Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Not sucking out air when door closes anymore
I don't hear the sucking sound when the door closes anymore.  I also have frost forming at the top of the freezer.   Will a bad/old seal cause it to not **** air anymore?
    Genius:
  • 1,122 Answers
Run your hand around the freezer gasket with the freezer closed slowly and see if you feel any cold air,also check corners they leak to,frost is caused by warm air getting into the freezer or the defrost system is failing,let me know what you find-mike
Posted on Oct 01, 2008
Door was left very slightly open. reclosed but so...
This is normal when compressor starts u can hear some gurgling from evap. from feron flowing. If you hear gurgling only when you close the door it's water in drain pan when you close the door air is forced down drain tube blowing air into water.
May 17, 2010 | Freezers
Ice if forming along top gasket area and side of freezer where
If we have ice on the inside of the freezer it means air is being pulled into the box somewhere. The most likely place is the door seal, it sounds like you already checked it, but I would suggest that you look very close at the bottom and aides of the seal too, it could be leaking in air from there. Check the inside liner for cracks and seal them if you find any. Look at the corners of the cabinet to make sure there is not room for air to come in.
Air leaks will lead to frost, it is just hard sometimes to find where it is leaking in.
Apr 13, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frost forming on top of inside door by hinge
you probably have an air leak. if the gasket is bad it needs to be replaced. Air could also be coming in through the door flap if you have water and ice dispensor on door
Sep 17, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Hissing
not to worry the warm air gets in when you open door then it cools and makes a vacuum and sucks air in...thumbs up
Aug 09, 2009 | Frost Freezer WCWO F15WA FREE - POCKET...
Small patch of ice if frost free freezer
Frost free does not mean no frost ever anywhere. It just means that there is a mechanism to defrost the evaporator on a regular basis. If there is a spot where frost is forming in the box it may just mean that a little bit of moisture that is not collected on the coil may be finding another cold spot to stick. The area where the fan blows into the cabinet is bound to be the coldest spot in the freezer therefore an ideal place to collect frost. Check the level of the unit and your door gasket to be sure the door is closing tight and true.
Jun 28, 2009 | Whirlpool 25.3 cu. ft. / 716 liter Upright...
Reply - thanks
check the way that your loading the door anf make sure that the unit slighly leans towads the back.
Dec 27, 2008 | Freezers
House was on fire now freezer dosen't keep the cool in at the top
your door gasket is letting in air which makes ice or frost to form ,,, the best is to replace the gasket but you may try to level your freezer with it leaning a little to the back to help it **** the door close ,,,
Nov 25, 2008 | Frigidaire Freezers
Frigidaire frostlfree upright freezer ice forming top interior door
Not sealing. warm air hitting cold air causing frost. also, door frame heater may not be working. most frames are "warm" to the touch. normally called an "anti sweat" heater.
Jul 15, 2008 | Freezers
Upright Freezer self defrosting
THE (SUCKING AIR) OCCURS WHEN THE TEMP IS VERY LOW IN THE FREEZER AND YOU LET WARM AIR IN BY OPENING THE DOOR. WHEN THE DOOR IS CLOSED, THE WARM AIR IS COOLED CAUSING A VACUUM IN THE FREEZER. IF THE DOOR SEAL HAS A LEAK AROUND IT, THE SUCKING SOUND WILL NOT TAKE PLACE. CHECK THE DOOR SEAL FOR A GAP AT ONE OF THE CORNERS OR ALONG THE SIDES,BACK, BOTTOM, OR TOP.IF THE SEAL IS O.K., HOW IS THE TEMP? IF THE TEMP SEEMS WARM, YOU MAY NEED TO CHECK THE SEALED SYSTEM. LOOK AT THE FROST PATTERN ON THE EVAPORATOR. IS IT COMPLETE AND UNIFORM? IS ONLY PART OF THE EVAPORATOR FROSTED BACK? IF THE ENTIRE EVAPORATOR IS FROSTED BACK UNIFORMLY, THE SEALED SYSTEM IS O.K.
Apr 01, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Door seal
If the door was left open you may have frozen the evaporator (on a frost free). I would suggest defrosting it as soon as possible and make sure the door doesnt get left open again. If it is not frost free it may just be that it is still trying to recover the temp it had lost by an open door. Hope this helps.
Aug 09, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezers Logo
494 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
