Question about Cameras
The pictures are too blue. - Cameras
  • ivyjo45 Oct 01, 2008
    The pictures are too blue. I need to reset the balance but do not know how. I have the Olympus Stylus 800 8 megapixel all-weather model no Stylus 800 DC3.7V and I need you to tell me exactly what I need to do, every step please. Thanks so much,Ivy
    Thank you. Looks like I have to check the WB mode every time and adjust it. It definatly helped. Ivy
    Sergeant:
  • 208 Answers
I think this can be resolved by adjusting the WHITE BALANCE.
The color of the subject differs depending on lighting conditions. For
instance, when daylight, the setting sun or tungsten lighting are reflected
on white paper, the shade of white produced will be slightly different for
each. By adjusting the white balance, you can achieve more naturallooking
colors.
To adjust it,
1. Select top MENU-> [WB]
2. Select the approriate White balance setting according to the environment.
To know about all the different white balance setting download and
read "Advanced Manual for Olympus 800" manual given in this site,
Refer page no: 50
www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Note:
White balance may not be effective under some special light sources.
Under that circumstances , you can use the photoshop or any other software to edit your pictures to get it right.........
Hope my info solves your problem,
Thanx for using fixya,
Good luck.
Posted on Oct 01, 2008
    Sergeant:
    Champion:
  • 435 Answers
Hi, Switch on the camera. Press menu button. You should see 3 modes. Camera, Card and Set.
Goto Set/ Setup > Color  Change the mode to normal.
It should work now.
  • Cameras Master
  • 1,879 Answers
    Master:
  • 479 Answers
Get your camera to work on the proper mode sometimes if the camera is set on the night mode it catches the extra blue.just transfer it to normal mode from night mode and your camera will work properly.
  • Cameras Master
  • 6,487 Answers
CAn you please provide us first the brand and model of this unit so we can help you better, YOu can also try first resetting your camera to its default settings and check if that will correct the problem...
  • 10,594 Answers
Select white balance options like in-door or out-door to get fine color tone in picture.
    Genius:
  • 3,422 Answers
Sounds like wrong shooting mode for your subject and improper white balance. First off, turn the white balance to full sunlight isf shooting in sunight and use the creative modes ( P, Tv, Av, M ) since white balance reverts to AWB in non creative modes. check exposure compensation, check iso,
  • Priya darshan Oct 01, 2008
    Thank you for using fixya.
    Sergeant:
    Champion:
  • 200 Answers
Hi
With out model no or brand name we can't help u fully pls tell me.So that we can help u..
Better try this..
Turn off the camera or remove battery for five minutes and then try it.
  • Thafa Oct 01, 2008
    If u have warranty means then claim it..
  • 57 Answers
It sounds like a White Balancing problem. I'd guess if it's set on Auto WB, then you'll need to do it manually. Some digital cameras tend to produce that blue tint when left to white balance themselves.
If you don't understand completely let us know the exact model of the camera and I'm sure somebody can talk you through it!
IGO tv connected with dish sound come from tv but pictur not show only blue color show
Component RCA Connectors are RED, BLUE, GREEN for picture. Sound is RED and WHITE. The red and white for sound work the same with the YELLOW that does picture. If the RED, BLUE, GREEN are in the wrong order you will get a blue or green picture. For the sound, try the other red and white connectors nearby. Make shore the right red connectors are connected correctly for sound or picture. Otherwise there could be a cable fault or a TV fault. If you get the picture right but not the sound, connect the sound into a stereo.
Jul 17, 2017 | Televison & Video
My screen starts blinking blue then goes all blue and pops and shuts off. I can wait hours and reset and it will come back on but the problem repeats itself.
This is symptom of bad/ defective blue picture tube that will be replaced to fix this problem.
Blue picture tube replacement is job of professional because it requires lots of convergence adjustments for correct picture and picture tube price would also be bit high.
Let me know to provide you blue picture tube part number info.
Thanks.
Dec 12, 2010 | Sony KP-57WV600 57" Rear Projection...
I have blue arched lines and blue screen
HI:
Your problem is the blue CRT or picture has gone bad, you will need to have the picture replaced, there are three tubes in this model rear projection television. Red, Green, and Blue. Replaceing the blue tube is the only option for normal operation to resume. It may be hard to find the tube, but you can try contacting this website for the part www.vdc.com, they manufacture and usually have stocks of sony picture tubes and rebuilt ones as well. The company's name is Video Display Corporation...
Jul 14, 2010 | Sony KP-57WV600 57" Rear Projection...
RCA mm32110 picture turn to blue and white like you have blue sunglasses on.
I'm not familiar with this set but it sounds like your blue crt has shorted out and is putting out so much color that it overwhelms the other colors. Is the picture also washed out? If so then your blue crt is bad. Probably not worth fixing. Let me know more about what the picture looks like.
hardrocko
Jan 31, 2010 | RCA Televison & Video
My tv has sound but no picture except for a blue screen
My television worked this morning and now only shows a blue screen. The sound works but no picture except for a wavy blue screen.
Jan 22, 2010 | Televison & Video
Distorted Color and geometry of Picture
replace stk 392-110 ( or stk 392-150 same number) , check resistor 2.2 ohms for open or burn beside STK IC's
Apr 13, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Hardly any Blue Color in the picture. the blue tube is projecting darker and dimmer.
You need a Blue picture tube CRT you can get one for your JVC at the following link for a real decent price and they provide free shipping. Heres the link.
http://servicemanuals.vstore.ca/
Jun 07, 2008 | JVC AV-56WP74 56" Rear Projection...
Picture fads to Blue after a 30 minutes the picture comes back with a blue tint.
yeah you need a tech to adjust the bias of the picture tube if you are lucky that fix it other wise the blue picture tube is bad
Apr 29, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
PT-47WX, Blue streaks across the screen?
It is not a bulb. It is a picture tube. If there are thin blue lines across the entire screen, not just the edges, and the picture itself looks too blue, it means that the blue picture tube is being driven too hard. This could be because the blue screen voltage is too high, the boost voltage on the blue picture tube is too low, or the video output is leaky or shorted. If the picture has what looks like blue arcs and double images on one or more sides of the picture, it means that one of your convergence IC's has burned out and needs to be replaced. These are things that should be tested and serviced by a qualified tech, so allow an experienced tech to handle it for you.
Sep 07, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Cameras Logo
136 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
