Question about Dell Computers & Internet
Windows update hi there I am having problems turning on my microsoft windows update, I cannot enable it from disable status. I think i might have removed it from the control panel, on the (Add or remove program.) can you please help me what can i do about it?
  • gmstar Oct 02, 2008
    Hi I cant seem to run the windows update any suggestions?
I think i deleted the program frm the control panel and if i go on to the site above & try to download it it says mcrosoft update not running.
Posted on Oct 03, 2008
  • 3 Answers
Using Internet Explorer, go to http://windowsupdate.microsoft.com. Follow the instructions you find there.
Posted on Oct 01, 2008
  • James Jensen Oct 03, 2008
    What does it do when you try to run the Windows Update?
Hi. I recently had my keyboard disabled because of sticky keys. I want to turn it back on, so that I can try & enable the wifi. I just looked in the bios, but cannot find the setting to re enable the...
Hi davelarz, these instructions will help you. *Note: "Everything that you do for the Keyboard!" "Can be applied with the same instruction to the Mouse." First, click on the "Start" button. paul7of9_163.jpg In the ["Start Search Window], type: keyboard. Now, Click on the "Keyboard" shortcut. It should appear at the 'top' of the list. paul7of9_164.jpg The "Keyboard Properties" window will open. You can (Test) to see exactly how your keyboard is responding. Select the [Hardware] button. Next, click on the {Properties} button. paul7of9_165.jpg Choose the (Change Settings) button. paul7of9_166.jpg Next, click on the "Driver" button!." "You will be in the 'area' where the "Keyboard" can be [Enabled / Disabled]. Next, "Enabled the Keyboard." Click on the (OK) button. "This should do it for you!" !Important: If you are still having the same problem? Check: the Keyboard {Status}. "Update the Drivers" Click on the "Properties" button. Select the {Update Driver} button. Next, click on the "Apply and OK buttons!" !Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Mar 13, 2011 | MSI Wind U100-016US Laptop
Tip
How to disable/enable Microsoft Windows startup programs
In this guide I will show you how to enable or disable startup programs in Microsoft Windows. Disabling startup programs can help your computer boot up faster and remove some of that garbage that clusters your desktop when you first boot up your computer.
In Windows go to Start and click Run. In the Run box type "msconfig". You will now get a new window that opens up like below,
Click the "Startup" tab. In this tab you will get a list of programs that will launch when Windows starts up. The more programs that start up, the slower your machine will be. You can speed up your computer boot process by disabling unnecessary programs. To disable a program, uncheck the box next to the program you wish to not startup. Some examples of unnecessary programs are Itunes, Google Talk, Skype, software updater programs or any other programs that you don't wish to be started when Windows opens.
Alternatively, you can enable certain programs to startup when Windows boots. Just check the box next to the program you wish to startup.
Make sure to hit the "apply" button once you are done!
I hope this article was informative.
Regards,
G33k
on May 19, 2011 | Microsoft Windows 7 Home Premium 64BIT...
How do I delete the error reporting to microsoft
if it is Showing ” Internet Explorer has encountered a problem and needs to close. We are sorry for the inconvenience ” Click “Don’t Send ” and everything get closed ,This Window error Report generated by microsoft is sometimes create problems for you , it is suggested you to dont ever click Send Error Reports or ” Please tell Microsoft about this problem ” because it will send all yours computer details to Microsoft , and creating problems for you.so its better to disable that error repor,so that such problem not arise in future,There are three methods to disable Microsoft error reporting.
  • To get rid of this MS Error Reporting, Right-click the My Computer icon on your desktop and choose Properties.
  • In the System Properties , go to the Advanced tab and click Error Reporting.
  • Select disable error reporting This will make any crashing program’s window simply close itself.
  • You could also click But Notify Me When Critical Errors Occur, but it might be even safer if you select Enable Error Reporting.
Inspite of this technique you can also disable error reporting via control panel as well as via editing registry . icon_smile.gif
Tags: Dont Send, Error Reports, Microsoft, Window Error
May 19, 2010 | Computers & Internet
Cannot RE-Enable the wired connection after Disabling it...
Hi
First thing to try is to down load the latest drivers for your LAN card, problems like this appear when windows has downloaded a update which is not fully compatible with your hardware driver.
Mar 18, 2010 | Microsoft Windows XP Professional for PC
Vista cdfs driver disabled, how to enable it
1.update it
  or
2.remove it from control panel
  or
3.intall a updated driver
  or
4.it might get disabled from the task bar,so right click it and select it enable
Sep 20, 2009 | Microsoft Windows Vista Ultimate Edition
My windows will not update
if its not updating automatically then you need to enable updates from control panel under security logo you will find update enable or disable option. Thanks
Jul 06, 2009 | Microsoft Windows Vista Home Basic Edition
Can't disable / remove "Print Status Window" on Sharp Ar-M160/M200
Remove the printer software and use a generic Windows driver. That is the only way, since the status window is part of the driver software. If the printer is postscript enabled you can almost always use the HP laserjet 4 driver which is basically generic postscript.
Jul 29, 2008 | Sharp AR-M160 Laser Printer
Windows update not working and system restore cannot be enable
Try going to the CP - Add/remove programs... updates. Remove the up date.
Go to microsoft and there should be two other updates to install first. microsoft reports people having trouble with this update without the other two updates first.
May 21, 2008 | Microsoft Windows Vista Home Premium with...
DELL Optiplex GX 270 windows update failure
hello,
please try this solution that i search in the net:
"Reboot the computer.
If you have a 3rd party firewall, disable it after enabling the Windows
Firewall:
http://support.microsoft.com/?kbid=283673
Disable any pop up stoppers.
Disable any anti spyware.
Disable and download accelerators.
Disable your anti virus.
Otherwise follow the Windows Update Checklist:
http://www3.telus.net/dandemar/updtcl.htm"
PS: pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
best regards, melnavz
Apr 10, 2008 | Dell OptiPlex GX270 PC Desktop
Microsoft Windows XP Media Center
when you start you machine press whichever key you need to get into your cmos setup. once you get there look through the list for password enable or disable. I think pressing the spacebar will change the enable/disable state, then save and exit.
Sep 26, 2007 | Health & Beauty
Computers & Internet Logo
Alun Cox
