Question about Panasonic Televison & Video
I have Pnasonic plasma T.V model TH-50PV30. It tends to switch off on its own. Some times it may go on for long time without doing it but at times it switches offin a few minutes , leaving the standby button flashing.
  • jbnadkarni Oct 01, 2008
    I will try this out
    Master:
  • 479 Answers
It may due to the ics getting heated up then its normal temprature.causing the tv to go off.try cold soldering on the main board which sometimes solves the problem, otherwise change the faulty ics
Posted on Oct 01, 2008
  • 57 Answers
You can check the board where the components are mounted and resolder any that look bad. a brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet.
In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace.
If this does not correct the problem, you may need to have your TV serviced.
    Genius:
  • 1,550 Answers
It seems to be power problem in your tv .
You need to check whether the fuse is blown . If so you need to replace it .
Replacing fuse will work at sometimes .
SAM ANDERSON
How do you remove the stand from a panasonic TH-50PV30 50 inch type with 3 levvels of storage shelving. Thanks.
Never owned the this TV, but from what I can tell the outside edges on either side should have a series of screw holes. Even if you can't see the actual screws, there are philips head and there are in the bottom of those 4 or 6 holes. Take those out to get the TV off the stand.
Those may also be covers for a less complex connect to the spot where the additional speakers normal mount. Either way, remove still starts there.
Apr 27, 2011 | Panasonic TH-50PV30 50 in. Plasma...
How to convert from pal bg to pal I in panasonic th50pv30
Specifications for the Panasonic TH50PV30 Plasma. Broadcast Standards, PAL-I.DVB, AV-NTSC:PAL 50/60Hz, NTSC, M-NTSC. Picture size, 42" (106cm) Discontinued Model.
Should work, have a look in the intallation menu for the correct country that you want.
Hope this helps.
Mar 09, 2011 | Panasonic TH-50PV30 50 in. Plasma...
Panasonic Plasma TV won't turn on
my television will not power on at all no lights no anything, Worked fine the day before
May 21, 2010 | Panasonic TH-50PV30 50 in. Plasma...
Picture shut off and now there is a light that blinks 12 times I have the 42 inch plasma
in this situation it means that there is a problem with secondary power supply. check it.
Jul 08, 2009 | Panasonic TH-50PV30 50 in. Plasma...
Hi....my 61 inch nec plasma is turning itself off
Set is going into "PROTECT". Unplug as you'll cause more damage. Get Pro repair ASAP. Around $450.00
Please rate!
Apr 01, 2009 | Panasonic TH-50PV30 50 in. Plasma...
Black bold line on panasonic plasma screen
Hey,
Your problem goes outside of my expertice, I would recommend you ask http://www.fixya.com/users/slinteriors Slinteriors for help, send him the problem, hes one of the best TV experts we have on this website I'm sure he can solve your problem
Thanks,
Ekse
Aug 29, 2008 | Panasonic TH-50PV30 50 in. Plasma...
Panasonic TH-50PV30
Make sure the power supply cable is tightly plug-in, the one in the back of the TV. This fixed my problem.
Jun 06, 2008 | Panasonic TH-50PV30 50 in. Plasma...
Panasonic TH-50PV30
You can check the board where the components are mounted and resolder any that look bad. a brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. all can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced.
Dec 21, 2005 | Panasonic TH-50PV30 50 in. Plasma...
Panasonic Viera 42" TH-42PV30
Check the 2 main interconnection cables (24pin and 26pin) rear of PDP and Tuner box. Make sure they are firmly connected. (Loose connection of 24pin will cause no power on symptom.)
Oct 21, 2005 | Panasonic TH-50PV30 50 in. Plasma...
Televison & Video Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
