Question about HP LaserJet 3050 All-In-One Printer
Lines showing up in printout
4 parallel lines showing up on printout.
Thanks,
FD
  • 1 more comment
  • erika holder Oct 01, 2008
    giyyyyyyyyyyyyyyyyyyyyyyyu
  • tim5749 Oct 09, 2008
    Lines showing up down the middle of the page on the print out. Is there some sort of drum to replace or anothe way to fix the line problem?
  • ganessan_p Oct 12, 2008
    I do have the same problem
    Sergeant:
  • 352 Answers
Hi, I would suggest you update your printer drivers, try this, follow instructions exactly as written:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Posted on Oct 21, 2008
Black colour lines in xerox only
Dear
If you have facing the problem while you made copy using ADF.then check th adf glass for scrathes replace it. If you have the problem while copy on platen glass then check lines on platen glass (rare case). Check cis for dust.
Thanks.
Jan 30, 2015 | Canon ImageRunner 4570 | IR4570 |
My hp inkjet prints lines on my printouts that are supposed to be there
Do you print regularly? When was the last time you changed the cartridge?
If you've changed it recently it's likely that your printer head is dirty. Clean (hot water and paper towels in a discardable container.... allow to sit for a good while, wipe gently replace in printer) or just completely replace the head.
Feb 07, 2013 | HP Officejet 5510 All-In-One Thermal...
Error badint 0085ddc0
The 'badint' error on the T6100 indicates the printers firmware has for some reason 'crashed', this error should not be seen in normal operation of the printer.
One common cause of "BADINT" messages is the use of an external print server or host computer with incompatible parallel-port settings. If you have an external print server connected to the printer's parallel port there is a setting on the print parallel interface that may need changing, to change parallel interface setting. • Set the printer to Offline. • Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access On) • Press the Mode key: display will show Offline Normal. • Press any Arrow key until display shows Offline Config. • Press the Forms/1 key. • Press any Arrow key until display shows Config Paralel. • Press the CPI/2 key. • Press any Arrow key until display shows Paralel Bi-Dir. • Press the LPI/3 key. • Press any Arrow key until display shows Bi-Dir Off. • Press the Enter key and the interface will be set. • Press the Clear key. • Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access Off) On the external Print Server, you need to ensure that the unit is also set for Uni-directional working.
Nov 04, 2011 | Tally Line Matrix T6100 Printer
I have downloaded the printer drivers for my HP Deskjet D2460 from the HP site but I have no printer toolbox and therefore cannot clean cartridges etc. Can you help
Hi Kimsmith99
Please do not worry. You can try the following.
1. Simple take the cartridges out from your printer.
2. Use a clean cloth and some distilled water.
3. Clean the copper connections of the print cartridge gently with the help of the clean water and a clean cloth .
4. Take a tissue paper and then try to mark a stamp from the cartridge print head on that tissue paper.e
5. Do it till you get a clear color / black parallel line on the tissue paper.
6. Once you get a clear parallel mark on the tissue paper, insert the cartridge back in to the printer and the take 2-3 printouts.
7. You will get the clear printout for sure. This is my practical experience.
Thanks & Regards
Ashish Rohilla
Aug 21, 2010 | Office Equipment & Supplies
Verticle color lines on scanner bed and printout in photo mode
Hardware failure, nothing much can be done, just replace the scanner.
Aug 27, 2009 | Epson Expression 1640XL Graphic Arts...
No black when printing color
Dear Sir,
You are getting black lines in green color,and apperence of parallel light and dark lines because your colour catridge is almost empty.So solution is replace the catridge and take a printout. There is no proplem with a printer. i think it solves your problem.
good luck
chandrashekhar
Jul 29, 2009 | HP OfficeJet 4255 All-In-One InkJet...
SMDR not showing all CO lines
i will making tda-200 ext and co lines cable
Mar 16, 2009 | Panasonic (KX-TDA200)
I have blank lines through my printouts
Run the cleaning cycle. If that doesn't work, try to use an alcohol soaked swab on the print head. Some of the jets are clogged.
Oct 27, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Vertical line running through video channels 1-4
Interchange the video channels 1-4 and 5-7. Now check white vertical line in video port 5-7. Suppose you get problem remove cable television cable from tv during another two port running. These type problem occurs only when RF disturbance from cable television or video ochannel ports cable wire ground problem. I found there is no problem in tv. External source only the problem. I hope above details give you the better solution.
Aug 23, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
HP LaserJet 3050 All-In-One Printer Logo
51 people viewed this question
Ben Johnson
