Question about Sony KDSR50XBR1 50" Projection HDTV
Sent you a fix on the tv...
Hi
read your plight with the 4 flashes...
check out my response, rate me after you see how easy a fix it is...
  • Anonymous Jan 12, 2009
    red light flashes 4 times removed bulb assembly then works ok
  • 41 Answers
Four flashes indicates fan error. Most likely candidate is the lamp or exhaust fan. With a flashlight look through the back of the set behind the fan when you first try on. You should see if the fan is moving or struggling to move. If its slow or not turning that's your problem. The fan needs to be replaced.
Posted on Apr 18, 2009
Samsung tv has flickering lineswhile watching tv
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec How to Fix Samsung TV Flickering Blinks Flashing Flat Screen ... Rating is available when the video has been rented. ... sorry to bother you tampatec but i have a RCA tv it works great when it's.... My Toshiba Full HD led tv model 32PT200ZE is having issues of screen blinking/flashing and horizontal lines.
Sep 25, 2015 | Samsung Televison & Video
Problems with chevy s10
have the actuator (mounted on the drivers side transfer case) checked. that is what makes the selection from 2-4 hi-4 low. it takes the place of a gear shift. they are a fairly inexpensive and easy repair (if thats the problem). i would start there providing you have checked the fuses and relays. i hope this helps.
Jan 31, 2014 | Cars & Trucks
On the spin cycle my washer is banging very violently is it off balance? Is that and easy fix?
Sorry to read about your problem, I hope this helps you out.
you may lost or have weak balance springs/rods in you machine, It does take experience to work with and balance machines.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | General Electric WJRE5500GWW Front Load...
The lights in our refrigerator suddenly stopped working. Is there an easy fix to this?
the easy fix, is to see if you have a defective door switch,
unplug unit, and take out door switch, to check
3 Thumbs - Helpful
Dec 31, 2010 | Samsung RF267AB (25.5 cu. ft.)...
Hi there, I've got a westinghouse freestyle 521 glass stove top and fan forced oven. Just recently when in use the oven stopped working, although the light and fan remained on. Is there anything like a...
sorry their is no simple fuse for what you are writing about, you may just have defective heat elements.or open thermal switches. and they are not easy to check
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 30, 2010 | Ovens
I downloaded Myfasterpc.com to make my netbook go faster. It says that I have 138 registry errors. How do I fix these. It says that it cant fix the errors due to the number of errors (138)
Hi ginger799,
First off, uninstall myfasterpc from your laptop. You'll have to buy it to get it to fix the registry errors.
Here's one i use for my customers....and it's FREE:)
http://download.cnet.com/Advanced-SystemCare-Free/3000-2086_4-10407614.html?tag=mncol;5
Very easy and straight forward to use.
If you need further help, please send me a mesage and i'll be glad to assist.
Hope this helps!
Please don't forget to rate:)
Dec 26, 2010 | Acer Aspire One Netbook 8.9" Notebook
Hi I have an electrolux front loader model number E/EWF1087/W I switch it on and all the green lights flash and I have an error code reading 'err90'. Can you please tell me what this is and can I fix it...
e90, means a bad connection. at the main control board.
you can try to open the machine and check a and clean all connections to the main board.
3 Thumbs - Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Electrolux EW1000i Front Load Washer
My xbox 360 has 4 flashing red rings
hi, 4 flashing red lights is telling you their is a problem with the video lead, try switching the xbox off and unplug all the leads from back of xbox and also back of telly, then plug them back into the xbox making sure you push them in far enough, doing this removes static and should solve the problem, then plug it into the tv and give it a try.
if after doing the above it still dont work then the next thing to do would be to try a neighbours or a friends video lead just to make sure the problem is with the lead and not the hana chip inside the xbox,
you should find another lead will solve your problem if unplugging them doesnt fix it in the first place.
let me know how you get on or if you need further assistance ok
please rate this solution and leave a testimonial please as most users dont leave a rating or response, thanks
Dec 12, 2010 | Video Game Consoles & Games
Stand by light flashes 4 times when turn on and nothing happen
I sent a premium offer to solve tv issue but got no response so far, not sure why.
I'm Sony tech and can be helpful to resolve this problem.
Aug 22, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
My sony cybershot DSC-T33 will not flash even though the flash is on. How do I correct this?
the flash is out. usually an easy fix. if sent to sony flat rate of around 140. and will come back with some warranty
Jul 10, 2009 | Cameras
Open Questions:
Sony KDSR50XBR1 50 black screen, no faults! Lamp working, fans OK Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on it's own. After disassembly, cleaning and lubrication of the fan, I have no errors but the input display or menu options will not post on the screen. The lamp is on but seems to either be projecting a solid black picture, or not be at full brightness and there are no faults. I have a solid greed LED on top, but can get no picture. Sound is fine. What should the lamp voltage be at operating mode? I have tried reseating connectors and pushing on the wires to make sure the connectors seat. This is baffelling because the lamp fired fine for 1 second before the stuck fan issue was corrected and I have no faults now after lubricating the fan. I'm going to check connectors again today as a triple check; as I did remove the power supply. The TV has been reset per instructions in the book. Any advice would be much appreciated but I cannot believe it's the OB as it worked fine before the fan quit and it's about 14 months old. I'm thinking something may not be assembeled correctly, but everthing seems to be pretty idiot proof for re-assembly. Also the menu or input banners will not post. I have 2 new lamps, so it's not that.It seems to be stuck in somne black screen mode. The large fan does start by itself now after cleaning and lubrication, therefore no fault blinks. Please help!!!
Mar 01, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50XBR1 50" Projection HDTV Logo
128 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
