Question about Sony Playstation 3 (PS3) Console
Playing blue ray
I need to be told all the correct settings that need to be turned on in the bnmv set up and display settings kids screwed it up was working fine they have messed up settings had green line on bottom of screen and up side of screen managed to get bottom of screen back to normal but still line up the side picture was also split into 2 but thats sorted as well but just guess work!!!!!!! games playing perfect still
    Scholar:
  • 125 Answers
My solution would be to restore the playstion 3 to default settings unless you have files on your ps3 that you do not want to delete forever.
Posted on Oct 02, 2008
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
Playing bluray through xbox one on toshiba TV
Make sure the display resolution is set correct for your TV,
How to change the display resolution for your TV on your Xbox One...
Also make sure the TV is on and set to the correct HDMI input before using the Blu Ray.
It is also possible the TV does not support HDCP, if not, it will not work with the XBOX one Blu Ray. You may be able to use the Component (Red Green and Blue) cable though.
Apr 07, 2014 | Toshiba Televison & Video
I bought this recover and so far everything works but for some reason I cant get any surround sound from the recover running hdmi from blue ray player on the display it shows sw, LF, RF that's all I can...
hi,
you reseiver is now in stereo mod that's why there is no surround and center. its some thing related to to the setting in the receiver or in the blue ray.
Settings in blue ray player
First of all check the audio settings in your blue ray players audio setting.
You didn't mentioned the brand of your blue ray player. Anyway go to its setup and set the audio output priority as HDMI. also turn OFF the DRC if its a sony blue ray player. Also check the down mixing setting make it satandard
Settings in receiver.
First of all check the surround settings.
Play a blue ray disk and press the STANDARD button o the receiver's remote and select STANDARD mode.
If you didn't get the surround channels follow the below procedure
Now go to the setup of your receiver.
1. Using the down arrow go to the Advanced play back and press enter.
2. In the Advanced playback menu select auto surround mode and press enter
3. Select it ON using right arrow or left arrow. and press enter
4. Exit the setup and check is every thing working fine.
If dosn't work
Again go to the setup of the receiver
1. Using down arrow select Speaker setup and press enter
2. In the speaker setup menu select speaker configuration and press enter
3. Check the status of all the speaker, if any speaker is in NONE position , make it LARGE or SMALL according to the speaker you are using.
Exit setup and check again.
If you need any more assistance feel free to contact me through fixya.
regards
Ajin
Feb 05, 2011 | Denon AVR-3806 Receiver
No longer plays color picture
Try the settings for "pal - ntsc - cvbs" video formats, if the tv and dvd aren't set the same, then this can cause the problem(usually with distortion to picture, depending on how it's mis-matched)
Jul 05, 2009 | Coby DVD-224 DVD Player
The Yamaha RX-V463 AV does not playsound from the blue ray player
"I am also having difficulties in try to display the yamaha set up menu on the tv."
According to the manual the display menu for TV will not work with HDMI hook up.
I also have a Panasonic HD TV and can't get TV sound through my Yamaha AVR on "TV Sound" mode.  Trying to use HDMI cable for this also.  Do I need a digital optical cable or do I not have something set right?
Apr 07, 2009 | Yamaha RX-V463 Receiver
I cant get a blue-ray disc to play on my hd tv through my laptop
go to "Windows Mobility" select external display and then set display to external only.
ClintM
Dec 16, 2008 | Acer Aspire 5920-6727 Notebook
My playstation 3 wont play blue ray disc
have you updated your ps3 with the latest firmware and do you have the inputs set correctly in the display settings to correspond with your cables if ur tv is not 1080p make sure you dont have that set either
Sep 16, 2008 | Televison & Video
Tv guardian settings
OK I FOUND IT!!! IT'S 1234, when the parent control screen shows up press the play button then enter 1234 then press play again!!! The movie plays then!
May 08, 2008 | Disney Princess DVD Player
PS3 - green Bar when playing blue ray on my 50" Phillips Plasma
Green bar or border is due to wrong AV Setting. To resolve this just insert the Blue-Ray DVD and begin to play. Press the Triangle button and select "AV Setting", in AV Setting change Video Output to RGB.
Jan 20, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
56 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
