Question about GE Dryers
Where buy light bulb (120V, 10W) for GE dryer Model DPSR10EG5WT ? Bulb burned out after 30 days of dryer use.
    Genius:
  • 1,122 Answers
Go to sears .com click on parts, put your model number in and all the parts for your dryer will come up,let me know how you do-mike
Posted on Oct 01, 2008
Whirlpool gas oven light bulb lasted 5 years but now keeps burning out?
all appliance bulbs are not created equal it needs to be specifically an oven bulb to take the heat .
Feb 14, 2016 | Whirlpool Accubake 30" Self-cleaning...
Tip
Why Light Bulbs Burn Out So Quickly
The bulb package should have an average life expectancy printed on it. The typical light bulb is good for roughly 900 hours. At 10 hours a day that's three months. At 24 hours a day it's a little more than a month. If you have 25 bulbs in your house burning an average of three hours each day, a bulb will burn out every twelve days, on average. If you compute the average life of your bulbs and discover it's clearly less than the manufacturer's rated life, then you may have: 1-You may have over-voltage in your house. Occasionally this causes more serious problems. You can get a cheap multimeter at Radio Shack. If the voltage is 125V or higher, talk to the power company about it. 7 or 8 extra volts on a 120V line will cut the bulb life expectancy in half. If it's a slight over-voltage, you can buy special 125V or 130V bulbs, though sometimes they're hard to find.
2-Too high a wattage bulb in too small an enclosed fixture (such as a globe), the heat can't get out--the bulb burns too hot, leading to short bulb life.
3-Recessed lighting fixtures often get covered by attic insulation. This blocks the intended ventilation method--heat can build up around the bulb, causing short bulb life.
4-A vibration problem. Such as, bulbs under a heavily used stairway, on or near an out of balance bathroom or ceiling fan, or near a door that gets slammed, or kids upstairs jumping, etc. You can buy special shock resistant, also called "rough service" bulbs, for this situation, or try one of the new compact screw-in fluorescent bulbs.
Flickering. Intermittent electrical contact can cause flickering. It's like turning the light on-and-off constantly, and will reduce bulb life. It can be caused by a bad light socket, or a poor electrical connection somewhere in the wires leading to the light (most likely right at the fixture). Flickering can cause the bad connection to get hot and possibly start a fire. If you don't locate the cause of the flickering and it affects all or many lights, you could have a bad neutral connection -- a dangerous situation. Another indication of a neutral problem; as larger appliances (washing machines/dish washers) cycle, lights will get quite noticeably brighter or dimmer (minor changes in intensity are normal). If you suspect this problem have either the electric company or an electrician check it out.
on Dec 18, 2009 | Kitchen Appliances - Others
What size bulb do i need for Mr.Christmas Holiday lighthouse?
I can not say for sure but normally these types of houses take the same bulb you would use in a night light. like a GE 120V 4W
Nov 25, 2013 | Gemmy Mr. Christmas Light Show and Sounds...
I replace the light bulb but it does not work although the dryer works fine. Is there a special bulb?
with the power unplugged, check the tab inside the bulb socket to be sure its not burned or damaged, also,, at times a new bulb is no good, If you have a multimeter,, put the selector to continuity ,, and place the black lead to the bulb base, and the red lead to the center point at the bottom of the bulb, if you get no reading, the bulb is no good, ( if you don't have a meter, screw it into another lamp, as long as your sure the dryer light socket is a 120v not a 220 volt
Jul 12, 2011 | Whirlpool GEW9250 Electric Dryer
Ge jvm1790wk convection/microwave oven exterior light bulb burned out...I can't read volts and watts on the original bulb and don't find the information in the manual, what do I buy to replace it?
The cooktop light is 120V, 40W max., part number WB08X10051.
That's all covered on page 27 of your owner's manual here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven or part numbers here.
To replace the inside light, you'd need to remove the oven from the wall, and take off the outer cover.
Jul 08, 2011 | GE JVM1790 Convection / Microwave Oven
What bulb is required for Lemair Rd-320ff fridge. Know its a 10watt but need type?
  • Lemair is made by G.E. So even though any 10 watt appliance bulb would work for your refrigerator I found one from G.E. for their refrigerators http://www.galesburgelectric.com/GE-10S11NF-120V-10W-Incandescent-Appliance-Bulb.html
  • You can order that one or pick any 10 watt appliance bulb from your local hardware store. They should just be frosted for added life and durance in the cold elements inside your refrigerator.
  • Thanks for using FixYa
Regards, Tony
Jun 22, 2011 | Refrigerators
GE GTS20ICNCC Refrigerator light bulb burns out quickly
Use the correct wattage bulbs. If they fail often then you may need to get it checked by an electrician.
Filament bulbs easily burn out. What you can do is to buy cheap bulbs and replace as soon as they burn. This is the problem which is why tube lights and LEDs were invented!
Sep 07, 2009 | GE Refrigerators
Interior Light GE Advantium replacement
Yes, that's right. Very common, standard 10W halogen available about anywhere. GE's # is WB36X10163 or WB36X10177.
Jul 18, 2008 | GE Advantium 120 Convection/Microwave Oven
Interior Light
The interior oven light can be accessed in the following way:
1.Open door and remove the top grill via the 2 screws along the top edge.
2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
Jan 01, 2008 | GE JVM1790 1000 Watts Convection /...
Dryers Logo
272 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
