Question about Oreck XL21 Bagged Upright Vacuum
Clear oreck schematic
How can I get a clear picture or at least an explanation of which wire to which terminal. 2 terminals opposite each other have black dots and 2 do not. Which are AC in and which 2 are 12 volt lights?
  • kevinrntz Oct 03, 2008
    The 2 terminals with the black dots were the A/C line in. Thanks Reddevil6!
  • SJCobb Jan 04, 2009
    Please email the wiring diagram for the Oreck XL 9100 series to sjcobb@aol.com.
    Thanks
    President:
  • 1,673 Answers
Here is Oreck's motor wiring diagram, if it isn't big enough to make out, give me your email addy and I will send it to you.
Posted on Oct 02, 2008
  • 2 more comments
  • bdafni
    bdafni Apr 29, 2012
    Please email me the wiring diagram for the Oreck XL motor. Much appreciated!
    bdafni@yahoo.com
  • paul stanley
    paul stanley May 22, 2014
    I was wondering if you could send this diagram to me too? ryandude13@yahoo.com Thanks!
  • Felix Pichardo Jr. Jun 14, 2014
    Could you please send me the diagram as well. I would really appreciate it. Email address is pichardo554@gmail.com. Thanks
  • Dax Marshall
    Dax Marshall Jul 22, 2014
    I need it tp daxter199857@gmail.com
HOW DO I HOOK UP THE WIRES TO THE MOTOR I FORGOT
You should only have 4 wires to hook up to an Oreck motor. The black wire from the cord coming into the back of the motor housing will be attached to the closest lead when the motor is in it's normal position. Most of the time there will be a black dot next to the terminal. On the other side of the motor you should have two white wires that should be connected together, one from the same cord just mentioned and the other one coming from your lights. Those two wires should also be connected to the motor where there is a black dot beside the terminal. Your last black wire coming from the lights should go to the terminal next to where the white wires are connected or to another terminal that is on that side of the motor. Hope this helps!
Mar 14, 2015 | Oreck Single Speed Handle Assembly - White...
How do I wire an oreck xl9100 motor
The black wire coming from the power cord will go onto the terminal closest to where the cord goes into the vacuum. Sometimes there is a black dot next to the terminal. The white wire from the cord will attach to a piggy-back terminal on the white wire coming from the lights and will attach to the motor on the other side of the motor from where the black wire attached. There may also be a black dot beside that terminal as well. The black wire from the lights will attach to a terminal on the side where you attach the white wires, either right next to them or above them on the same side of the motor. Hope this helps you.
Sep 06, 2014 | Oreck Lamp Housing with Reflector XL9100...
I need a good wiring diagram for my Oreck xl vac
Chuck,
I do not have a diagram for you but I can tell you how they normally are hooked up. When you have the motor sitting in it's normal position the black wire from the power cord will attach to the terminal closest to where the cord comes in. There should also be a black dot next to the terminal. The two white wires will connect together and they will go on a terminal on the other side of the motor that also has a black dot next to it. The remaining black wire should connect to a terminal next to the white wires or at least on the same side of the motor as the white wires. Hope this helps you.
Apr 12, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Oreck U4148 motor wiring
Pat, I do not have a diagram for you but I can tell you how they normally are hooked up. When you have the motor sitting in it's normal position the black wire from the power cord will attach to the terminal closest to where the cord comes in. There should also be a black dot next to the terminal. The two white wires will connect together and they will go on a terminal on the other side of the motor that also has a black dot next to it. The remaining black wire should connect to a terminal next to the white wires or at least on the same side of the motor as the white wires. Hope this helps you.
Mar 09, 2014 | Oreck XL2600 Vacuum
Ametek wiring diagram for a Oreck XL21 600 ECB
I cannot find a wiring diagram from where I am located right now, but I do know that the black wire coming from the power cord goes to the top side of the motor when you have it laying upside down with the cover off, and it will go to the tab towards the back of the vacuum. Sometimes they put a black dot beside the tab and if that is there you put your wires from the power cord on those. You will also have two wires coming from your light bar in front and the white wire will usually have a piggy-back terminal that your white wire from the power cord attaches to as well. If there are no black dots beside the terminal tabs the white wires will connect to the bottom terminal on the opposite side from the black power cord wire. It will usually be on the lower side of the motor as well. The black wire from the light bar will go on the remaining terminal tab as there is usually only three tabs on the motor. I will check back later this week to see if this has helped you and if not I should be able to get a diagram this weekend.
Sep 22, 2013 | Oreck Vacuums
Need wiring schematic for ametek 119550
I had the same problem after not paying attention to the connections when replacing my motor. I spent days searching for information and only found several non-answers with small photos that no one can read.I contacted Oreck for wiring information. They explicitly stated that they can't provide any wiring information for safety and liability reasons.
I found the Ametek schematic which shows the LINE and TAP locations on the motor.
Note: I have a 2600HH XL with 2 headlights.
Connect as follows:
3A, LINE: White lead w/piggy back terminal from light harness #1 & white lead from the power harness to the piggy back terminal
2A, TAP: Black lead from light harness #1
3B, LINE: White lead w/piggy back terminal from light harness #2 & black lead from the power harness
2B, TAP: Black lead from light harness #2
Dec 13, 2012 | Vacuums
Model Oreck 2600HH- need schematic
white to motor terminal,black to other motor terminal,green is always ground to housing there is a small terminal tucked away its s small spot for the lights
Feb 01, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Henry's motor burnt out
You should have 3 wires one of them are green . gr. is the ground . the other 2 are interchangable. good luck DFD
Aug 07, 2008 | Henry Numatic "" Canister Vacuum
Wiring Schematices
Connect as follows:
Mar 31, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL21 Bagged Upright Vacuum Logo
1,944 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
