Question about Hussmann HGM-2-TS Commercial Refrigerator
Hussman hgm2ts refer commericial 115 volt hooked up 220 bye accendent lights not working i think not getting cold sounds like motors working did i mess alot things up if anything and how to fix it
  • 943 Answers
Hi . thanks for the question . its very hard to say what blew . it could be very expensive or not . but to see what 240 volts did .call in a tech for an estimate. thanks the appliance doc
Posted on Oct 01, 2008
How to covert a 220 motor to a 115vac motor. ao smith rpm3450 3.hp 15 amps
If your label looks like this one and or if your label dose not have 120 as one of the voltages then you can not run the motor on 115 volts.
Apr 16, 2017 | AO Smith Pool & Spa
Lights light up...but it just clicks when I push start
Try turning the drum bye hand then try starting again. If this makes it work then you need a motor. If not, check that you are getting 220 volts to the machine and then check the door switch. I am here if you need further asisstance
Jan 27, 2014 | Dryers
Proper wire hook up
black goes to L1 white goes to L2 make sure to look on side of motor to change from 220 volt to 110 volt either a knob or changing wires brown and white to different locations hope you didnt fry motor
Jul 26, 2013 | AO Smith 1.5 hp 3450rpm 48Y Frame 115/230...
Wiring a 230/115 1 hp 56y pool pump motor
please verify the name plate to be 115 230 volt motor.there will be a schematic that shows you exactly how to hook up this motor depending on the voltage being supplied to it. The main thing is switching between 115 and 230 volts this is a selector switch this very easily forgotten about. Please make sure to check that and double check that to make sure its on the proper selected switch. Good luck
A thumbs up would be greatly appreciated if this answer is helpful to your free Fixya question
Jun 30, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
Bosch universal mixer 800W. How do I change a 110 volt to a 220 volt? Is it possible?
Bosch is not very good about putting manuals or other documentation online for older products, so I'll have to give you generic advice.
Some electric motors have optional voltage connections. If your motor has this feature, there will be a box or removable plate on the motor with 110 Volt and 220 Volt connections inside. You would need to replace the line cord with a 220 Volt cord having the correct plug for the location you plan to use the mixer, and connect the motor "hot" wire to the 220 V connection in the motor junction box instead of the 110 V connection (the neutral wire goes to the same neutral).
If there is no such option available on the motor, you would also have to replace the motor with a 220 Volt version. Check the labeling on the speed control (inside the mixer) to be sure it is rated for 240 VAC, and check the power label by the power cord. If the label gives a single range of input voltages spanning both 110 VAC and 220 VAC (e.g., "Input 97 V- 265 V") then you only need to change the plug. Unless the electrical parts are all rated for 240 VAC or higher, conversion is not safe.
Some products (especially desktop computers) have a recessed switch on the back that lets you select either 115 VAC or 230 VAC input power. If you have this on the mixer, all you have to do is use a small tool to push it to the other position.
An alternative is to get a 230 VAC - 115 VAC transformer or inverter rated for at least 800 Volt-Amps and wire it with a 230 Volt plug on the primary side and a 115 Volt socket on the secondary side; then you can just plug in your unmodified mixer to this. If you cannot find a box like this, you can buy a "control transformer" from an industrial equipment supplier and put it in a suitable metal box. I recommend including a power switch and a 4 Amp dual-element fuse or breaker on the primary side circuit; you don't want somebody burning up the transformer with a 1200 Watt microwave oven or griddle.
Mar 17, 2011 | Bosch MUM6630 Universal Series Stand Mixer
Kenmore dryer runs but no heat. I have ohm checked the heating element, all thermostats and the thermal fuse. All ohm okay. I also checked voltage throughout the circuits from the main block to each...
Did you read ~220 volts AC across the two slanted blades of the power socket? The motor and controls usually run on 115 volts. When the timer is set to dry, press start, and look for ~220 volts at the heater element connections. (Don't let the heater reach full heat if it starts working!) You may have to short the door switch connections to get the unit to run. If you don't read 220 volts at the plug, check the output from each breaker of the dryer pair (should read 115 volts to neutral). Hope this helps!
Oct 09, 2010 | Dryers
Dewalt D55155-QS 220 volts can it convert to use 115 volts?
The short answer unfortunately is no. The internal motor that drives this compressor requires 220 and will not work properly with 110. Your only option would be to replace the motor with one compatible with 110. The cost of that would approximate a major portion of a replacement unit.
Sorry about the bad news.
Dan
Jul 08, 2010 | Black & Decker Dewalt #D55155 2HP 4GAL...
Am I able to step this motor down to 115 ? Plate specifies 230V.only
it depends on how many motor wires you have available to work with .. IF the name plate says 220 volts , not 120 / 220 volts , then no. If there are only 2 wires for the motor, then NO
thoughts?
Jun 23, 2010 | AO Smith 1.5 hp 3450/1725rpm 56J Frame 115...
My GE DPSB620ECWW does not light up the pannel or
Check circuit breaker at the house electric panel, if good, check for voltage (220/240)volts at the receptacle that the dryer power cord plugs into, if good, check for voltage(220/240)volts at the dryer terminal block where the dryer power cord connects to the dryer, if good, check voltages at the dryer power transformer, should be 220/240 volts for motor,and 110/115 volts control power for dryer controls, you should find the failure within these inspections/testing.
Good Luck !
Mar 15, 2010 | GE Profile DPSB620ECWW Electric Dryer
Hussmann HGM-2-TS Commercial Refrigerator Logo
138 people viewed this question
Top Hussmann Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Hussmann Refrigerator Expert? Answer questions, earn points and help others
