Question about Samsung Televison & Video
SAMSUNG LCD TV LE19R8.
We have turned it on for the first time but i pressed the on button a couple of times and the plug and play didnt come up. so we tried auto store but it cleared all the channels. what can we do to install the digital channels
My samsung ps-42s5h seems to have a problem with the screen, there is no picture and seems to make a pulseing noise. any ideas?.
Posted on Aug 20, 2009
How do i fix my broken power button on my samsung 40 lcd tv?
You can easially just replace the button assembly with included circuit board just unplug your old and plug in the replacement. They are very inexpensive and you can get them for most models at www.tvrepairworld.com
Jan 10, 2013 | Samsung LN-T4061F 40 in. LCD HDTV
Lost pin for samsung TV LE19R8
Hello
If you did forget the PIN of Samsung LE19R8, do the following.
Press the remote control button in the following sequence, which resets the PIN to [0-0-0-0]:
POWER(Off), MUTE,8,2,4, POWER(On).
This process will set your PIN to initial settings, and you have to set it to new passcode. OK.
Apr 13, 2011 | Samsung TXK2754 27" TV
My samsung ES55 camera wont switch on and its fully charged.
I have a Pink Samsung ES55 and The first time I pressed the power button it turned on. However when i went to turn it on the second time by the power button it didnt work. I tried to charge it again and it didn't work by this time I thought I'd broken it or something but then i pressed the bottom play button in a square/box twice and it came on I was so seriously relived. :) hope I helped
Feb 01, 2010 | Cameras
While trying to tune in my le32r7 tv..I find that I can't select the tuning option as the cursor keeps by passing it..What can TI do?
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Sep 30, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Trying to retune my samsung le19r8 in booklet itsays select set up then press enter button then again to select plug and play. on my set up menu plug and play is not highlighted cursor will not go there
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Retuning digital TV
You need to use the (what looks like a large sattellite) button to retune your tv.
Some Samsung tv's let you access the button but other models have a "D MENU" button on the remote. Press this button, then scroll down to the icon that looks like a large sattellite. Then scroll across and click on "Auto Store" this will then go through all the available channels
Mar 26, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung YP-U3 mp3 won't turn on!! help please
try pressing the menu button and the play button at the same time
Jan 13, 2009 | Samsung YP-U3 MP3 Player
Samsung lcd tv
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 07, 2008 | Samsung LN-S2651D 26 in. LCD Television
PS3 & Samsung LCD TV
mabey its the tv try to if u still have a white ps3 manual book look and if u can stil see the screen check all the settings i also have a samsung but all was good if its flat and has the av2 option put the ps3 on that option thats how i have mine and if u can help wit this i have a 80 gig and once im done wit playing bacwards compatibilty it gets stuck on the please wait and it starts to freeze
Jun 01, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
595 people viewed this question
Jerry Greenberg
Jerry Greenberg
