Question about Oreck XL21 Bagged Upright Vacuum
Oreck wiring I've read the threads. Which 2 terminals are the lights and which 2 are the motor ac?
  • kevinrntz Oct 03, 2008
    Thanks to Reddevil6! If others read through these posts you will see that on the Oreck XL motor, if you replace the motor you must be very careful putting the wires to the correct terminals. The diagram used for a previous fix is too small to read. There is a black dot marking each A/C terminal with the black wire from cord going to left upper on the motor (looking from belt as installed) and the white wire going to the lower most right terminal (on the piggyback white wire if you have the parallel light harness), On my motor the black (light bulb) wire goes on the other terminal lower right. If you mess this up you will burn out your light bulbs. Of course ALWAYS make sure you are unplugged while working on your vacuum. If not experienced with electricity, take to an authorized repair center!
3 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Clear oreck schematic
Here is Oreck's motor wiring diagram, if it isn't big enough to make out, give me your email addy and I will send it to you.
Posted on Oct 02, 2008
  • 206 Answers
SOURCE: I had a loose wire in my Oreck XL motor. I took it
Lights are 12 volts.
The motor has taps on it to pull 12 volts rather than 120 volts for the lights, uses the motor as a transformer.
Should be black and white to the motor from the switch, believe the switch breaks the black wire. White wire should be neutral. I can't remember colors for the wires to the lights. Would expect it to be the white wire and then the "tap" wire to be red.
One crazy way to do it, is to hook up wires, leave the light bulbs out, turn on power, and check voltage at the bulb socket with a voltmeter. (This is one of those things they tell you on television to only let a professional do, do not attempt at home.)
Posted on Aug 07, 2009
wentlanv
  • 710 Answers
SOURCE: I need a wiring diagram
Hi Gregory,
You can get wiring instructions from the Oreck factory. They'll need both your model number and serial number. Here is the number to call: 1-800-989-3535 and here is their website: 1-800-989-3535
Hope this helps. If it does, I'd appreciate your 4 thumbs up. Thanks,
Handie Andie
Posted on Apr 16, 2011
HOW DO I HOOK UP THE WIRES TO THE MOTOR I FORGOT
You should only have 4 wires to hook up to an Oreck motor. The black wire from the cord coming into the back of the motor housing will be attached to the closest lead when the motor is in it's normal position. Most of the time there will be a black dot next to the terminal. On the other side of the motor you should have two white wires that should be connected together, one from the same cord just mentioned and the other one coming from your lights. Those two wires should also be connected to the motor where there is a black dot beside the terminal. Your last black wire coming from the lights should go to the terminal next to where the white wires are connected or to another terminal that is on that side of the motor. Hope this helps!
Mar 14, 2015 | Oreck Single Speed Handle Assembly - White...
Need a wiring diagram for an Oreck XL 9100 with a amatek motor.Seen one but to small to read.
Jerry, typically the way it should be wired, is the black wire from the handle cord will go to the closest terminal on the motor from where the cord comes into the back of the power head. There should be a black dot beside the terminal. The two white wires should go to a terminal diagonal from the black wire connection and should also have a black dot beside that terminal. The other black wire should go to the terminal beside the terminal that the white wires are connected to. If there are not two terminals side by side then the black wire will go to another terminal that will be on the same side of the motor as the white wire. Hope this helps!
Jan 28, 2015 | Oreck Vacuums
How to properly wire the cord at the switch on Oreck XL Pilot Series? Wired it wrong during a cord replacement at the switch. I couldn't remember which prong to put the black wiring on. Switch has 3...
Joanne, when you take the screws out of the handle, and take the handle half off to expose the switch, the black wire from the handle cord goes on the front terminal on the switch that is by itself. The black wire from the power cord will go on the terminal that is facing up as you look down on it. Hope this helps!
Jan 23, 2015 | Oreck Vacuums
How do I wire an oreck xl9100 motor
The black wire coming from the power cord will go onto the terminal closest to where the cord goes into the vacuum. Sometimes there is a black dot next to the terminal. The white wire from the cord will attach to a piggy-back terminal on the white wire coming from the lights and will attach to the motor on the other side of the motor from where the black wire attached. There may also be a black dot beside that terminal as well. The black wire from the lights will attach to a terminal on the side where you attach the white wires, either right next to them or above them on the same side of the motor. Hope this helps you.
Sep 06, 2014 | Oreck Lamp Housing with Reflector XL9100...
Oreck U4148 motor wiring
Pat, I do not have a diagram for you but I can tell you how they normally are hooked up. When you have the motor sitting in it's normal position the black wire from the power cord will attach to the terminal closest to where the cord comes in. There should also be a black dot next to the terminal. The two white wires will connect together and they will go on a terminal on the other side of the motor that also has a black dot next to it. The remaining black wire should connect to a terminal next to the white wires or at least on the same side of the motor as the white wires. Hope this helps you.
Mar 09, 2014 | Oreck XL2600 Vacuum
Ametek wiring diagram for a Oreck XL21 600 ECB
I cannot find a wiring diagram from where I am located right now, but I do know that the black wire coming from the power cord goes to the top side of the motor when you have it laying upside down with the cover off, and it will go to the tab towards the back of the vacuum. Sometimes they put a black dot beside the tab and if that is there you put your wires from the power cord on those. You will also have two wires coming from your light bar in front and the white wire will usually have a piggy-back terminal that your white wire from the power cord attaches to as well. If there are no black dots beside the terminal tabs the white wires will connect to the bottom terminal on the opposite side from the black power cord wire. It will usually be on the lower side of the motor as well. The black wire from the light bar will go on the remaining terminal tab as there is usually only three tabs on the motor. I will check back later this week to see if this has helped you and if not I should be able to get a diagram this weekend.
Sep 22, 2013 | Oreck Vacuums
Need wiring schematic for ametek 119550
I had the same problem after not paying attention to the connections when replacing my motor. I spent days searching for information and only found several non-answers with small photos that no one can read.I contacted Oreck for wiring information. They explicitly stated that they can't provide any wiring information for safety and liability reasons.
I found the Ametek schematic which shows the LINE and TAP locations on the motor.
Note: I have a 2600HH XL with 2 headlights.
Connect as follows:
3A, LINE: White lead w/piggy back terminal from light harness #1 & white lead from the power harness to the piggy back terminal
2A, TAP: Black lead from light harness #1
3B, LINE: White lead w/piggy back terminal from light harness #2 & black lead from the power harness
2B, TAP: Black lead from light harness #2
Dec 13, 2012 | Vacuums
Model Oreck 2600HH- need schematic
white to motor terminal,black to other motor terminal,green is always ground to housing there is a small terminal tucked away its s small spot for the lights
Feb 01, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Oct 01, 2008 | Oreck XL21 Bagged Upright Vacuum
Wiring Schematices
Connect as follows:
Mar 31, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL21 Bagged Upright Vacuum Logo
304 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
