Aiwa F2000 20" TV
Problem for Aiwa F2000 20" TV
Greenish tinge on tv screen
By pandamama - usenet poster
Hi there.
Recently on my tv screen, everything seems to be a greeny-yellowy tinge. I dont know why. It kinda just appeared one day.
I tried fiddling with the brightness, colour and contrast settings but that didnt seem to make any difference. I thought it was my cable tv receiver but even on channels that dont work, a the blur lines have a yellow opaque screen over them.
I've also tried using the VCR tv tuner, but the problem is still there.
Any ideas?
Same Problem
Oct 23, 2008
-   NEED HELP!
Kids TV went green,Sounds like alot of people are having the same problem. Anyone get a fix?? RCA Truflat m# 14fs12t made Aug 05.-   heyoka112
Apr 10, 2008
-   Hi, we have a redish tint on out PAL JVC set, had the back off tonight to see if there were any adjusting pots for the guns like in the old days but nope couldn't see any. I see there are test card DVDs available for people to set up picture sharpness/focus colour and sound, so there must be some way of adjusting them.
Thanks in advance for any help.-   puss2cats
Dec 06, 2007
-   have same green yellow tint on rca f25442 screen. picture and sound are fine. Heard popping noise then tint appeared. tried a justing color and tint and brightness etc....didnt work-   Guest
Solution #1
posted on May 30, 2006
Somewhat Helpful)
Melissa
Rank: Apprentice
Rating: 0%, 0 votes
Well based on the very limited amount of info you provided I would say your set is suffering from a white balance problem due to low CRT gun emission or a RGB drive problem since anytime a set is predomineintly one color more then another on a grey or black or white screen it is due to a white balance problem Now since you did not give model or chassis info there is not much more I can tell you but since you refer to color as colour I am going to assume your not in the US and that means your system is probally PAL or some other format and that being the case then you really need to provide us more info to be able to advice you any further.
Regards
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Aiwa F2000 20" TV
Questions and Unsolved Problems for Aiwa F2000 20" TV
Do you recommend Aiwa F2000 20" TV?
Answer
Answer
phillips 27 inch switches on and has coloured lines running down the picture - not sure what to do?
Answer
my philips 27 inch tv model # 27pt5445/37 has no picture, it started out as purple colors in the... (More)
Answer
The volume level of my Aiwa A2119 is not increasing or decreasing though the volume level displayed... (More)
Answer
i have aiwa tv-A2119.my serviec man says there code that look my tv sound option from remote... (More)
Answer
i notice that there a few roachs in tv what do i need to do to get them out?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Aiwa F2000 20" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 821
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
