Question about Philips Magnavox MRV660 DVD Recorder
My philips dvd recorder is not letting me open the disc drawer. it tells me blocked, i can hear it trying to but is unable to. i have tried to restore factory settings but it has not helped
These methods have been shown to work
The electronic procedure:
Switch off the unit at the wall plug. On the front panel, hold in the <RECORD> and <EJECT> buttons at the same time, and keeping them held, switch on the power at the wall again. Keep holding the buttons until the disc tray opens.
The manual procedure:
There should be a small slot on the lower side of the unit near the front and center of the disc assembly. By sliding a small plastic numb from one side to the other unlocks the door so it can maually be opened the rest of the way. You will need a strong, thin object to slide that release nub. A small knife or nail would work. Of course you should follow all safety precaution such as removing power and not damaging anything else.
Posted on Dec 21, 2008
Cdr drawer won't open on Philips cdr 800.
looks like the rotor is jam or broken,try to unscrew it and open the top cover so you can see the rotor and then plug it in to the power source ,then always press the open/close button and check the rotor if its jam or broken and see what happen.
Jun 06, 2010 | Philips CDR800 4-Disc CD Recorder
Disc drawer says BLOCKED and will not open. No disc is inserted
I had the same problem . I had to take the outer casing off and was able to open. to keep this from happining again I always leave a disc in the disc drawer it seems to solve the problem
Mar 07, 2009 | Philips DVDR3450H DVD Recorder/HDD...
I cannot open the DVD drawer on my Philips DVDR3480 DVD RECORDER – it just won’t open? The screen display just keeps saying ‘Error’. Any help is appreciated.
I have two of these dvd recorders and both have the exact same problem where the drive won't open. It opens fine when there is a disc in the tray. So I just unscrewed the cover, press the white part which would be over the center of the disc as it's trying to open, it should then open. Then just make sure there is always disc left in the tray.
Nov 26, 2008 | Philips Televison & Video
My ex77eb recorder keeps coming up u61 on the display and then tells you self check did not complete, it tells you to press ok, it then says the unit will open ang go onto stanby, it doesnt do this it...
Do you have young kids. I have had the same problem, tried everything. Left it unplugged overnight - no difference. Tried forcing it to reset - no difference.
Unit is still under warranty but I have caught my kids putting discs in it before so I completely unplugged it the flipped it upside down a few times and could hear something rattle inside, then all of a sudden an earing fell out of the dvd drawer. Plugged back in, let it go through recovery and hey presto back to normal.
If the dvd drawer is not staying open as mine was you can force it opened by having the unit plugged in but switched off then hold down program up and the stop button on the unit simultaneously.
Hope this helps.
Nov 18, 2008 | Televison & Video
Recording problem
I have had two of these recorders, Using only Sony + discs or rewriteables is my solution, I will not use any thing else. It may work 1-3 times on others brands then start throwing coasters.
As to renaming, on my model I pull up the tiltle menu then select Try using rewriteables for the other problem as well My model is a little older and lets me take disc out without finalizing then when inserting select title, hit edit on remote and select rename. Maybe if you can skip the finalizing (as with rewritables it will help
Apr 01, 2008 | iLO DVDR05 DVD Recorder
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Blocked dvd tray
The disk inside is most likely jammed. It would be best to take it to a repairman, or you can try to remove it your self.
Jul 14, 2007 | Philips DVDR75 DVD Recorder
Open Questions:
Philips Magnavox MRV660 DVD Recorder Logo
382 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
