Question about Corona 23-DK Compact Heater
Burns unevenly and smokes
I replaced the wick at the end of the last heating season. When I lit the heater this year, the flame is extremely uneven, one side is very high and the other very low. In addition, the heater produces a large amount of soot. As I turn the burner, the high part of the flame moves with it. I have taken the heater apart three times and see no obvious problem. The only other thing I can think of is that I accidentally bent either the burner or the part it rides on and this is casuing the problem.
  • 4 Answers
Try emptying your heater of fuel,and lighting it letting burn for several hours. This will burn all of the deposits off of the wick. Make sure your heater is outside when you do this. when done lower the wick,fill with fuel,and let the wick soak for fifteen minutes before lighting.If this doesn't work try brushing the top of the wick a light brush of some sort and light.If still no luck,change the wick.
Posted on Nov 02, 2008
Put in new wick cleaned it up wait an hour lit it and it smokes any suggestions
new wicks in kerosene heaters will smoke till the mfg coating burns off it , burn it outside for a few hours then readjust wick height then it should stop smoking
Mar 11, 2015 | Heating & Cooling
I just replaced the wick, cleaned up the heater and filled with new K-1 kero. The heater (Dyna-Glo RMC-95-C7) is emitting black smoke worst than ever. The wick is burning a little unevenly.
Either the wick was improperly installed or you may not have allowed enough time for the wick to soak in the kerosene and become evenly distributed. Check the placement of the new wick and allow time (several hours) for the wick to absorb the kerosene.
Jan 31, 2011 | Dyna-Glo RMC-8001SS Heater
After shutting off heater it smokes out the back of the heater
This can be caused by an uneven or worn wick. Replace the wick and make sure there is no debris in the wick channel as when you shut off the heater if a piece of wick or debris is sticking up it will smoke after shutting down untill it has cooled.
Oct 08, 2009 | Dyna-Glo Heating & Cooling
I have a goodman gmpn 100-4 REVB furnace that will not stay lit
If the igniter lights the burners the ignitor..... is not bad. Its like a light bulb.... it works or ot doesn't.
You are describing a dirty flame sensor. Dishonest contractors will sell you a new ignitor but clean the flame sensor when the are installing the ignitor. It is located at the opposite end of the burners than the ignitor. It has one wire going to it. Remove it and clean the rod with a piece of fine grit sandpaper. this should be done every year before heating season.
Good luck
Mar 28, 2009 | Goodman GMS90703BXA Heater
My Dyna GLo kerosene heater has excessive smoke and yellow flame
I'm wondering the same
Should a duraheat, etc., cylindrical convetion heater's flame be bright yellow, blue , or what? With the old wick the flame was blue, with the catalytic converter glowing red hot. Now with the new wick, I can't even see the CC, because the flame burns a bright yellow. Also I have to really fine tune it now. A wee bit too high, I get smoke and soot. A wee bit too low, same...smoke and possibly flame out.
Feb 24, 2009 | Heating & Cooling
Master 160,000 btu will not stay lit
pull out flame sensor and sand. Re install and call for heat
Jan 21, 2009 | Master Heaters 160-IF
Only half of the wicks burns/ flame varies in height/ smokes !
Sounds like you have a wick that has burnt unevenly in the past and now there is not a good setting for an optimum burn. Either the wick needs to be trimmed even or you need a new wick.
Nov 14, 2008 | Heating & Cooling
Dyna glo RMC95C6 kero heater
I suggest you replace the wick and clean the wick feeder assembly. I did not own that model but did have one a number of years ago. The wicks can begin to dry out.
Jan 08, 2008 | Northern Tool 10,600 BTU Radiant Kerosene...
Why am I replacing wicks every 3 weeks
could be you got the flame a little too high so its burning off the top of the wick.
Dec 27, 2007 | Corona 23-DK Compact Heater
Corona 23-DK Compact Heater Logo
248 people viewed this question
Top Corona Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Corona Heating and Cooling Expert? Answer questions, earn points and help others
