My old Z22 died I would like to retreave the information from my PC to my new Z22 but I am switching to a Mac. Can this be done
Problem has been resolved
Posted on Oct 02, 2008
Lost my Cd to my palm z22. Does any one know were I can download the porgram for my palm. So I can put info on my computer. :)
behoney56:
The information support page for the Palm Z22 has moved around over the past few years. It is now at
http://kb.hpwebos.com/wps/portal/kb/na/zire/z22/unlocked/home/page_en.html
As well, I have an entire web page devoted just to maintaining, repairing, and using the Palm Z22, at:
http://kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.htm
As the Palm Z22 ages, there are issues with old and dying batteries, with the touch screen deforming and becoming useless, and various DATA connectivity issues, since the new Windows 64 BIT Operating Systems did not yet exist when the Z22 was diss-continued.
On my web page are links and USER information on the various solutions that they found, as well as a bit of information that I discovered, which is hitherto unknown!
Hope these tid-bits of help get your Palm Z22 up and running properly...
good luck
robin dusty graves
lost-cd-cdqazwk5fkdpm30unkbxcrm5-1-0.jpg Z22 PALM PILOT lost-cd-cdqazwk5fkdpm30unkbxcrm5-1-1.jpg
Aug 24, 2010 | Palm Z22 Handheld
I have a Palm z22 that won't keep a charge. My
The Palm Z22 is, I have found out, a bullet-proof design in regards to reliably keeping your valuable "DATA" safe over time. The Engineers at PALM really did a good job of Data integrity compared to many other devices. HOWEVER -- there are 3 common problems with the growing AGE of the Z22, 2 are with the dying batteries, and 1 with the years of wear and tear on the touch screen. The battery is a typical square, thin, modern Lithium battery, wired in with two wires ( + positive, red, and - negative, black ) that can be
taken out and replaced if you take the unit apart. In a brand new, in-the-box package, the battery is dying simply from old age. If the Z22 was used heavily, the constant cycling from dead to fully charged wears out the battery even more. The Touchscreen is a thin layer of plastic stretched over a sheet of glass, with a tiny air gap in between. Over time, the top plastic layer deforms - with hot and cold, air pressure changes, and being pressed by wearing the unit in a pocket, purse, briefcase, or even in a drawer with pencils, pens, and staplers etc. It is very important to have a hard cover over the screen! Other than just having the battery loose its weak charge continually, there is a problem with the unit getting into a state of BLACK SCREEN - it does not charge and remains "apparently" dead, since the logic circuits are in an invalid state, and it can only be reset if the battery dies COMPLETELY to remove the power on the logic circuits.
I have covered the topics of the battery problems, the data problems, the screen problems, and the disassembly, maintenance, and security, and how to get data off the unit, particularly to the new Windows Operating Systems that were developed AFTER the Z22 was no longer made. This is at
kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
I have ripped apart the Z22 repeatedly, and posted pictures of the various steps to service these units. There are links to aftermarket software to transfer data, and examples of how to USE the Z22, for valid purposes. This should be a one-stop source for any information or troublehooting the Z22, for those who have the Z22 and want to keep it operating!
good luck
robin dusty graves
Z22 PALM PILOT
palm-z22-keep-charge#solution-section-jquljdhkw5zrsfvn5uli2qb2-3-0.jpg palm-z22-keep-charge#solution-section-jquljdhkw5zrsfvn5uli2qb2-3-1.jpg palm-z22-keep-charge#solution-section-jquljdhkw5zrsfvn5uli2qb2-3-3.jpg palm-z22-keep-charge#solution-section-jquljdhkw5zrsfvn5uli2qb2-3-6.jpg palm-z22-keep-charge#solution-section-jquljdhkw5zrsfvn5uli2qb2-3-10.jpg
Mar 09, 2010 | Palm Z22 Handheld
My Palm Z22 won't turn on. If I do a hard reset
It absolutely won't, you don't have to worry. I've done it several times, and I know I was really nervous at first, but it's fine.
Nov 01, 2009 | Palm Z22 Handheld
How do i fix the touch screen on my palm z22?
