Fitting new screen medion mim 2120 laptop
Hi has anyone tackled fitting a replacement screen on a medion mim 2120 laptop mine has been broken and i would like any help or advice how to tackle this is it a big task ? any help would be appreciated thank you jake
  • jakeycakey Oct 02, 2008
    my thanks to joed911 for the help supplied i appreciate it, you have given me the confidence i needed
    to tackle this task .....thankyou again best wishes jakeycakey 10/10 for quick reply
    joe you are a star thankyou....jake
  • 4,338 Answers
I could not find a breakdown for you laptop. But from a picture I saw on the web, I could tell you that it is probably the same as most laptop. First, there are screws under the round inserts. You need to pry those up and stick the aside ,in order to put them back when you finish.
Then remove the screws, usually 4 on each corner of the screen. Some laptops have 2 screws on top of the screen near the latch.
Then you need to pry the front bezel off the screen. You can use a small straight screw driver. Carefully (as not to scratch the case) insert the screw driver and pry the bezel away from the back casing of the LCD.
Once you have the bezel off you will see the screws that hold the actual LCD screen in, remove them and lift the LCD out. You will have to un-hook the cable from the System board to get the screen completely out. Then install the new screen.
Please remember to rate all users who assist you for free :)
Posted on Oct 01, 2008
  • JDTec
    JDTec Oct 02, 2008
    Glad to be of service!
    Joe
My Medion MIM 2300 Notebook PC MD 96648 is
Your best bet is to hope it goes up in flames then you can claim off your insurance, the problem can't be fixed.
I have the same machine but with mine it got hot and the graphics processor has burnt out, it seems to be common with this model.
I can't even connect to an external monitor as everything to do with the VGA is fried and Medion support are useless.
I'll never buy a Medion again even though my previous two going back 8 years still work if somewhat slow.
Dec 30, 2009 | Computers & Internet
My power lights keep going from red and green then they go off altogether. i have to fiddle around for a bit before the power comes back on mim 2120 medion laptop
Could be three things causing this. First, the DC jack soldered on the motherboard could be loose. Over time the solder will crack loose. Most likely this is the problem. Second, the AC adapter could be going bad. Finally, the battery could be going bad. Each of these items should be checked.
Nov 17, 2009 | Computers & Internet
Medion mim 2120 laptop
Hi
First i reccomend checking the power cable and seeing if there are no short circuits or breaks in the circuit. - to do this unscrew the end of the power cable - this part wares out often and costs about 50 cents to replace.
Hope i could help
CBZ
Comment if you need more assistance
Apr 27, 2009 | Medion md40298 Notebook
Wireless connection problem with Medion MIM 2120
hi..go and try to find the (Control Panel) then double click the icon of name is (Network Connections) then find the wireless LAN connection..if you have wireless connection u need configuration..if not no have wireless connection you need re-install the LAN card driver..Thanks and good luck..^_^
Feb 01, 2009 | Medion md40298 Notebook
Medion 2120 stuck on f2 screen
put the cmos battery back in and before you turn it on press and hold down the f2 key should send you to bios where you will have to reset all funcation becase you removed the battery
Dec 11, 2008 | Computers & Internet
I have a medion mim 2310 notebook laptop and the problem is that when i plug in the charger it short circuits and switches off,anyone got any idea what the possible cause may be as i dont fancy replacing...
dejay .
if you have a light for charging then have you checked if the ddr memory cards are ok just take one of some one to try you may get it solted if the memory is no good,wrong or damadge then replacing the memory card will solve your problem !
Nov 09, 2008 | Computers & Internet
Medion mim 2130 Laptop
Its not good idea to but your computer on fire, but i hope you didn't use real fire ;)
Sounds like some of your buttons are stuck on keyboard and need some cleaning.
Sep 01, 2008 | Medion md40298 Notebook
Medion mim2080
Usually this is caused by the Compact Fluorescent Tubes that run down the back of the screen, or the inverter that powers them.
If you are really confident, you might be able to but replacement CCFL's and inverters on ebay and install them or you could take the machine to a professional and them do it.
Alternatively if you use your laptop at a desk, you could simply plug it in to a monitor and use it like that.
I hope that helps, if you have any further problems, please add them ass comments to this question. If I have been able to answer your question (or not) please click on one of the ratings buttons to let everyone know how I did.
Thanks for your feedback, and good luck.
Jan 13, 2008 | Medion (40010998)
Medion mim2080 notebook
my sugestion is to leave laptop unpluged from wall and removed battery and leave to cool for 3 days and then check on the fourth day replace battery. and reboot laptop. if problem accures take to be repaired, as the hard disc may have over heated plus comntatcs for hard disc and motherboard this is the only help I can give I leave mine on for 5 -6 days somtimes then turn the thing off to cool down the other addvice is if it works get it a laptop cooler which it sits on and keeps it cool. best of luck on the laptop
Aug 13, 2007 | Medion MD-40954 Notebook
Computers & Internet Logo
361 people viewed this question
David Payne
David Payne
