Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
How to clean ice maker door on a Kenmore
The ice maker part on the outside of the door is dirty. how can i remove those parts to clean them. i can only see it if i neel down and look up at the ice maker parts.
  • 120 Answers
Is it a side by side or trio with french doors ? we will asume is a side by side under the dispencer trip there are two small slots were you insert a flat screw driver. now twist to unlock them once you remove that cover you can see more inside and how you can have more access but be care ful disconect unit if possible
Posted on Oct 17, 2008
Ice maker stuck on crushed ice instead of cubes
most likely you have ice built up in the door or icemaker that has frozen hard easiest thing is to turn of fridge empty freezer leave door open to melt the ice remember to empty ice maker wash it out removing all ice ect. then when all is dry and clean start it up and see if that doesn't fix it.
Aug 20, 2014 | Kenmore Refrigerators
My ice smells moldy
Icemakers need to be cleaned about every 90 days, especially if it is a bin type unit that holds recirculated water in a tank which is then pumped over a grate to make ice. You didn't indicate what type of ice maker you have. Many manufacturer produce a cleaning produce for their ice makers. Here is a link to the Whirlpool/Kitchen Aid product:
http://www.amazon.com/Whirlpool-4396808-Machine-Cleaner-16-Ounce/dp/B001ECQ1YM/ref=sr_1_1/177-5038340-6980446?ie=UTF8&qid=1397503407&sr=8-1&keywords=Ice+Machine+Cleaner
It is made primarily for a bin type ice maker and does an adequate job if you use it on a routine basis (i.e., every 90 days).
If your commercial ice maker has removable parts, remove all parts that have direct contact with the ice. Wash these parts in hot, soapy water and use a brush to remove any dirt or mildew from the parts. Remove any ice or water storage bins and wash them in soapy water. Rinse each part thoroughly to remove all traces of soap. Use a 50/50 vinegar/water solution to break up any hard water (calcium) deposits on the parts. Sanitize your ice maker parts by soaking them in a solution made of 1 oz. of bleach and 1 gallon of warm, clean water. Allow the parts to soak for at least 30 seconds and leave them to air-dry.
Clean and sanitize ice makers that do not have removable parts by running two or three cycles and discarding the ice. Check you manufacturer's instructions for how to clean your ice maker. Some machines may not tolerate diluted bleach solutions, so check the sanitizing solution specified by your instruction manual through the machine. Always throw away the first batch of ice made after cleaning. Also change your water filter, if so equipped.
If you
Mar 29, 2014 | Kenmore Refrigerators
Ice and water keeps coming out
Cup lever isn't returning to the off or close position completely. Suggest checking for rusty spring, dirty parts restricting lever and other parts there from moving freely. Could be the switches are worn out as well. Dis-assemble and clean all parts and inspect or replace old worn switches. Inspect ice drop/ flap door for mildew, sticky residue from drinks and ice build up.
Feb 09, 2014 | Kenmore Elite 31 cu. ft. Grab-N-Go...
Poor quality ice
Is the ice too small or is it dirty in appearance? If it is too small then the 1.4 inch water supply line may be pinched or clogged. Trun off the water to the unit and remove the line connected to the rear of your fridge. Then get a large bowl and have someone turn on the water supply. If there is sufficient pressure then more than likely the inlet screen to the ice maker water valve is obstructed and will require cleaning. Follow the input water line to the ice maker water valve. Some valved can have the screen cleaned with the valve installed by removing the input line and then the input screen. You can gain access to the screen by removing the flexible back panel, remove it by using a pointed tool on the outside of the screen ede only. Then wash / or scrub it clean with your fingers while running water over it. Reinstall the screen, reconnect the valve input line and then reconnect the water supply line and turn on the water supply. It can take several hours before the unit starts making ice cubes again as you have intorduced air into the system and it will self purge during the next few ice making cycles. You should have the correct sized cubes within 24 hours. If the cubes are dirty then go to any appliance parts supply store, purchase a charcoal filter and install it just above the inlet supply line connection.
Jan 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice Maker Dispenser Motor Won't Stop Running
There is a plastic part in the dispenser that holds the micro switch that operates the auger motor when you push the paddle. If you're handy with hand tools, you can order the part and replace it yourself. The part is on the outside of the door.
Jun 15, 2017 | Kenmore Refrigerators
Freezer running, ice maker not producing, hot in middle divder.
The dividing section should be warm, to keep unit from sweating. (by design). Cleaning under the refrigerator was what cooled it down. You cleaned the condenser. The condenser allows the refrigerent to cool down. When it was dirty, the condenser could not get enough air to cool down.
Mar 14, 2009 | Kenmore 57029 Side by Side Refrigerator
Snows inside freezeer compartment of side by side
You actually have 2 problems here.
One the ice maker shutoff is defective. REPAIR is to replace the ice maker.
Two (snow) is a loose door seal, Outside air entering the freezer.
Feb 20, 2009 | Kenmore Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
463 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