I am repeating a previous answer, since it covers most of the common problems :
good luck
robin dusty graves
Z22 PALM PILOT
Z22 PALM PILOT fix-touch-screen-palm-z22-ngl0e1lc0ft3j10pmz4xzklk-4-0.jpg fix-touch-screen-palm-z22-ngl0e1lc0ft3j10pmz4xzklk-4-1.jpg fix-touch-screen-palm-z22-ngl0e1lc0ft3j10pmz4xzklk-4-3.jpg fix-touch-screen-palm-z22-ngl0e1lc0ft3j10pmz4xzklk-4-6.jpg
Aug 17, 2009 | Palm Z22 Handheld
Palm Z22 won't sync, USB Device Not Recognized
The Z22 is very well designed to PROTECT your stored data - do NOT do a RESET, since this has nothing to do with your problem! It sounds like your USB cable is damaged- a very common problem, usually one of the 4 or 5 wires near one end of the cable or the other, breaks inside the plastic covering, and you loose connectivity. The "OLD" Style USB end that plugs into the Z22 is getting difficult to find, since it has been replaced with the smaller "MICRO" version, available everywhere (As of 2014 ! ) It is available online very inexpensively.
I have a full page of information on the Z22, and how to repair, take-apart, maintain, and connect it. It is at:
I hope that this information helps you to get your
Z22 up and running again.
good luck
robin dusty graves
Z22 PALM PILOT palm-z22-sync-usb-device-not-recognized-ngl0e1lc0ft3j10pmz4xzklk-1-0.jpg palm-z22-sync-usb-device-not-recognized-ngl0e1lc0ft3j10pmz4xzklk-1-1.jpg
Feb 22, 2009 | Palm Z22 Handheld
Screen goes blank and requires a soft reset with "memo"
I believe that this problem relates to the BlackScreenOFDeath or BSoD - which is caused by a low or weak battery allowing the CONTROL Logic circuits to get into an invalid state where the ON/OFF/SLEEP/CHARGE/ FUNCTION transistors are niether on nor off. I would recommend getting a new battery as soon as possible. Doing a SOFT RESET "may" get you temporarily going again. DO NOT do a HARD RESET !. I have posted many discussions on the Z22 that you may find helpful, on my tiny website,
http://kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
One other possibility, is to take apart the Z22, and wipe the buttons and traces with a soft damp cloth to remove oils, water, and possible spilt liquids from the touch/snap/button/discs areas. Even the tiniest trace of conductive liquids will short out the logic circuits, causing "unknown: states on the control circuits.
My answer on the BLack ScreenofDeath, is as follows:
__________________________________________________
The Z22 suffers from 3 problems. One of these is the Black Screen of *****. I got a used Z22, and over the years discovered this problem. The small battery was a perfect fit of power and size when manufactured, decades ago, but, time alone has deteriorated the capacity, so that a "NEW" , sealed-in-the-box Z22 today, has a weak, dying battery that needs replacing. These are $10 free shipping from China. The BSoD seems to be caused by a dip in power from the battery to the LOGIC CIRCUITS that control the ON/OFF/SLEEP/CHARGE, etc states of the Z22. If the logic gets out of sync, the unit is in an INVALID state, will not charge, nor respond to the LOGIC buttons on the front - these buttons are NOT the standard ON/OFF buttons from the past that mechanically connected or diss-connected power. All the buttons on the Z22 are touch snap disks that are connected to transistors, to flip logic states. THUS, is the power in any of the transistors gets low, the transistor is neither ON nor OFF, and the control circuits are in a messed-up state. Or another way of looking at it, the ON button is a logic gate on a transistor network, and the only way to activate the "ON" logic state, is with full power to the circuits! -- the power on the Z22 is ALWAYS ON. . . The screen may turn off, and the chips may go into "sleep" mode, but the Z22 is always on. SO if there as a weak battery, you may get the random Black Screen of *****. The GOOD news, is the the DATA and programs that you purchased are incredibly SAFE, as long as you do NOT do the HARD RESET (which someone suggested ! (NOT ) ). I have ripped apart the Z22 dozens of times, and subjected it to freezing and heating and all sorts of horrible things, the data has always been 100% reliable, -- stored in permanent memory. There is a quick way to get rid of the BSoD - you have to open the unit and cut one of the two battery wires, wait 2 minutes to kill the logic circuit power, then re-connect. I added a switch on the Z22, just for this purpose. I would recommend, if you get the Z22 re-powered, to get a new battery as soon as possible. This should clear the BSoD for a while. See my tiny website :
There are many photographs and step by step procedures to try to get the data off the device, maintain the Z22, get parts, and use the Z22 with the new 64 Bit Windows computers. The BEST way to use the Z22 would be to get an old Widows 32 bit laptop (ie WinXP), and simply connect the Z22 in a standard way using the software that it was designed for... The new patches to 64 bit machines, are very limited, and many previous features do not work.
