Question about Maytag Atlantis MAV6000 Top Load Washer
Water drips into tub when machine is not running
I have already replaced the complete water valve assembly and I still have water dripping into the tub. Any ideas what might be causing this?
  • 943 Answers
Hi. thanks for the question. its strange that after you changed the valve . that its still doing it it .can only be a faulty valve. replace under warranty, in the mean time turn water off .the water should be shut off after every use anyway. we see some flooding from broken hoses, when nobody home. quite the mess .thanks the appliance doc please rate me
Posted on Oct 01, 2008
My washer will drip water back in the tub after complete washing is finished Why Help
If the water is dripping in from the area where it normally fills for a wash cycle, then you probably have a problem with the water valve. You can open them up to see if debris has made its way into the valve, but they normally are not real expensive and it may just be easier and less hassle to just replace the entire valve. Hope this helps!
Feb 18, 2015 | Maytag Washing Machines
Water is continually leaking into the tub from the inlets as a slow drip. This happens while the washer is off and continues forever unless the water supply is turned off. This is a stackable washer/dryer.
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Jan 06, 2011 | Washing Machines
After wash cycle is finished I lift the tub lid and water is dripping into tub.
You may be looking at residual water dripping down from the rim. If the drip is located near where the water fills from, then you may have a water valve (could be either hot or cold side) that is not able to close completely. The valves are typically replaced, but sometimes cleaning can help for short term. Consult your user manual for removal / replacement instructions.
Aug 18, 2010 | Maytag Washing Machines
Water drips into the tub when the washer isn't running
Your solonoid is in need of a service. Tilt the washer sideways after you unplug it and remove the water pipes. Once disconnected, undo a nut or two holding the plate in position.and remove water valve from machine. Possibly you can remove both water pipes from the valve assembly without going in from underneath. Once loose, use appropriate screwdriver or socket spanner and carefully strip the valve. Clean dirty area untill all particles are removed. reassemble and retry..
May 05, 2010 | Maytag PAV2300 Top Load Washer
I have a Model GSL9365EQ2. It has a slow drip
Take the drain hose out of the regular drain and lower it to gravity drain into a bucket, pan, or floor drain if available. Turning the water off should not have prevented the machine from starting. The drip is likely coming from a leaking solenoid water valve at the rear of the machine where the hoses connect. Replace the valve assembly after removing the cabinet top and maybe the cabinet back panel. Make sure to remove the power if you are going to do the work. Hope this helps!
Mar 26, 2010 | Washing Machines
Water drips into the tub from the inlet
Good day,
If water constantly runs or drips into the tub,even if the machine is off, then the water valve in the back of the machine, has one of the seals failing, and the water valve needs to be replaced.
Dec 22, 2009 | Maytag Washing Machines
GE WHDSR315 washer randomly drips still after done filling
you looking for a new water valve assembly...not very hard to replace..maybe a lil' messy
Aug 28, 2009 | Washing Machines
Water Level and Water continues to drip after cycle has ended.
The water dripping into the tub is caused by the fill valve solenoid not closing completely. The fix is to replace the fill valve. The overfilling of the washer is caused by the pressure switch. Over time the diaphram within the pressure switch becomes fatiqued & fails. The fix for this is to replace it as well... Hope this helps... Bill
May 18, 2009 | Maytag MER5775Q Electric Kitchen Range
Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washer continues to drip into tub after cycle in complete.
contstant water dripping into tub sounds like a bad water valve, no repairing valve just replace it
Feb 25, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
130 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
