Pls3 laser level got wet. helper opened it up and now 3 of the 4 wires are disconnected and don't know were they go. can someone help?
2 Suggested Answers
  • 225 Answers
SOURCE: i have a pls3 yellow laser and when i've changed
have you got the batteries in right?if it worked before you changed batteries,then the new batteries may have been put in wrong or the new batteries might not be any good.check
Posted on Jun 21, 2009
My new pls5 laser will not light when turned on. It's only 4 months old. Never dropped or even wet. Anyone else have this problem? And can I fix it?
In my experience, on PLS found several times the power button defective after few weeks/months (especially if You work in construction sites ).
The ultimate fix is new power button (not replace the old one!) in a convenient position. I have fix several PLS3:
25648370-ud5esjubpx2k2ouh2wsyjwog-2-0.jpg Notice: if You open your PLS5, You have to break the lateral sticker and the warranty will be void!! Keep this in mind!!
Bye!
Apr 15, 2015 | Pacific Laser Systems PLS-2 Palm Laser,...
I have a proform 650 v threadmil, and the left side of the buttons panel (start button and incline levels) don't work. could someone help me?
1) tight all connector wires and clean
2) tight the ribbon cables from keypads.
3) Run the software calibration for diagnose, and troubleshooting, and fix it.
4) lube the shaft and gear in the elevation motor,
5) adjust the potentiometer for better running see the diagram.
God bless you
Jun 19, 2012 | Proform Exercise & Fitness
My bike fell over now there's a warning light on? How do I fix the problem? It was muddy pressured washed it did I get something wet?
It could be the case that some components got wet, was it pressure washed on the inside as well? Check for the fuses, it could be that one is burnt. Check for oil level. The warning light comes on if its an engine failure, starter failure, sometimes grounding or shorting on the chassis, and oil level.
Also, to be sure nothing's been disconnected due to the power of the pressure wash, i'd recommend taking the flairings (covers) off the bike and manually checking for dangling wires if every anything was disconnected. It may help also to un-plug then replugging the wires connected to the CDI. It could be the case that it got water there as well.
Hope this helps,
levibit
Dec 22, 2010 | 2007 Suzuki GSX-R 750
Air in clutch line. how do you bleed the system?
1. Fill up the clutch reservior with right type and DOT of fluid (Dot 3 or Dot 4)
2. Have someone help pump the clutch paddle.
3. have the helper pump the paddle 5-7 time and hold it down and you open the bleeder and close it before the helper lets off the clutch paddle.
4. Keep repeating the above procedure until you see clear fluid coming out and no air is coming out with the fluid.
Good luck.
Dec 02, 2010 | 1993 Toyota Corolla
I am tiling my bathroom from a full strip out. The walls are plum and level all round but when I use the laserlevel, the line is out when I get back to the start corner. My builder has checked and double...
If I understand which unit this is, it's not sold as a highly accurate instrument (advertised use is for hanging pictures). No numeric specifications were given for it's accuracy. And I don't think it is adjustable. Also, by using the level on each wall progressively you might be accumulating error manually.
You can easily measure the accuracy of your laser level by taking it to a room with one long wall (the bathroom is too small) Hold the laser against the wall at the left end of the room and make a mark nearby. Have a helper make a mark on the wall at the most distant point possible (at the right end of the room) Now put the laser near the mark your helper made at the height aligned with his mark. Now, back at the left end of the room have your helper measure the vertical distance between the laser beam and your first mark. This will measure double the level's error over the length of the wall. However, this test assumes that the beam coming out of the left side and the right side are perfectly co-linear. .
Aug 06, 2010 | Garden
HOW TO BLEED THE CLUTCH?
Have someone hold the pedal down. Open the bleeder. Then close the bleeder. Have your helper pump the pedal. Then hold it down. Repeat this about 3-4 times. Make sure the fluid level is full while bleeding.
Apr 24, 2010 | 2001 Chevrolet S-10
Car heat takes 10 to 15 minutes on a 2005 dodge
could be clogged up heater core or the heating helper element ..if you look for the heater air box you should see a 3 wire plug with i believe its 2 screws on it remove it and start the car and have someone hold it {not the coil wire ends and turn on the heat it should glow red hot this is the heater coil helper you may also have insufficient antifreeze remove radiator cap and check fluid levels also while your there feel the top and bottom hose to see if they both get hot and that you feel water in them but 1st ensure the radiator is full if just the top hose going into the heater-core to the firewall is hot and the bottom one is cold you should have a radiator flush to dislodge the Gunk buildup in the heater core .
Dec 07, 2009 | 2005 Dodge Grand Caravan
I need step by step instructions on how to bleed brakes on my 2005 toyota celica
If you don't have someone to help you you'll need to get a one man brake bleeding kit. The bleeding kit will take the place of the helper. IF you have a helper start with the rear passenger side wheel (furthest from master cylinder). Remove the wheel, have a helper sit in the vehicle and pump the brakes several times (motor off). Tell them to hold the pedal down while you open the bleeder screw. Tighten the bleeder screw before the helper releases the brake pedal to avoid sucking air back into the line. Repeat this process until the fluid flows out of the bleeder with no air. Then repeat these steps on each wheel. The order of bleeding is always furthest from the master cylinder. Rear passenger, rear driver, front passenger, and lastly front driver. After each wheel is done check the fluid level in the master cylinder and add as necessary. You don't want it to get low and **** air in from the cylinder.
Nov 06, 2009 | 2002 Toyota Celica
I have a pls3 yellow laser and when i've changed the batteries it is completely dead
Mar 15, 2009 | Pacific Laser Systems Pls 20309 Tripod For...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
