Question about Hitachi DV-PF2U DVD Player/VCR
Front of dvd tray broken off -- dvd stuck inside
My son managed to break the front piece off of the dvd tray on this machine. It still has a dvd in it, but it will not load, nor will it open. I would be interested in finding out if this might be fixable, and would at least like to be able to get the dvd out. It is currently sitting there churning, attempting to open.
  • rachelkb Oct 01, 2008
    Thanks! Unfortunately, when I went to try this, I discovered that this DVD tray did not have a hole in the front. :( Eventually, after unplugging the machine and plugging it back in, I got it to open. There was a piece of plastic underneath the DVD in the tray (part of what held the front on), that seems to have been the primary problem. Once I was able to get that out, it now seems to open and load and everything.
    Scholar:
  • 145 Answers
In the front of your dvd tray there is very small hole. Straighten a paper clip and push straight in and it will release the mechanism.
Posted on Oct 01, 2008
I kept a disk in a dvd writer and after sometime it has broken in the writer i have removed the disk tray and removed the broken disk pieces now the tray is not going inside
You need to open the cover of you DVD driver to check if there is some particle left inside the DVD. As there is a possibility that there is something left inside the DVD. If you have idea you can open it and remove everything left inside the DVD.
Apr 26, 2011 | Samsung (SH-S162L/BEBN) DVD RW Burner
Unit on standby mode only, the dvd rack didnt open when open button was pressed.
Turn off and unplug at mains Plug back in and turn on press standby button so power light come son. If pressing open button on player (rather than remote) doesn't work it may be a disk that is not sitting properly in the tray. You could try sliding a very thin blade (preferably something with an insulated handle!) gently in the top of the tray to press the disk downwards whilst gently prising under front edge of the tray with a small screwdriver. If you can manage to press the open button at the same time as doing both these things it may help.
If that fails to solve the problem it may be a broken drive belt or worn cogs in the tray operating mechanism. DVD players are so cheap these days that repair is seldom worth the expense.
Feb 23, 2011 | Philips DVP642 DVD Player
Dvd is stuck inside and drawer will not open
Yes, it was a piece of the addhesive dot that was stuck to the back of the disk. I unplugged the unit (of course), removed the 10 screws holding the cover on the chassis and that exposed the disk in its tray. I could not manually open the tray still, but I was able to remove the tape dot from the disk while it was still in its tray. All is well now.
Dec 02, 2009 | Philips Televison & Video
Coffee leaks out the bottom of the machine once coffee is ground and mixes with the water it seems that it is plugged and the fresh brewed coffee leaks to the bottom of the machine
The black tube that is protruding from the coffee machine is broken or leaking.If you pull out the brewunit,, you may find the broken piece stuck inside of brewunit.
Nov 14, 2009 | Saeco Odea Go
Display flashing Hello and clunking sound from DVD RW. Will not change from Hello nor will it open or close
sounds like you have broken piece moving around on the inside or broken dvd inside my youngest son put a music cd in my dvd player and didnt put it in right and it broke causing player to make clunking sound and door refused to open. The broken cd was found when player was opened up and sorry to say the tray was broken because of it
Aug 09, 2009 | RCA DRC8030N
Jammed tray
try checking the tray for something that jams the tray.
May 27, 2009 | Yamaha DV-C6660 Multi-disc DVD Player
Broken piece from jammed paper tray
what did you break off?????? let me know so i can help you
Dec 29, 2008 | Brother IntelliFax-2480C Fax
CD ROM is jammed-wont open
This has happened to me. Sometimes when I'm in a hurry I'll place a CD or DVD in the tray and start to close it without making sure that the disk is seated flat in the tray. If it's ****-eyed the CD wil shatter when the tray is closed. The only way to remove the pieces inside the CD drive is to take apart the CD drive. Might be easier just to replace the unit. They run from about $25.00 to $75.00. One other note: You can try to open the tray manually by inserting the end of a paper clip into a small hole on the front bezel of the drive.
Oct 17, 2008 | E-Machines emachines (emachinees) CD-ROM...
CARS DVD COMBI DVD STUCK
Your son may have stuck something else in there too!!!--God knows mine did!!!!!! I have stated in here already how 2 access the insides of the unit.Check the questions asked by others and u will find it. If all else fails and you r forced to get it serviced by a professional, you might want 2 prevent this from happening again by removing the "smiley face mouth" piece that is attached to the tray when it opens so that little people or others don't pull it open:) It unsnaps, very easy to do
May 13, 2008 | Disney DTD1363-CAR 13" TV/DVD
DVD stuck/jammed in tray
there may be two screws on the top of the tray that holds the rounded magnet, the one that is placed to hold the disc when spinning, remove it, you can then simply take the disc out.
May 19, 2007 | Pioneer DVR-810H DVD Recorder
Hitachi DV-PF2U DVD Player/VCR Logo
124 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
