Question about Fuji FinePix A600 Digital Camera
No Power My camera won't turn on even when I put new btteries in , so I know for sure it isnt the batteries. Please help as I have some important pics on it I want to download.
  • 797 Answers
Hi:
Some problems cannot be fixed, and I am afraid that if you cannot get the camera to go on with the on/off switch, then there is nothing I can even guess to do. That is because it could be a thousand things. Stating with the on/off switch, the battery connections, the battery interior connections, corrosion, water damage, acid damage from corrosion, burned out parts, broken chips from possible overload, damaged LCD, damaged and broken lens system, a shorted part or motor, and so on. These are only some of the problems I have discovered with the digital cameras I have tried to repair in the last few years.
One thing, if you are not afraid to damage the camera even more, should it not work, is to fold a towel and lay it on a table, then hold the camera (turned off) so that it will come down on it's corner. Don't be too hard, but do use a firm hit down. You may try a few other angles. What this may do, no promises, is that it may jog something inside to allow the camera to start.
If this does not work, then the camera needs repair, and may not be worth repairing. Repairing can cost $150.00 or more depending on what is needed.
Posted on Oct 02, 2008
Finepix s3380
Still, power, or better said, the lack of correct power supply is the cause of most problems in electronic apparatus.
Please also check the contacts in the battery holder. If there is any corrosion, the voltage that is left for the camera can be just to low to work correct. And also new batteries can be worn out before you put them in the camera. Always check the date on the batteries.
Never use manganese (Zinc-Carbon) batteries. They don't have enough power to let a modern camera work. Even the expansive alkaline batteries, only have enough power to let you take perhaps 100 pictures. The best choose is Li-Ion or NiMH rechargeable batteries.
New rechargeable batteries, can only deliver "Full" power after a few charge / discharge cycles.
Nov 29, 2013 | Cameras
The camera was exposed to rain and it won't even turn on.
Hello. Please follow these 5 easy steps:
1. The most important of all, DO NOT try to start your camera.
2. Loosen the battery cover, remove the battery and put it somewhere to dry.
3. Wipe the camera immediately with a paper towel or anything that absorbs water well.
4. Use a powerful vacuum to absorb the water droplets which you can't reach with a towel (such as those inside the case).
5. Put the battery and the camera in a bowl of uncooked rice by covering it completely. The rice absorbs the moisture from the air very well so that it will help drying your camera. Keep it there for 24 hours or so.
I hope it helps!
If you have any other questions, please leave a reply!
Thank you for using FixYa.
Tip by hiddenul.
May 30, 2011 | Nikon D50 Digital Camera
Transferred pics from computer to card and the camera will not display them - all are jpeg just like what the camera takes. These were from the camera but I wanted them back on the card also.
once out of the camera & deleted form the card, the camera will not display any of the images because it does not have that function. even jpeg images being the same format cannot be viewed.
Apr 21, 2010 | Kodak EasyShare One Digital Camera
Camera doesnt work, got as a gift about 6 months ago and took out
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. This camera has an auto lens. Which means it will focus automatically every second, which makes this clicking sound. You can turn this option off: 1: Go into the menu 2: Chose option Cam Settings 3: Switch AUTO focus to single lens and click OK.
Jan 07, 2010 | Kodak EASYSHARE M1063 Digital Camera
Will not turn on
Try cleaning the connection, scrubbing at where the battery connects with a wire brush to get rid of corrosion & make sure of a tight connection.
Jan 01, 2009 | Olympus SuperZoom 115 QD 35mm Point and...
My samsung wont turn on
It's not the camera. Are your batteries suggested for digital camera use? Have you checked the expiry date? this camera is quite the battery ****- even if your batteries show up as fully charged, a lot of brand's don't have enough power to support this camera, so MAKE sure you buy good batteries.
Jun 30, 2008 | Samsung Digimax S630 Digital Camera
Vivicam 8400
I have a ViviCam 8400 and have the same problem UNLESS I buy Duracell Power Pix or Energizer Titanium batteries. These cost more than the regular grade AA batteries, but when I used brand new regular batteries, the camera would turn on for 2 seconds then turn right off. Titanium or Power Pix batteries make the camera work fine. And, because they are made for digital media, they do allow you to use the camera for longer periods of time.
Jun 09, 2008 | Vivitar ViviCam 8400 Digital Camera
Camera will not come on
I just had the same problem though I replaced the btteries for new ones and it worked...
Jan 02, 2008 | Nikon Coolpix 5600 Digital Camera
Pictures mysteriously deleted
Are you sure the pics aren't in a separate folder?
Nov 27, 2006 | Panasonic Lumix DMC-LZ3 Digital Camera
Fuji FinePix A600 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
