Question about Husqvarna Viking 1
Power supply for 1+
Machine foot pad got wet and now machine will not power up
My 5710 just sews without any pressure on the foot pedal and sews at top speed.
Posted on Apr 03, 2011
  • 201 Answers
Water + Electricity = Yikes!!!!!!!!!!! Take the machine to a repair shop before you do anything else with it.
Posted on Oct 19, 2008
Walking foot not feeding fabric
Fine wet and dry paper slightly rub walking foot and it's base for any jagged edges.
Oct 19, 2017 | Sewing Machines
Missing accessories
Call Brother Sewing Machines - 1-877-276-8437
Jul 01, 2017 | Brother Sewing Machines
Husqvarna model 183 foot control no power
anytime the machine does not respond like it's suppose to then it needs to be checked, the foot pedal could have gone bad, or the the sewing machine plug where the foot pedal goes may have gone out
Mar 27, 2012 | Husqvarna Viking 1
The foot pedal on my Singer Inspiration is stuck on fast speed.
Hi lawoffice474...
Unplug your foot pad from the machine and the electrical receptical.
Try moving the foot pedal with your hands, back and forth as if you were pressing your foot on it.
Did it loosen up?
If yes then you still need some maintenance...
If no then you still need some maintenance.
Disassemble the foot pedal and take as many pictures as you need to be able to reassemble it.
Once you have disassembled then you will look to oil (one drop max) the pivot points of the foot pedal, like the hinge assembly, reostat linkage,etc.
Once you have it oiled then try moving the foot pedal again my hand before reassembly.
If everything moves ok then your good to go...
Reassemble the foot control.
If not then its time to replace it with another foot pedal such as one of these at this webpage below:
Please take time to rate me thumbs up.
http://www.sewingmachinesplus.com/singer-foot-controls.php
Sep 10, 2011 | Singer Inspiration 4206
I wouuld like a 1/4 inch stitch is it passible with the 227?
This is the seam width?
Some machines can use a universal 1/4" presser foot.
If the needle can be positioned to the right, you may be able to use a regular presser foot.
A seam guide can be fabricated by using a sticky note pad or layers of painter's blue tape to act as a "wall" to help keep the raw edge of the seam feeding evenly. Measure 1/4" to the right from the needle and position the note pad or tape accordingly.
Mar 18, 2010 | Consew 226R-1
My machine has power, but foot pedal only makes needle go slowly
sounds like the contact in the foot peddle has failed try a new peddle
Jan 02, 2009 | Necchi 3101 Mechanical Sewing Machine
Designer 1 reverse won't select, no light at all
The designer 1 has a weakness of the reverse pad (rubber button set) on left side of the machine wearing out and not working. You can try pushing from different angle, or pushing hard, but it most likely needs to be replaced. If you did buttonholes with the buttonhole sesor foot (foot with a wheel and a cord that plugs in), it would automatically size the buttonhole and you wouldn't need to reverse and you can use "FIX" to tie a knot instead of reverse
Dec 30, 2008 | Husqvarna Viking 1
Model 6010 Won't Stop Sewing
I would say that is the computer in hte machine
Jul 18, 2008 | Husqvarna Viking 1
Sewing Machines Logo
147 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
