PSC 1610 All-In-One InkJet Printer
Cant scan from hp 3110 photosmart printer
You are having hardware communication problems caused, very likely, by driver installation troubles. Go into CONTROL PANEL and then SYSTEM and then DEVICES and look for the scanner there under IMAGING DEVICES and check to see if it has an exclamation mark next to it, or if any other device has this mark, meaning that drivers are not installed for it. If there is no scanner but you have a warning icon labeled UNKNOWN DEVICE, this is the problem. If you find any non-functioning hardware devices, this is probably it.
Try this as a fix. Unplug the cable to the printer/scanner.
Go online to HP and download the latest drivers and utilities for the scanner/printer and save them to your desktop.
In CONTROL PANEL, open ADD REMOVE PROGRAMS. Scan down and remove (uninstall) anything related to the HP printer or scanner, everything. Then reboot. Then install the drivers and utilities on your desktop you saved previously, plugging in the unit when prompted to do so. If you are never prompted, plug it in at the very end when everything is installed. If this routine fails, try rebooting the system without the HP scanner plugged in, wait for a complete start-up, and then plug the scanner into a different USB port and follow the directions on screen taking note of any failure messages. PS: the scanner/printer needs to be powered on through all of this, of course. :>)
Good luck
Nov 16, 2007 | HP Pavilion dv4000 Notebook
666 people viewed this question
k24674
jasbo
jasbo
