Question about Pioneer DEH-P3600 CD Player
DEH-P360 won't output to Sub
Still trying to make my sub work with my DEH-P360 deck. How do I switch the R-SP function to P/O :S/W from P/O :FUL? The manual says to press the Function button repeatedly but that doesn't work.
Hold function while radio off showing only the time
Posted on Jan 25, 2009
Were is the sub woofer tie into at.
You should have two (or more) RCA plugs on the back of the deck that will act as pre-amp outputs for subwoofer and speakers.
Failing that, your wiring harness should have come with a wiring diagram that will let you know which is the subwoofer output.
Failint THAT, the deck itself should have a wiring diagram on the bottom or side telling your which wire is which.
And if that fails, Your deck may not have a subwoofer output. Just attach your sub to the amp pre-out like everyone else.
May 11, 2011 | Pioneer DEH-2400F CD Player
Pioneer DEH-1900MP how do i enablethe subs
There is no sub preamp output on this head unit.
Jan 07, 2010 | Pioneer DEH-1900MP CD Player
I got the same problem since thair is no sub out for this deck
Hello livinglifeas,
You can connect the regular preamp outputs to a sub amp. Dedicated sub outputs will normally have a built-in crossover whereas the regular front/rear preamp outs will be full-range. Just make sure that the amp you use for your sub(s) has a "low pass" filter.
Hope this helps.
Jun 16, 2009 | Dual XDMR7710 CD Player
DEH-p5500mp will not fade F to R
Hello ryan_4run,
The "non-fading" output may be turned ON or the rear output may be set to R-SP:S/W or both.
Press AUDIO repeatedly until NOFAD:ON appears in the display. Press DOWN button to turn non-fading output OFF. Also make sure that the setting for the rear output is set to R-SP:FUL and not to R-SP:S/W.
Hope this helps.
Jun 02, 2009 | Pioneer DEH-P5500MP CD Player
Pioneer DEH-P3000IB... Hook up RCA cables to 2, 2 channel amps for front and rear control. Supposed to be able to set rear to either rear full or sub... can't find how and all I'm getting is sub response.
Here are the directions according to the manual:
1 Use MULTI-CONTROL to select
SW CONTROL.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
you wish to set.
Press MULTI-CONTROL repeatedly to switch
the segment in the following order:
REAR SP (rear speaker setting)—PREOUT
(RCA output setting)
4 Use MULTI-CONTROL to select the desired
setting.
Turn to change the setting.
When REAR SP (rear speaker setting) is selected.
REAR SP:SUB W(subwoofer)—REAR SP:FULL
(full-range speaker)
When PREOUT (RCA output setting) is selected.
PREOUT:SUB W (subwoofer)—PREOUT:REAR
# When no subwoofer is connected to the rear
output, select REAR SP:FULL.
Hope this helps.
Oct 13, 2008 | Pioneer Audio Players & Recorders
DEH-P360 Won't output to rear channels/Sub
Make sure that the FIE (front image enhancement) is off. If it is on, the rear outputs are muted.
Oct 01, 2008 | Pioneer DEH-P3600 CD Player
Amp
I think it's a bad switch
Jul 07, 2007 | Pyle Blue Wave PLA2740 Car Audio Amplifier
RCA Problem
You need an active subwoofer input in your amplifier.Which amplifier you are using? Only latest pioneer amplifiers has active sub input and sub output which can be connected to subwoofer.If you dont have active input then you will have to connect it the way you did in old player.
Feb 10, 2007 | Pioneer DEH-1800 CD Player
Pioneer DEH-P3600 CD Player Logo
165 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
