Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Bosch dishwasher not 'steaming' plates dry
Hi. My Bosch dishwasher used to give off loads of steam when I opened the door just after it finished it's cycle - now there is no steam whatsoever and the plates etc are cold and not completely dry. Do I need a new heating element or what could be the problem??
  • John Ralph Jun 07, 2013
    Hi. I have a similar prob on a Siemens D/W. It seems to run for about 3 hours and when it's finished there's no steam when you open the door and plates etc are cool/luke warm and wet. They are also slightly dirty. Does anyone know where and what the themosat looks like and where it can be found?
My Bosch dishwasher used to give off loads of steam when I opened the door after it finished it's cycle-now there is no steam and the plates etc are cold and not dry...Does this sound like the heating element? This dishwasher is approximately l0 yrs. old (built in).
Posted on Apr 30, 2009
    Sergeant:
    Champion:
  • 324 Answers
First check to make sure you don't have a air dry option.then look at the thermostat then heater.
Posted on Nov 11, 2008
Dishwasher not drying the dishes using the fan when the programme finishes
It is likely the rinse aid is low or empty. Check the rinse aid dispenser to see level of rinse aid. Also make sure when you open the dishwasher at end of dry cycle that it is hot inside. Otherwise most likely there is not enough steam as the heater may not be working to capacity or the thermostat is not regulating the water temperature to generate steam for drying.
Feb 05, 2014 | Fisher and Paykel Dishwashers
Not sure this is the model but the inside stays wet after dry cycle - all stainless steel inside. WHY? and what should I do?
These units are made by Bosch and they have passive heaters. Use Jet Dry Turbo in your rinse aid compartment and make sure you are there to open the door when the dishwasher ends. If you wait for hours until the dishwasher cools down to open the door, the steam will recondensate and the inside will be wet.
http://www.appliancerepairlesson.com
Mar 05, 2011 | Thermador DWHD94EP Stainless Steel...
Dishlex dx302 not drying dishes. Doesn't seem to be as hot as usual when opened immediately after finished. Steam not present.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Mar 04, 2011 | Dishwashers
Dishwasher does not dry all the disher water lef on dishes
Make sure your machine is not over loaded.
When you open up the door when machine has just finished do you get a cloud of steam ?
If not the drier element has blown and will need to be replaced.
Feb 05, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
The dishes are pretty wet as is the inside of the dishwasher after a regular run. will a rinse agent fix this?
Rinse aid will help.The Bosch dishwasher uses the captured heat from the water to dry the dishes.turn on your dishwasher ,wait 20 mins and open door .Does steam come out?if yes rinse aid should do trick,if not water is not heating and you probably have a bad e.control (common problem)est repair cost in Boston area $229.. Hope this helps ,please rate my response :)
Dec 08, 2009 | Bosch Evolution 800 SHE68M05UC Stainless...
Dishwasher maytag 945 awq
Door gasket or sealOver time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Nov 08, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Wet dishes; steam does not escape
Hi, Most dishwashers do not have steam vents! there are several reasons for poor drying in a d/washer! The first one is to see that you have rinse aid in the machine as this aids drying! Next if you have rinse aid then is it being put into the machine when it needs it? Also you must bear in mind that the dishwasher need to heat on the last rinse to create the heat to dry the items which use the steam to dry them. Check the rinse aid first and see how you get on....
Let me know.......
Aug 01, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Drying cycle problems
Take the door fascia off, and you'll see a pipe from the steam outlet to the Soap Dispenser in the door.
Take that off, and flush out the small bit of food that is blocking the tube.
Put the cleared pipe back in situ.
Run machine, you should get steam, and no water.
When it blocks again, and you get the water again, repeat unblocking process etc...
Jul 16, 2008 | Miele 24 in. G665 Built-in Dishwasher
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
678 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
