Question about Sony KDSR50XBR1 50" Projection HDTV
Kdsr50XBR1 FAN FIX!!!! SPREAD THE WORD!!!!
Cliff!!!!!!!
I have the answer for the fan issue on the KDSR50XBR1!!!!!
Ok, I think I have the answer for the BIG FAN failure. I recently did a similar fix on the spindle of an xbox 360 and it is identicle. Ok, this is an EXTREMELY EASY FIX...
Open the back of the tv, locate the large fan (on the lower left on the back of the set.) unscrew the screen and remove the fan.
Once the fan is removed, you will see the side with the model number and the other side is totally open.
On the open side, pull...
The fan will come off, into your hand, it is only held by magnets...
You will notice a spindle on the fan and the other side has the magnets and the hole where the spindle came from (this is the fan motor).
Clean both the spindle and the hole (motor) with a q-tip. The hole is smaller than the q-tip, but do the best you can to remove the old lubricant.
Get a bit of WD40 and lubricate the spindle and spray a touch in the hole.
Put them together, reconnect your fan, test it on startup and thank me...lol...
HOPE THIS HELPS!!!! IT WORKS, TRUST ME...
What do you think? Spread the word, lets save some folks from spending needlessly...
  • 41 Answers
Replace the fan cleaning or lubricating will not last.
Posted on Apr 18, 2009
Tv cooling fan
which fan, the unit has at least two of them. You getting a fan error or what? The Sony sets do have a error buffer you can try to call up.
Dec 17, 2012 | Sony KDSR50XBR1 50" Projection HDTV
Sony kdsr50xbr1 over heating red light flashes 2 times
There are 4 fans in the set. If a fan is clogged with dust, the fan will not provide proper internal cooling.
need to clean or replace fan's
Oct 02, 2011 | Sony KDSR50XBR1 50" Projection HDTV
KDL-46VL130 RED LIGHT FLASHES 5 TIMES WONT TURN ON
Sep 28, 2011 | Sony KDSR50XBR1 50" Projection HDTV
With the red light having four blinks, it looks like it could be a faulty fan. Are all the fans the same on a Sony WEGA KDSR50XBR1?
Does all the other functions work well and if your set works other wise if force cooled ?
In such a case if the heat exceeds the possiblity of a cut off cannot be ruled out and checking onthe power to the fan will justify.
Sep 24, 2010 | Sony KDS-R50XBR1 50" HDTV
Sent you a fix on the tv...
Four flashes indicates fan error. Most likely candidate is the lamp or exhaust fan. With a flashlight look through the back of the set behind the fan when you first try on. You should see if the fan is moving or struggling to move. If its slow or not turning that's your problem. The fan needs to be replaced.
Oct 01, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Sony SXRD Projection TV
This is a fan issue, most likely the large fan in the rear, lower left (from the back)...
Here's the fix, I promise, it's EASY........
Jul 12, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Standby Green light Blinks 52 times
52 times? Sorry for laughing...
I would bet it actually flashed 4 times and continued to cycle four times...lol...
If that is the case, check it again to be sure...
If so, here is a very easy fix, created by yours truly...
May 27, 2008 | Sony KDSR50XBR1 50" Projection HDTV
SONY XBR1 SXRD
I get the same problem (4 flashing red lights).
I done some internet troubleshooting and narrowed it down to an overheated power circuit card/fan issue.
It turns out one of the fans is failing and will not rotate at the appropriate speed to cool the power circuit card, this will kick out the 4 flashing lights from the diagnostics.
In lieu of replacing the fans I have a temporary solution:
For my TV (kdsr50xbr1) the fan in question is located on the far left side (facing the rear). You will see a grill on the back of the TV showing you where the fan is located.
First, get a can of compressed air and blow it into every fan. This will clear away a lot of dust and help the fans move easier.
There is one blower type fan located inside the TV, remove the back panel and look for a tall yellow circuit card just to the left off the center of the TV. Behind that card is a blower (stands upright looks like a tube). Blow air into that blower, you will see a lot of dust come through the duct and out where the large fan in the center is located.
Put everything back together. and provided the fans aren't too far gone the TV should be working again.
Also, if the issue comes back, try this:
When you turn on the TV, shoot a short squirt of compressed air into the fan (Far left facing the rear). This will give it a kick start and bring it up to speed.
It is important to note that the compressed air cans do contain a liquid and as such are not compatible with electronics when they are plugged in. Try your hardest to keep the can upright and not allow the liquid to squirt out where it shouldn't. If it does it will evaporate in a few seconds.
Ok, relatively long post, to summarize:
1. Open back of TV, blow compressed air into every fan to clean them.
2. Blow air into whichever fan is causing problem if it happens again.
3. Keep the can upright if the TV is still plugged in. Don't sue me if you fry your TV.
4. If this doesn't work (has for me) replace fans
Mar 18, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Sony SXRD KDSR50XBR1
Jan 17, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Open Questions:
Sony KDSR50XBR1 50 black screen, no faults! Lamp working, fans OK Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on it's own. After disassembly, cleaning and lubrication of the fan, I have no errors but the input display or menu options will not post on the screen. The lamp is on but seems to either be projecting a solid black picture, or not be at full brightness and there are no faults. I have a solid greed LED on top, but can get no picture. Sound is fine. What should the lamp voltage be at operating mode? I have tried reseating connectors and pushing on the wires to make sure the connectors seat. This is baffelling because the lamp fired fine for 1 second before the stuck fan issue was corrected and I have no faults now after lubricating the fan. I'm going to check connectors again today as a triple check; as I did remove the power supply. The TV has been reset per instructions in the book. Any advice would be much appreciated but I cannot believe it's the OB as it worked fine before the fan quit and it's about 14 months old. I'm thinking something may not be assembeled correctly, but everthing seems to be pretty idiot proof for re-assembly. Also the menu or input banners will not post. I have 2 new lamps, so it's not that.It seems to be stuck in somne black screen mode. The large fan does start by itself now after cleaning and lubrication, therefore no fault blinks. Please help!!!
Mar 01, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50XBR1 50" Projection HDTV Logo
294 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
