Question about Sharp UX B700 Plain Paper Inkjet Fax
Blank pages All copies and faxes are coming out blank. I know the paper is being placed in the sending machine correctly - I tested it from another fax here in the office. Ink is fine. This is a new problem today. The fax has worked fine for several years. Any ideas?
  • dlcamacho Oct 02, 2008
    I'm almost too embarrassed to tell you what happened...... I removed the cartridge to clean it as you suggested and realized that WHOEVER (I swear, it wasn't me) changed the cartridge last time didn't remove the tape. Of course, no one around here will admit to it. I'm just happy we're back up and running. We depend on this little machine as our back up to our expensive always-breaking-down printer/copier/fax machine. Thanks so much for your help.
Remove the cartridge and using a damp cloth wipe the ink openings...this might fix the issue.
Posted on Oct 02, 2008
Why won't it print test page?
If the test page placed face down on the glass does not contain text, you will get blank copies.
Jan 08, 2016 | Office Equipment & Supplies
Can send faxes but not receiving, comes thru blank piece of paper
What about copies or internal prints?
If even a copy doesn't work then it sounds like your LASER unit has gone out, in which case I'd just replace the machine.
If the internal pages or copies come out but not faxes, and you know the sender is sending correctly, then it could be an issue with the main board.
I'd get a second opinion from a service tech locally but I can at least give you the part numbers for both so you have an idea of the cost of parts.
LASER UNIT
LM4578001
MAIN BOARD
LG6141001
Jun 13, 2011 | Brother IntelliFax-2820 Laser Fax
Fax in memory is full. also the fax i received is blank. I had the sender to send multiple times, and its still blank.
OK...I'll ask a dumb question....have you tried to make a copy on your machine.???? If the pages are still blank, just a thought would be to check that you havn't installed the roll of paper in upside down.
Sep 27, 2010 | Panasonic KX-FHD331 Plain Paper Thermal...
Blank page when I copy or print reports
Re check all the connections. When taking off the paper feed assay, other parts and plug and jack connections were needed to be taken off first.
Make sure the drum seats in its correct position, silver grounds are not bent.
The copy cartridge and Dev housing are not connecting very good somewhere.
Make sure the machine is unplugged.
Try running copies.
Apr 21, 2010 | Xerox WorkCentre Pro 580 Plain Paper Laser...
Faxes coming in print fine but outgoing faxes people are saying are coming out blank on their end
If outgoing faxes are turning up blank on the recipients end, you may be putting the paper to be faxed in backwards. Outgoing faxes should be sent face-down. If you are sending properly, either your scanner is failing (test it by copying a document) or the recipient is having fax issues on their end.
Jun 23, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Fax comes out blank at the receiving fax machine.
This type of fax is "toy" buy a laser fax an get rid of all your problems
May 26, 2009 | Canon FAX-JX200
TX problem
If I understand you right, what you send, people are receiving blank sheets?
When you try to run a copy are those blank also?
If so your problem is with the scanner. The drum should have nothing to do with sent faxes.
Unless your putting the paper in the scanner upside down. And if you ran it enough to need a drum I can't imagine that .
May 15, 2008 | Xerox FaxCentre F116 Plain Paper Laser
Problem with Sharp FO-1460
What happens when you make a copy?
If that is blank, you have a bad scanner.
Jan 09, 2008 | Sharp FO 1460 Plain Paper Thermal transfer...
Sharp UX B700 Plain Paper Inkjet Fax Logo
156 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
