CM 9521A ROTATOR PROBLEMS
I JUST HOOKED UP MY NEW CM SDW1850 ROTATOR BUT DOES NOT WORK. WHEN YOU PUSH THE UP OR DOWN BUTTONS IT ONLY TURNS IN ONE DIRECTION AND DOES NOT STOP WHEN YOU LET UP ON THE BUTTON. IT WILL CONTINUE TO THE STOP AND KEEP HUMMING. THE ONLY WAY TO SHUT IT OFF IS TO UNPLUG IT.
CAN YOU TELL ME IF THERE ARE A LIST OF CODES THAT FLASH UP ON THE SCREEN SO I CAN DIAGNOS IT?? CAN THIS UNIT BE RESET TO FACTORY SPECS SOMEHOW??
DanEz007
  • 86 Answers
SOURCE: MRM 700 won't start; screen flashes white . . . help.
stonelinton, It's not your LCD, otherwise you would have heard the sound of buttons being pushed. If your units first screen is white and there is no logo screen or any legible images, then it's your NAND flash on your main board. The first image produced upon boot is the blue magellan screen. This is produced from the NAND flash and will show it no matter if a hard drive is present or not. After the Magellan screen it pulls images from the hard drive. So, it is the mainboard and the only way to fix it is to send it to Magellan repair and they will have to put in a new mainboard then reprogram your serial number, etc.
Posted on Jun 07, 2007
  • 30 Answers
SOURCE: Denon stereo remote stopped working correctly
try programming ur remote
Posted on Jul 17, 2007
  • 4 Answers
SOURCE: Remote stopped working
http://www.fixya.com/support/t320518-bose_321
Posted on Jan 13, 2008
Slinteriors
  • 8617 Answers
SOURCE: green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
Posted on May 16, 2008
SOURCE: direct tv remote control - tv volume
PaulTulsa is actually incorrect, Directv remotes do allow this function. I had this problem too... but was able to fix it. You have to go back into the system settings menu. Depending on your receiver (I have the hr21-100) press "Menu" then scroll to "Parental, Fav's & Setup" then "Sytem Setup" then "Remote" then select "Program Remote". Scroll to "TV" then select the brand name (I also have a Samsun tv). Follow the directions to change the code of the remote and manually go through the codes they have posted. The second one worked for me. Good luck.
Posted on Jul 29, 2008
Lg direct drive start button is not work" what's problem in machine
Take off the control panel. There is a little plastic arm behind the start button that may be worn down on the end and may not be making contact with the electronic button underneath.
To access the control panel on the WD14700RD:
  1. Disconnect the unit from power and water
  2. Remove the top: take off two screws at the back, push it backwards one inch and lift it off
  3. Take out the soap tray and remove two screws on the soap tray compartment.
  4. Remove the control panel: push down on the two arms on top of it so that it can pop out, and pull it out at the top and then lift it off the bottom hooks. Pull it out a little from the machine, about an inch.
  5. Remove the front plate from the control panel: there are 7 screws behind it. Rotate the control panel up or down in order to access the screws behind
  6. Now that the front plate of the control panel is loose, identify the arm of the button that has stopped working. Wrap a small amount (2-3 times around) of electrical or plumbers tape on the very end of the plastic arm. Or if there is a nib instead of an arm, a small dab of epoxy resin allowed to harden does the trick.
  7. Refit the control panel and test the button now works.
  8. Reassemble the control panel, top, and turn on water and power.
  9. Test once again.
And that's it! All you need is a screwdriver and some tape. Too easy. Hope the information helps out.
Sep 17, 2016 | LG Washing Machines
My remote is not working
You have to hook up roku box BEFORE YOU PUT IN BATTERIES IN remote.Make sure batteries are making a good connection try rotating batteries or try new batteries.Some ROKU models have a button in remote next to batteries. this has to pushed to connect to ROKU box.
Jan 01, 2016 | Roku 3
Juki LU-562 I heard a clunck and the bottom walking foot doesn't work right .
Hello, I have a different model Juki but it sounds to me that your safety clutch has been tripped. The safety clutch functions when an excessive load is applied to the hook or the other components during sewing. At this time, the hook will not rotate even if turning the handwheel. When the safety clutch has functioned, remove the cause and reset the safety clutch by pressing and holding the push button on the top surface of the machine bed, while strongly turning the handwheel in the reverse direction of rotation. The resetting procedure is completed when the handwheel clicks.
Jan 07, 2014 | Juki Sewing Machines
New blue flame heater, everything is hooked up, gas is going to unit, I have a natural gas hookup, in the correct port, knob is turned and locked into the NG position but unit wont light. There is gas...
do you have the pilot light burning if not then you have to get in burning first
Put knob in pilot position push down and hold for at least 30 seconds or longer then if there is an igniter push and release it push and release till pilot light comes on .Continue to hold pilot light button down for another 10 seconds or so, release pilot button and turn button to on or up a number or set T stat
Main flame should come on and burn
Oct 13, 2013 | Procom Heating & Cooling
Dough hook will not come off
I had the same problem too. There should be maybe 1/4" of loose vertical play of the dough hook (or similar attachment) on the agitator shaft. The hook locks in place rotationally on the shaft until it is pushed up. Before you try to turn the dough hook backwards in an attempt to remove it, push it upwards and hold it up, then rotate.
May 22, 2012 | Hobart A200 Stand Mixer
I push the start button and the dryer makes a humming sound and the drum doesn't turn nor does the dryer turn on
Humming indicates motor is getting weak. If you look in the back compartment of your dryer you can probably see the belt. You can relieve the belt tension and then take the belt off the motor pulley. Once you do this, make sure the belt is out of the way and push the start button. If the motor turns it means it couldn't push the weight and is too weak to run. It make not turn without the belt on it either but you will hear if the sound is coming from the motor. In either case you need a new dryer or new motor if the dryer is pretty new.
May 02, 2010 | Dryers
Computer will not turn on
It sounds like your power switch (the buttone you push to turn on the computer) is stuck, or you have a bad power supply (that provide power to the computer). Electric components sometimes go back if they are not used often.
Aug 18, 2009 | Computers & Internet
Rotor not turning antenna
Most rotors have a brake, if yours has one, you have to hold the brake down then rotate.
Jan 31, 2009 | Channel Master 9521A Remote Control
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
