Question about Samsung DLP HL-P5663W 56" TV
OLDER 32" TV WON'T TURN ON/KEEPS TURNING OFF
1 HAVE A PHILIPS 32" TV MDL# 32PS53 C101 CHASSIS 32V514-00AA
THE PROBLEM IS THE TV WOULD KEEP TURNING OFF RIGHT AWAY WHEN YOU TRIED TO TURN IT ON. NOW IT WONT EVEN TURN ON. YOU PUSH THE ON BUTTON ON REMOTE AND TV TRIES TO TURN ON (IT CLICKS ON) THEN IMMEDIATELY CLICKS OFF AGAIN WITHIN 1 SECOND. IF YOU PUSH ANY BUTTON ON THE TV - VOLUME UP OR DOWN, ON/OFF BUTTON, ANYTHING THEN THE TV TRIES TO TURN ON THEN CLICKS OFF AGAIN. IS THE SWITCH WORN OUT OR IS IT THE POWER SUPPLY ? I HAVE DISCONNECTED AND TRIED TO PLUG IN AGAIN AFTER SITTING A WHILE BUT NO LUCK, ANY HELP WOULD BE GREAT.
THANK YOU,
HENRY
    Champion:
  • 252 Answers
Re solder your tv,if its not works, check the horizontal output transistor
Posted on Oct 02, 2008
Philips/Magnavox 27TS54 C101/chassis 27B800-7562. Originally would not turn on at all. Replaced C506 (totally scorched) as other posters recommended. Now turns on but only bright white horizontal...
check for power supply for normal dc voltage..try resoldering the vertical output ic or test the vertical output ic dc supply..if there is..try finding some loose connection to the deflection circuits
Jul 13, 2011 | Philips TS2768C 27" TV
Philips 32PT6441\37 will not turn on. Flashing
You need the Horizontal Timing Kit for your TV. Chassis # is L04.1U AA can be found on the back of the TV. The part# is 4835 310 57673, Have a tv tech install this for you.!!!!
Oct 17, 2009 | Philips 32PT6441/37 32" TV
OPERATING A MAGNAVOX TP3170 C101
i would try the magnavox website,just go to support or customer service and they should have a manual there.if not let me know how you make out.
Dec 07, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Television problem
Hi there!
I would start with power supply caps and regulators. However it could really be anywhere on the circuit, Philips TVs are error sensitive so I would recommend a repair technician. Good Luck, Jus004
Feb 20, 2008 | Philips 32PT6441/37 32" TV
Picture issue with Philips 64" Big Screen
don't know if this is same problem or not but try this:
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.keohi.com/keohihdtv/brandspecific/philips/philips_convergence_geometry.html
Dec 05, 2007 | Philips Magnavox 9P6034C 60" Rear...
LG 32 in. HDTV keeps turning off.
I Have the same problem, LG 32" , LC2D a couple of work arounds that work are
1) - never unplug the mains plug
2) - i noticed it does this when the clock time is --:-- , i find that switching to digital tv can stop this,
however these are only tempory fixes and the problem re surfices, as i have found out after having no problem for 12 months, i have accidently unplugged the mains, and now the tc keep turning itself off,
Oct 31, 2007 | LG 32LX3DC 32 in. LCD HDTV
TV Power
it is general problem in philips tv. it is due to low voltgs section of power supply might be defective
Sep 13, 2007 | Philips 32RF50S 32" TV
My Tv just keeps turning on and off with no pattern
The first and most obvious thing to check is if the power button has been push in too far in,other than that the unit is going to need service,if you are familiar with tv service you can try removing the back cover and pulling the chassis back a little to make sure the buttons are not making contact with the momentary switches inside the unit.Make sure the unit is not plug in while you do this.Be careful or be safe and call for help.
Sep 27, 2006 | Philips 32PT6441/37 32" TV
Philips magnavox 25TS56
Same problem. The power button does not work. The volume and channel buttons turn the tv on. the tv then shuts its self off 15 seconds later. the red light blinks in second intervals while this happens.
Sep 16, 2006 | Philips Magnavox MS3252S 32" TV
Samsung DLP HL-P5663W 56" TV Logo
443 people viewed this question
Henry  Thomas
Henry Thomas
