Question about Compaq Computers & Internet
Want to add RAM 1GB to my compac 6400nx but unable to remove the cover how is this done
  • mssuses Oct 02, 2008
    proton77 although the photos did not arrive with the e-mail his most excellent description of my computer side panel explained it all , there was only one screw , black plastic that loosened . and a slight adjustment and off the side panel came. I just wanted to say thank you for the safety tips . A+++++
    Thank You : Mssuses
  • Compaq Master
  • 1,183 Answers
Opening the case
Use the following steps to open the case: WARNING: The edges of metal panels can cut skin. Be careful not to slide skin along any interior metal edge of the computer. CAUTION: This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
  1. Unplug all cables except for the power. Write down each cable location if you do not already know where it connects.
  2. Unplug the power cable and with the power cable removed press the Power button.
  3. Remove the screws on the rear of the desktop (Your PC case may appear different than the images in this document). Figure 1: Example of screws for the side panel want to add RAM  - c00371471.jpg
  4. Slide the side panel off from the rear of the desktop. Figure 2: Removing the side panel
Thanks proton
Posted on Oct 01, 2008
HOW TO UPGRADE RAM ON VAIO VPCM121AX LAPTOP
Memory Upgrade for Sony VAIO VPCM121AX Netbook Laptop, the Sony VAIO VPCM121AX Netbook Laptop takes the PC2-6400 DDR2 SDRAM SODIMM 200pin memory Memory Type, and comes installed with 1GB (Removable) of Memory.
You can upgrade your Sony VAIO VPCM121AX Netbook Laptop to up to a maximum of 2GB Memory, the system has 1 Socket to install Memory, already with 1GB (Removable) standard Memory installed.
For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
Power off the computer, and unplug it from the power source. Close the computer and turn it over.
Slide off the battery cover and remove the battery.
Locate the memory bay and remove the screws in the cover.
Remove your old RAM board(s) by pushing the metal clips and holding it down and outwards until the RAM board pops up. Then pull it out at a 30-degree angle. (If you only need to add more RAM to your existing RAM and you have enough available empty RAM slots, you will not need to remove the RAM.)
5
Insert the new RAM board into an empty slot at a 30-degree angle until you hear it click. Then push it flat down into the slot.
6
Replace the cover and screw it back in.
Upgrade the Sony VAIO Hard Drive
7
Locate the hard drive bay and remove the screws from the cover. Then slide the cover off.
8
Pull the hard drive out of the bay.
9
Remove the screw securing the hard drive with the magnetic screwdriver.
10
Pull the hard drive out of the bay by the black tab connected to it.
11
Re-insert your new hard drive into the bay and replace the cover.
hope it helps
Jul 15, 2012 | HP Pavilion dv7 Keyboard (483275-001)
Attepting to add 1gb ram to my acer aspire 5315. after removing the cover i findwhat seems like a metal covered case underneath.how can i progress further
soloution was already answered on this site ,please try to use search function next time
http://www.fixya.com/support/t483680-acer_5315_aspire
if this helped please vote
Feb 24, 2011 | Acer Aspire 5315 15.4-inch Notebook PC
I have 512 mg of memory. Would there be a big difference if I add a 1 gb stick and keep the 512 mb , as oppose to removing the 512 mb and replace with two 1 gb sticks?
The performance of your laptop will improve if similar memory is placed in each of memory slot.If 1gb memory and 512mb memory are placed in available slot you will only get the performance of a single 1gb memory.but two 1gb memory are used performance will be similar to a 2gb ram or more.
May 30, 2010 | Acer Aspire 3003WLCi Notebook
I have a nec GA-81915PMD Motherboard and would like to add more memory. Please can you advise me as to what is required.
You can either add to empty ram slots or replace them with new matching ram. If you add to the current, get ddr 400 or 333 depending on what's in it & the sticks can't be more than 1gb each,according to the maker. So you can put a total of 4gb in it. If you go with new, get ddr 400 in 1gb sticks up to a max of 4. To install,power the pc down, unplug it,remove the side panel,keeping yourself grounded to the case remove the ram you want to replace or add to the empty slots. Make sure the ram snaps firmly into place. Leaving the cover off, power up the pc to make sure it boots ok. It may shown a warning about the memory change,just press whatever key it says to continue. Once you verify that all is good,replace the side cover,that's it.
May 14, 2010 | Computers & Internet
Is it possible to add 1GB DDR1 RAM 333 MHZ to INTEl D101 GGC
u can use the 1gb ddr1 ram,if the sound is coming then may there is two problem
1.may be the ram is damage
2.your motherboard is not supporting 333mhz bus support
try to find 400mhz ram instead of 333mhz
Feb 27, 2010 | Intel D101GGC Motherboard
Usbs not working. am37 motherboard. Updated to the newest bios that I could find (Bios 3.20). Compaq Presario 6400NX. Im running 1gb of ram.
Remove bios battery and erase new bios (usually a pair of pins to short). If USBs now work - don't upgrade bios! If bios settings have no setting for diabling USB, motherboard failrure seems likely. Try a PCI USB card to provide sockets.
Sep 07, 2009 | FIC AM 37 Motherboard
I want to add RAM to my hp pavilion dv4269us. how do i know how many cards i can add? i want at least 1GB or 2. Is there room for two 1GB cards or room for one 2GB card? What are the best brands? and...
Hi there.
Your system supports 2 GIG (1x GIG each slot)
Have a look here >>>>>>
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=90110
Kingston is one of the best memory modules you can get.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | HP Pavilion dv4000 Notebook
I am unable to play any games on my pc....
Can you please name the game which you were unable to play ?
Apr 01, 2009 | Computers & Internet
1024 RAM
You will need to remove the 2-512MB ram that are installed on your computer and buy 2-1GB sticks. There is no other way around this. Download CPU-Z program to find exact memory module needed before you buy the wrong one. Good luck.
May 19, 2008 | Toshiba Satellite A135-S4527 Notebook
Computers & Internet Logo
80 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
