Kenwood RXD 501
my problem is with supply transformer in my Hi-Fi stereo system Kenwood
RXD 501. This supply transformer have defective primary winding and I need know secondary voltage in this supply transformer.
Into Czech republic is impossible buy new supply transformer.
I want make new supply transformer or I need know the adress where is
possible buy this new supply transformer.
Thank you for your answer and I am sorry for my English.
  • kaulik Oct 02, 2008
    Thank you for your answer, but I am radio fan and I know that a primary winding is broken.
    Measurement resistance of the primary winding is no one (behind thermal fuse).
    I need know lewels of electric tension secondary windings or schematic diagram this Audio system.
    Thank you.
    Genius:
  • 1,550 Answers
Do you already check the thermal fuse on the primary side of the transformer
Posted on Oct 01, 2008
What is the resistance of the primary winding?
Hi I just checked the primary winding on two transformers for u one was 13 ohm the other 21 ohm for 240 volt power supply Sounds like u have a shorted turn on the primary winding. Hope this helps
Dec 09, 2015 | Yamaha RX-V2700 Receiver
Home stereo Phillip 708/37 is not getting power.i was told that I need to replace the transformer.cam you advise me how?
maybe not, are the fuses ok ? check fuses, make sure they are ok, also some transformers has a thermistor in between the winding of the transformer in series with the primary winding. Phillip do make their transformers with that kind of protection, just in case the transformer over heat it shuts down. examine the transformer look for the thermistor it is open.
Apr 07, 2014 | Audio Players & Recorders
Kenwood Hi-fi component RXD-M1MD is not working
I have kenwood rxd m1md . it was on and it got extra voltage. now its not working.
the current condition is now when I turn it on, the display turned on for 2/3 seconds and then it shuts down. few green -------------- dots blinks starts, some times "auto power control on " also displays.
Please tell me what happend to this unit? which IC or part have to change?
Thank You
Jun 13, 2012 | Audio Players & Recorders
Kenwood RXD-G2 clock setting
My kenwood is not a car system but it is
KENWOOD entertainment system
RXD-G2
Turn power on at wall
Clock is flashing
Press clock
Press memory
Hour flashes
Press up/down to set Hour
Press memory
minute flashes
Press up/down to set minute
Press memory
Press power on buton
Feb 13, 2012 | Car Audio & Video
Hi,i just change the flyback of my sony KV-21JSR1 ,but still it's not working,it has sound(audio volume is working)but no raster,the flyback that i bought is only generic,because originals are not...
Hello
Have you a digital multimter that can count frequency. if so the testing will be easier to you. Just count the requency at the collector point of horizontal driver transistor, or at the base of horizontal output transistor. it should come around 15.625KHz [15625Hz]. When the tv wors with no signal this frequency may differ, but come very near to it. When it synchronises with a picture, it won't vary and will remain constant.
If you have no frequency counter, just measure the voltage at the collector of horizontal driver transistor. It will be normally connected to the primary winding of the line drive transformer, which is very small transformer on the PCB. Then check the voltage at the other end of that trnsformer, where supply to the collector of the above said trasistor is given. The voltage at the collector side of the winding and at the other side of the winding must have some difference, if the frequency said above is present, and drive transistor is working.
If there is no voltage, check the resistor connected to that winding to main power supply for open, or the capacitor fitted to that point to negative for short,,, or check the continuity of the driver trasformer primary winding itself, or a short between its primary and secondary windings.
If all of there are ok, and still LOT doesn't works, check the supply voltage to lot. Being a 21" TV, its LOT supply voltage comes upto 125VDC or so. If it is also there, try replacing the horizontal output transistor. It also doesn't help, the Line Output Transformer you have replaced is not the exact match. Sony EHT transformers are critical in construction and in winding. Keep it in mind, and buy an another. If you need any assistance freom me, don't hesitate, ask me through Fixya. OK.
Nov 05, 2010 | Sony Televison & Video
Kenwood rxd-355
It's a safety measure by design to avoiding overloading your stereo system.
May 31, 2010 | Kenwood Audio Players & Recorders
Kenwood KA-880D Amp keeps blowing the 6v 250w fuse
please check the VDR in primary supply side.its directly connect to bouth N&Live wire connections of supply.
nuwan.
Jan 11, 2009 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Kenwood UD-551M hi-fi stereo ...problem
power problem of power amplifier .
if you can open the cover we can give try to solve this problem.
nuwan
Sep 02, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Users manuals
Here is the manual for free(downloadable)
CLICK HERE
Feel free to leave a Fixya rating if this helped, and thank you for stopping by Fixya!
Jul 10, 2008 | Kenwood XD-A55 CD Shelf System
348 people viewed this question
 Grubhead
Grubhead
