Question about D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge
Router not allowing connection to sites
When I installed my router and tried updating my anti virus program and windows update I had no connection. The only thing that worked is mozilla! Any advise on how to fix these problems ...I'm assuming I will be having problems with other sites?
    Scholar:
  • 87 Answers
Turn off the router's firewall or allow for exceptions. Most downloads and other software than browsing use additional ports that the firewall is not allowing to pass thru.
Posted on Oct 20, 2008
Limited or no connectivity problem.. from phil. here!
If you are receiving this error, you should run the Microsoft patch (KB884020) for it. Follow the instructions below to do this. Alternatively, you can download a zip file with the patch, registry file,.
1) Download the patch from Microsoft's site
2) Run the update to install it
3) Run this short Registry fix to complete the update. Type the following lines in Notepad and save the file as FixReg.reg on your desktop, then double click on it to install into your registry.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\IPSec]
"AssumeUDPEncapsulationContextOnSendRule"=dword:00000002
4) Reboot your computer
If you experience the error message again, reboot your computer first. In most cases this will solve many connectivity issues that are not associated with this SP2 bug.
Sep 14, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
Reset linksys router
General Linksys has a reset button on the back on the unit. Its really small and recessed into the unit. To cause the reset to happen do the following:
1 Get a pen/paperclip something small and pointy and hold down the reset button
2 after 20-30 seconds of holding button down you will notice a change in the lights in the front once you see this unplug the unit and wait 5 seconds.
3 Plug unit back in and you should be good to go
On some units if you enter into a web browser 192.168.1.1 you can enter into the admin controls and do a restore to factory defaults and worse case if you need to you can flash the unit (this will also update the system to its latest firmware)
Dec 30, 2009 | Computers & Internet
LAN to LAN Connection
try to use the the teamvier software and install it at boot server or pc you want to access for the other site, remember you need to intall too at the other site the software and take down the id number and the password
Jul 20, 2009 | Computers & Internet
Internet Connection won't work
if your router have freeware, like for example you type it on IE, http://192.168.1.1 so this mean you are accessing your router, in this method you can see the default connection of your router itself identifying the IP, DNS and gateway address, this time you know what is your exact address going to you PCs...
Jun 18, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Windows messenger doesn't sign in with D-Link 604+ router.
A simple solution would be disabling the firewall on the router and use your windows firewall. Your router might be blocking msn messager. Another solution which is harder under application on a router. Most routers have you can set that program to aloud on the Internet.
Jun 15, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Modem and d link
Hello there,
Your internet connection should be setup properly in order for the router to give connectivity to both your computer.
You must contact your ISP and ask them for the IP's and put it in the router.
Apr 05, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Cannot share connection
The IP address that you have is an automatic IP address the Windows generates. It basically means your computer is not getting an IP address from the router (DHCP). You should try powering everything off. Then, in this order, power on your modem, wait 30 seconds, then, power on your router, wait 30 seconds, then power on your computers...This should fix the problem since one computer is working already.
Mar 22, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
I am trying to connect my D-Link router to my PC. I changed providers from DSL to CAble, and now it doesn't work. When I try to hook up the router to the cable modem, I no longer have internet service....
First, you have to directly attach to the cable modem whichever computer the instal tech used to establish your account. Make sure that connection works. Then re-insert the router and clone the MAC address of the instal computer to the router. Then check your DHCP settings. Make sure it's set to get a new IP from your new provider. You may then have to then release your IP and resubscribe.
Feb 19, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
D-Link DI-524 Wireless Router
Start with the simplest answer first so make sure the laptop's WiFi is turned on. If you have set the router to provide a closed network your laptop will not see it automatically and you will need to enter the WiFi network settings in network setup. if you are using Windows click start, click control panel and click network, on the left hand sidebar you will see "Setup a Small or Home Office Network", follow the wizard and you should be able to get connected. If you are using Mac OS X click the Airport icon on your menu bar, click "other network" and enter the SSID, select the encryption type and enter the network key (password). Lastly make sure that if you have chosen to use an access control list you have entered and allowed your laptop's MAC address in the list before trying to connect.
Aug 15, 2007 | D-Link DI-604 4-Port Cable/DSL Router...
Open Questions:
See all D-Link DI-604 4-Port Cable/DSL Router (DI-604) Questions
D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge Logo
145 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
