Question about Mach Speed VENOM V2DP Motherboard
SATA Hard Drives
  • How do I install a SATA HD in the V2DP 400 motherboard:
There is no slot near my ide connectors to hook the HD cable to.
Posted on Oct 02, 2008
    Genius:
  • 1,913 Answers
Coonnect your sata connection to hdd and aslo its other side to motherbord it is nesar the ide connector.
Posted on Oct 01, 2008
Is it possible to use ID harddisk and SATA harddisk at the same time?
You can indeed mix IDE & SATA drives on a computer. If installing the OS (Operating System) to the IDE HD, you will only need to instruct the BIOS to boot the IDE HD drive first.
If you decide to install an OS on & boot the SATA drive first; you will need to instruct the BIOS to boot the SATA drive first and may need to provide a driver for the SATA controller - if the OS install does not recognize the SATA drive. The driver should have been included on a disk or diskette with the controller (or on the motherboard driver disk if a built-in type controller). You should see a prompt asking "If you need to install a driver.... press F6" (or similar). Press the F6 key and supply the driver disk - and follow the prompts.
Nov 24, 2011 | ASUS K8V-MX Motherboard
What type or brand of hard drive do I have to get to install in Acer AM5641 Desktop ? I want to upgrade to a 1 tb hd.
You currently have a 320GB 7200-rpm SATA II hard drive, with 8MB cache install on a base package of your make and model of computer. I would recommend a hard drive like Samsung Spinpoint F4EG 2 TB Internal hard drive. You can find it roughly for $70.00 - $90.00 at online stores like amazon, new egg, etc.
I hope this helps.
Jun 30, 2011 | Acer AM5641-B5660A Desktop PC & Monitor...
Will it support Seagate Baracuda 500 GB SATA hard drive?
This board doesn't support the SATA interface hard drives, it only supports the older IDE interface drives
Jan 13, 2011 | AMD ASUS A7N8X-VM/400 Motherboard
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
How much total Hard Disk capasity supported by my motherboard
Since it supports 120GB, it will support any "large" SATA drive, such as 500GB or twice or three times that size.
Sep 20, 2009 | MSI K8MM-V Motherboard
I can detect no SATA' HDD
The ECS PM800-M2 only supports SATA 1.0 hard drives. If you are using a newer SATA 3.0 hard drive, there is a jumper on the hard drive which has to be set to SATA 1.0 in order for the VIA 8237R chipset southbridge (which Is on your ECS PM800-M2) to recognize the newer SATA 3.0 hard drives. This Is applicable to all motherboards with the Viatech PM800 / 8237R chipsets. Note: the location for the SATA 1.0 / 3.0 jumper varies on each brand of hard drives. Also check If SATA Is enabled In the BIOS and select IDE mode.
Apr 23, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
I have a st380011a 80g hard drive
you need diskmgmt.msc if its a slave drive unalocated.. create partition then format it OR .. if its to install windows on it. boot from xp cd . sometimes sata drives need F6 floppy motherboard driver for installation cd to see sata hd through chip of sata on motherboard.
Jul 14, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Where to connect what on motherboard
Very generic questions so lets see if i can answer as best as i can. hard drives and dvd are very similar principles (see below)
hard drives comes in SATA or PATA. If its a SATA then there should be small red connectors that you should plug the HD in on the motherboard while PATA or IDE drivers should have white connectors. They are wider in width of the cable containing about 24 pins. The motherboard would also call out SATA1,SATA2 etc so you know its the SATA plug. Likewise for IDE drives.
Regarding power switches, on most motherboards there should be a set of pins at one corner of the board with tiny little letters pwr next to it. You will need to connect power switch cable from the case to the motherboard.
I highly recommend you read the manual that comes with the motherboard to see where it is located.
good luck
smeags.
Jan 04, 2008 | Computers & Internet
Mach Speed VENOM V2DP Motherboard Logo
63 people viewed this question
Top Mach Speed Computers & Internet Experts
David
David
Abhinandan  Patil
Abhinandan Patil
Iqbal Husain
Iqbal Husain
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
