Aiwa F2000 20" TV
Problem for Aiwa F2000 20" TV
Can the "tuner" be replaced?
By Cornish - usenet poster
The stem that the cable line goes into (think it is called a tuner} my tv seems to be cracked. It wiggles and the picture jumps around. Can this be replaced? It looks like it is part of the board.
Thanks
Best Solution
posted on May 30, 2006
Helpful)
Jimmy NY
Rank: Apprentice
Rating: 0%, 0 votes
If your TV set is sony, and your problem is tuning problem. Then you can try to take out the Tuner to solder the gound area.(inside the tuner. I found some Sony TV tuner cold solder cause tuning problem.
The other way is using your VCR to instead of you T
Was this helpful?
Yes
No
Solution #2
Not Rated)
Brad
Rank: Apprentice
Rating: 0%, 0 votes
Yes it can be replaced. Yes it is soldered to (should be when not broken anyway) the tuner case and the board inside the tuner.
Was this helpful?
Yes
No
Popular Solutions for Aiwa F2000 20" TV
Questions and Unsolved Problems for Aiwa F2000 20" TV
Do you recommend Aiwa F2000 20" TV?
Answer
Answer
i want code to open setting of aiwa tv modle FS2580SHR Plz Help me in this metter
Answer
phillips 27 inch switches on and has coloured lines running down the picture - not sure what to do?
Answer
my philips 27 inch tv model # 27pt5445/37 has no picture, it started out as purple colors in the... (More)
Answer
The volume level of my Aiwa A2119 is not increasing or decreasing though the volume level displayed... (More)
Answer
i have aiwa tv-A2119.my serviec man says there code that look my tv sound option from remote... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