So the bottom line - all your data, information, and programs are safe. You simply have to reset the LOGIC CIRCUITS (this has nothing to do with the PALM Z22 SOFT and HARD Resets !) - it has to do with disconnecting the power from the battery, or waiting until the battery is COMPLETELY DEAD ! (which can take a long time! )...
Good luck
robindustygraves sept 2014 ( robin dusty graves )
Z22 PALM PILOT
Z22 PALM PILOT b24a4c23-cde3-44eb-a542-221e23771cfb.jpg 5d677a3f-163a-4546-ae79-d98c6fb397b6.jpg 5cb49c67-a9f7-4dbc-90df-4cf481cf4e2d.jpg badc8899-3493-408c-b9aa-fa81dc391d93.jpg ab336a44-9ab4-44a2-97f6-d3720b8639c9.jpg
Jan 30, 2009 | Palm Z22 Handheld
Palm sync doesn't work even though it says sync complete.
1. Right click on red/blue arrows on lower right of pc
2. Select custom
3. Check direction for all
If you found this helpful, please post as such. If this fixes of coarse, please post as fixya
Jan 02, 2009 | Palm Z22 Handheld
Absolutely black screen - will not power up - did not give warning of low battery - palm z22 about 2 years old ---is it dead????
The Z22 suffers from 3 problems. One of these is the Black Screen of Death. I got a used Z22, and over the years discovered this problem. The small battery was a perfect fit of power and size when manufactured, decades ago, but, time alone has deteriorated the capacity, so that a "NEW" , sealed-in-the-box Z22 today, has a weak, dying battery that needs replacing. These are $10 free shipping from China. The BSoD seems to be caused by a dip in power from the battery to the LOGIC CIRCUITS that control the ON/OFF/SLEEP/CHARGE, etc states of the Z22. If the logic gets out of sync, the unit is in an INVALID state, will not charge, nor respond to the LOGIC buttons on the front - these buttons are NOT the standard ON/OFF buttons from the past that mechanically connected or diss-connected power. All the buttons on the Z22 are touch snap disks that are connected to transistors, to flip logic states. THUS, is the power in any of the transistors gets low, the transistor is neither ON nor OFF, and the control circuits are in a messed-up state. Or another way of looking at it, the ON button is a logic gate on a transistor network, and the only way to activate the "ON" logic state, is with full power to the circuits! -- the power on the Z22 is ALWAYS ON. . . The screen may turn off, and the chips may go into "sleep" mode, but the Z22 is always on. SO if there as a weak battery, you may get the random Black Screen of Death. The GOOD news, is the the DATA and programs that you purchased are incredibly SAFE, as long as you do NOT do the HARD RESET (which someone suggested ! (NOT ) ). I have ripped apart the Z22 dozens of times, and subjected it to freezing and heating and all sorts of horrible things, the data has always been 100% reliable, -- stored in permanent memory. There is a quick way to get rid of the BSoD - you have to open the unit and cut one of the two battery wires, wait 2 minutes to kill the logic circuit power, then re-connect. I added a switch on the Z22, just for this purpose. I would recommend, if you get the Z22 re-powered, to get a new battery as soon as possible. This should clear the BSoD for a while. See my tiny website :
Good luck
Z22 PALM PILOT 691d763d-1b45-4323-a389-5dd3900ad65d.jpg 4ab4c25b-c05c-4deb-898e-d858abbab87f.jpg b63d6d62-a28c-4450-b1de-0e692a79ae08.jpg 8387fdcf-76fa-42ab-a7d4-e941d697b879.jpg
Nov 11, 2008 | Computers & Internet
Can I hot sync z22 palm without the touchscreen?
The data on your old Z22 is very likely very secure, and the touch screen problem is very common - there are a few tricks to get the touch screen working long enough to transfer the data.
I have a web page entirely for maintaining, repairing, and interfacing your Z22 at:
You can try these tricks, or just replace the screen for $9 U.S., since the screen only needs you take the unit apart and flip open a connector lock ...
I would strongly advise getting a solid plastic cover over your new Z22, since this is the key to keeping the screen working...
hope the information is of help to you
good luck
robin dusty graves
Z22 PALM PILOT hot-sync-z22-palm-without-touchscreen-ngl0e1lc0ft3j10pmz4xzklk-3-0.jpg hot-sync-z22-palm-without-touchscreen-ngl0e1lc0ft3j10pmz4xzklk-3-1.jpg hot-sync-z22-palm-without-touchscreen-ngl0e1lc0ft3j10pmz4xzklk-3-3.jpg
Nov 06, 2008 | Palm Z22 Handheld
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
