Question about Pioneer AVIC-D2 In-dash Car Audio Stereo CD player with navigation and 6.5" video screen - Free UPS ... Car Video Player
Pioneer car stereo-how to hook up speaker wires
I'm trying to install a used Pioneer car stereo in a 99 Suburban-the Sub.s wiring harness has 8 speaker wires(2 per speaker?)and the radio just has 4 speaker wires-how do I go about hooking this up?Also theres a wire on the radio marked to be controlled by ignition switch(another wire is marked to be hot all the time)-on the ignition switch wire there was a little 3/8 ? long component soldered in and one end of the wire broke off it-do I need this?Whats it for?maybe I can get a soldering iron and reconnect it.I suppose this wire is needed?Thanks for the help.
Which wires are the speaker wires on a Pioneer DEH 1700 Auto Stero with CD player
Posted on Feb 04, 2010
  • 7 Answers
Ok u have 8 wires because the other wire is just a ground.as long as u ground the other wires u should be fine. ok the wire that is marked ign. wire may be your mem.wich usally hooks to an orange wire the hot wire u have is just what it says hot that comp. at the end i blieve was a fuse .it sounds like the other part is missing.
Posted on Apr 25, 2009
  • bharvey92 Apr 25, 2009
    yes it would be a good idea 2 reco. it the fuse that is
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
Is there anyone who can answer a question re color codes for matching wires from harness to stereo i have a pioneer stereo and and need to install it in a honda civic need to match its wire colors to...
hoy cr*p. Thats a big question. I'm used to the simple hook up of red = hot wire, black equal ground wire, and white usually goes to the speakers. MOST electronic equipment use red as the "hot wire"...or the wire that is the main electrical wire. If your colors dont match, you might talk to a shop that specializes in installing car stereos. Good luck. thats how they make their money, but depending on the price you may decide not to mess with it yourself. Just label the wires with tape when you find out.
Nov 06, 2017 | Pioneer Car CD Receiver, DEH-16
I wont the speakers hooked to the cd player no the amp
check were the speakers are installed for pre existing wiring they probly left it there.. if not then you will have to run speaker wire from your stereo wiring harness to your speakers. if the speakers were hooked up to the amp then the wire in the harness should be vacant and you can use it if all the wires are connected then that means that you just have to find were that wire leads and hook your speakers up to it.
Jun 03, 2010 | Pioneer DEH-P6400 CD Player
I have a 99 GMC suburban. I just replaced the AC
Find a blue wire on the wire harness to the truck and connect from the blue white on the radio. this will turn on the factory amp that runs the rear door speakers
Feb 08, 2010 | Car Audio & Video
How to hook up the pioneer stereo to wire harness?
Not real clear on question, but you can buy a direct fit wire harness and the wires are color coded so you don't have to cut and splice your wires on your factory harness.The harness hooks to your factory plug and you wire it to your pioneer stereo wires. Harness is about 7.99 up at most stores.
Nov 03, 2009 | Boss RT-6CK Car Component System
Pioneer dehp3100ub.stock speakers wont work with unit?
If the vehicle has a premium sound package - you need to use the remote wire to turn on the factiry amplifier.
If you want to use the power from the radio for the speakers, you must buy and install a factory amplifier bypass harness.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 19, 2009 | Pioneer DEH-P3600 CD Player
Rear door speakers don't work w/ aftermarket radio in 94 suburban
You need to attach the blue wire on the stereo harness to the blue and white wire on the car adapter harness. they installed a small amplifier to power the rear door speakers and unless you connect those two wires then the speakers will not work.
Jan 05, 2009 | 1994 Chevrolet Suburban
Pioneer car stereo instalation
if they are all positive speaker wires then each speaker will get a positive and the other speaker wire goes to the ground of the ground wire
Oct 12, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Need to hook up a 200 pioneer stereo with wire harness from 96 honda accord to the wiring on a 64 impala
you'll need a small 12 v lamp to figure out which one has the power terminals. after mapping that out you need to find a small battery and hook it up to a pair of wires to figure out to which speaker the wires go to.
note : new car radios don't use the chassis ground as common (negative).. the head unit has a negative and positive wire for EACH speaker.
Mar 13, 2008 | Pioneer DEH-P6800MP CD Player
Pioneer AVIC-D2 In-dash Car Audio Stereo CD player with navigation and 6.5" video screen - Free UPS ... Car Video Player Logo
997 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
