Question about Nikon Coolpix 8700 Digital Camera
Coolpix 8700 turns itself on, with power switch in off position
A few seconds after I turn my camera off, and it has closed down, it turns back on again. Even though the switch is set to shooting mode, it turns on in playback, so the lens doesn't open, and I wouldn't have noticed that it was on but by chance. In this state, it wont do anything else but playback, and wont turn off. I have to take the battery out to stop it from running down. When I put the battery back in, it shows "set date & time" screen, but I then can't get away from this, except by removing battery again. If I put battery in with switch set to "on", it functions as normal in shooting mode, until after I turn it off and it shuts down. It turns back on again!!
Anybody know what's going on, & more importantly, what I can do about it, without it costing an arm and a leg. I really like this camera.
Cheers in advance, Jon.
  • wind_cruiser Dec 07, 2008
    Well, so much for "Fixya" being a great site for help. Not a whisper.
    Anyway, not to panic, 'cos a couple of weeks ago my camera started to work again all on its own, so fingers crossed and all that.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 29, 2010
My Nikon 8700 will not take any pictures..when I turn it on a message comes on the screen that "speedlight is in the closed position". When trying to take a picture, it buzzes,and an orange light flashes...
Please try resetting the camera to factory defaults first, but it sounds as though it may be a mechanical problem with the flash linkage. You can also use the flash selection on the side
of the lens housing and select "No Flash" to see if the camera will take pictures then. Since you have an attachment for an external flash, that might be an avenue to help you still use your camera. Getting it repaired would be expensive.
Sep 09, 2013 | Nikon Coolpix 8700 Digital Camera
I'm using my Nikon coolpix 8700 to take photos of museum objects so the photos need to be of a fairly high standard, but the photos are coming out just slightly out of focus. Where am I going wrong? Thanks
If these are close up photos, the depth of field will be shallow. You need to raise the ISO to force the camera to close down the aperture and increase the depth of field. Also, the use of a tripod or monopod will greatly increase your chances of taking a sharp picture.
May 17, 2010 | Nikon Coolpix 8700 Digital Camera
Display will not turn on. Battery is fully
Hello
Thank you for using FixYa for your problem
Always check the batteries first (check that the voltage is correct with a volt meter) but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Anything is fixable but it is more "is it cost effective"
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | Nikon Coolpix 8700 Digital Camera
I need a CCD for my Nikon Coolpix 8700
Hi
If you are in the U.K
Please contact Nikon UK for this part. Call: 02084816815
Aug 07, 2009 | Nikon Coolpix 8700 Digital Camera
I am not able to find, How to turn of the Flash of Nikon Coolpix 8700. When i need to take pictures without flash, but when i click, it automaticaly turns on the flash, and i tried to figured it out how to...
ok. there is a button on the side of the lens. it has an eyeball and a bolt of lightning, press that button and look in the top right corner of the screen. keep on pressing this button until you see; a lightning bolt with a circle with a line threw it. then "click". if that doesn't work switch your camera to manual and try this again.
Jan 11, 2009 | Nikon Coolpix 8700 Digital Camera
Problem with nikon coolpix 8700
Same problem that would not allow me to take a picture without pressing the LOCK button on my Nikon 8700. Here is how I believe I fixed the problem:
Turn the camera ON.
Press MENU button on your camera to bring up the menu.
Scroll down to SET-UP, open the SET-UP menu by scrolling right.
In the SET-UP menu, scroll all the way down to FUNC (Controls) on page 2/3 , open the FUNC (Controls) menu by scrolling right.
You are now presented with 2 options:FUNC and AE-L, AF-L)
Select the FUNC option by right scrolling.
Choose the 2nd option: i.e the mountain, flower and timer icon (distance, macro and self-timer icon) by right scrolling.
Press the MENU button to get out of the menu.
Attempt to take a picture without pressing LOCK.
Should work! Anyways, it worked for me.
Cheers.
Sep 28, 2008 | Nikon Coolpix 8700 Digital Camera
Lense not closing, switching on for one second then shuts down. when attempting to turn on green light flashes then turns off
try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
May 21, 2008 | Canon Cameras
HOW DO YOU TAKE A MOVIE ON THE NIKON COOLPIX 8700
Go to menu and on the contuniuos change it to a movie camera icon.
Oct 23, 2007 | Nikon Coolpix 8700 Digital Camera
Battery Problem
Sorry this isn't a solution, but I wish my 8700 would last even as long as yours does. 2 hours, period. on or off, taking pictures or not, two hours & it's a stone dead battery. Just on the off chance it will help I'm about to upgrade the firmware to 1.3 (I don't really think it will help). After that I've decided to take the camera apart & try to find the problem or possibly just a hack that will let me turn it OFF without removing the battery. I'd as soon have a bunch of bits for the project bin as have to put up with this 2 hour battery life problem. Good luck with your problem, and if I find anything worth while I'll post back.
Sep 28, 2007 | Nikon Coolpix 8700 Digital Camera
Nikon Coolpix 8700 Digital Camera Logo
76 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
