Question about Back to Basics NS1000 Nutri Source Juicer
NutriSource juicer I accidentally put the blade on before the basket, and now it wont come off. When I try to loosen it, the blade just spins. Also, how can I contact their customer support?
  • 8,596 Answers
The support number is:
866-290-1851
Posted on Mar 25, 2009
I cant remove the blade or mesh basket to clean it.
you need the orange crescent shaped tool to loosen the filter
Jun 28, 2010 | Jack Lalanne Power Juicer 250 Watts
Jack LaLanne Juicer
Try this site for a manual
http://www.powerjuicer.com/pdf/classic.pdf
Dec 07, 2008 | Jack Lalanne Power Juicer 250 Watts
I bought the juicer at a second-hand store in brand new condition however the crescent tool was missing. To remove the flat blade for cleaning, I use a pair of scissors spread far enough to fit the ends in both holes. Hold the basket still while turning the scissors counter-clockwise untill the flat blade detaches. Easy as that! I ordered the tool, but it hasn't arrived yet. Hope this helps!
Oct 11, 2008 | Jack Lalanne Power Juicer 250 Watts
Acme juicer
There should be a lug nut in the center that loosens so you can take the blade, basket & outer basket out to clean.
Jul 26, 2008 | Acme 5001 Supreme Juicerator Juice...
Cant grt it apart to clean
Take off the top part of the juicer that has the chute. You will see the blade and basket. The blade appears to be attached to the basket with three small screws but is actually screwed onto the basket by a large screw that protrudes out of the basket underneath the blade. So the trick is to unscrew the blade, turning it to the left by using maybe a small screwdriver that you will have to put into one of the two small holes that are on the blade surface and pushing the blade to the left. This should loosen the blade and then you can just unscrew the blade off the basket. Once you get that blade off, the rest of the juicer comes apart. The newer models come with a little tool with a couple of arms that go down into those holes and loosen the top. Good luck.
Jul 22, 2008 | Jack Lalanne Power Juicer (Stainless...
Using the Citrus Attachment
CALL WARING AT 800 492 7464. MAY BE
SOME TYPE OF SAFETY CUT OFF. YOU
MIGHT ACTUALLY HAVE TO ATTEMPT
JUICING AN ORANGE OR SO WITH THE
NEWER MACHINES.
Jun 25, 2008 | Acme 5001 Supreme Juicerator Juice...
Cutting Blade won't come off
I do not have a tool so I used two pen tops, turned the blade counterclockwise while ensuring the filter basket stayed put. It worked well
Apr 16, 2008 | Jack Lalanne Power Juicer 250 Watts
How to dissassemble Jack Lalanne Power Juicer?
After about a half hour I finally figured it out. I'll go through all the steps.
1. Remove pusher from chute.
2. Pull the locking bar down over the spout.
3. Remove lid.
4. This part is tricky. Stick the orange crescent tool into the blade holes and while holding the filter basket steady with one hand, turn the blade couterclockwise while pulling up.You do have put a little muscle into it. And remember, if you don't hold the filter steady, the whole damn thing just spins.
5. Remove the receptacle.
Good juicer, but it seems unnecessarily complicated.
Jan 01, 2008 | Jack Lalanne Power Juicer 250 Watts
Take apart and clean the juicer
ok so i am tryin to take apart my juicer to clean it but i can't find a way to do it. Can u help me?
Dec 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Back to Basics NS1000 Nutri Source Juicer Logo
188 people viewed this question
Top Back to Basics Juicers Experts
eyecam
David Payne
David Payne
Are you a Back to Basics Juicer Expert? Answer questions, earn points and help others
