Question about JVC Everio G Camcorder
JVC CU-VD10U DVD Burner
I have two burners and neither of them will recognize a blank disc. We are connecting an Everio 515 and/or an HD7. Burners recognize the camera but will not recognize the blank media. I have tried Ridata, Memorex, Magnavox, Maxell and Sony blanks. I have resorted to buying 2X -RW'S, and those won't load up. One of the machines failed after burning 4 DVD's. It was sent back to JVC for repair. We were charged $125 for the repair, and it burned 1 DVD, then failed.
  • 7 more comments
  • waynerd Oct 01, 2008
    One of the first things I did with both units was to open them up and clean the lens. I have operated a VCR and Video Camera Repair for years, so I feel most qualified to do that. When this failed, I searched and found updated software. I have attempted to load and run CyberLink 5.5 with no success. It origionally came packaged with CyberLink 2. I think we are just dealing with a true JVC lemon!
    Maxell 2X -R is what they packaged with the unit as a trial DVD blank. I have tried Maxell 2X -RW's with no luck. As you can imagine, 2x media is hard to find. I have made attempts to contact JVC Tech with absolutely no success.
  • waynerd Oct 06, 2008
    This is my attempt to repost concerning the JVC CU-VD10 Sharestation failures. I have two of the units. One was bought along with a JVC GZ-MG505 camera, the other with a JVC GZ-MG555. Both worked well first time out of the box. Both were put away for several weeks after their first trial. Our next attempt to use each of them resulted in failure. The erroe message on both was incompatible disc replace disc. We have tried cleaning to no avail. We tried using different media to no avail. One unit was sent back to JVC for a repair charge of $125.00 and burned one disc (a brand that we had purchased). I called JVC Tech and spent an hour on hold waiting for a Technician. I finally terminated the call without talking to anyone. I sent JVC Tech a query and never recieved confirmation of the query or a reply. Last week, I again emailed a query to JVC and have yet not heard from them. Based on the large quantity of these that are to be found both on the internet (ebay) and in retail stores as returns that don't work, I have to suspect that they are basically lemons that JVC will not support. I have spent several hours going from blog to blog reading failure reports from other buyers, and no one seems to have a solution. That is as much info as I can provide on the JVC CU-VD10U Sharestation. Now it's time for FixYa to show off and find the solution everyone needs! Thanks.
    Three cameras and two burners, and every camera to burner combination gives the same results! To what firmware are you referring?
    With three different JVC cameras, two burners and 5 different brands of media, no combination will work. The same error message appears regardless of the combination. What firmware do all the experts keep referring to? The camera/burner combination is a stand alone entity. There was no software or firmware to be installed before usage.
    Nick, Thanks for the response. I fail to see the connection between the two problems. I am not having any problems what-so-ever taking video from the camera hard drive to the pc hard drive. I can burn from camera to DVD recorder in real time. It can use the Everio software to backup to my pc. The backup to pc process is most time consuming. It took 12 hours to backup 4 hours of video to the pc. The Sharestation was designed and sold as a complementary device that would burn a usuable DVD from the camera at 2X speed without the need of a pc. This was one of its great selling features. It don't work!
    Either I am not being clear on this or I am not understanding the significance of Nero. You have a stand alone DVD burner plugged in to an a.c. outlet. You have a hard drive video camera plugged in to an a.c. outlet. The video camera output is connected to the DVD burner input through a U.S.B. cable that is provided by JVC. There is no software. There is no firmware. There are two pieces of JVC equipment tied together with the supplied JVC cabling. There is a blank JVC DVD -R disc in the DVD burner. You power on both items, open the view screen on the camera, then follow the instructions sent to the viewscreen from the burner. The DVD burner makes (supposedly) a DVD directly from the cameras hard drive without the benefit of a pc.
    Final comment, and I'm gonna write this off as a complete waste of time and energy. There is a list of DVD media that is reccommended, found on the second or third page of the JVC manual for the CU-DV10. I have tried each and every one of them with the same results! This FixYa exercise has netted me the same results as trying to contact JVC Tech.....NADA!
  • kordishread Jan 19, 2009
    incompatible disc in the share station
Bin it.
Posted on Nov 04, 2008
    Sergeant:
    Champion:
  • 334 Answers
I have nero 7 ultra that has video cam caputre softare shoudl work great i can email u or im me on aim or yahoo
Posted on Oct 06, 2008
  • 3 more comments
  • nick helpap
    nick helpap Oct 06, 2008
    cuse u need nero man your roxio or any other buring software is terrible u wann burn mpeg ? or convert video files form cam 1st make dvd movies menus use nero
  • nick helpap
    just junk off brand all that is buddie has one that has that ad don burner junk does your cam have usb out for it we can buy new dvd rw drive extrnal
  • nick helpap
    ojust on that kinda ideam erther works or dont cant get in ther wiggle a needle aorund to make min i drive work to brun alotthose off brand ones dont work right need buy ther brand meadia only read it close online how it says what it uses if that dont do it take it back try anther unit
  • nick helpap
    ya i would just go to hard drive then not dirdect recording to dvd rw
  • nick helpap
    uuse dvd + r
  • 1,879 Answers
Bad product i say. does JVC have a list / info of "tested blanks" ?
Posted on Oct 01, 2008
  • monk3ybidzness
    monk3ybidzness Oct 01, 2008
    since you've been in contact with JVC, do they have a list / info of "tested blanks" for use with their product ?
  • 6,487 Answers
This problem is weird because if you already tried using alot of disc and still it wont burn this can be a problem with the burners , this can be a softwarer related problem I will advice you to contact JVC and ask them if there's any software update for this devices...
Hope that helps.......
  • Mark Gil
    Mark Gil Oct 01, 2008
    What do you mean no success you cannot contact them or they don't have any solution for this problem? if they don't have any solution just ask them if they have any updated firmware for your device ...
    Genius:
  • 1,124 Answers
This is a problem with the firmware of your camera or bad device. Try to update the firmware first.
Getting incompatible disc error everio cu-vd10
What speed disc are you using?
Use only $x, 8X or 16X -R or -RW
Oct 02, 2009 | JVC Everio Share Station DVD Burner Burner
Keep getting incompatible disc error
what if you try other dvd-r brands. just a suggestion.
Sep 23, 2007 | JVC Everio Share Station DVD Burner Burner
Cant find the correct disk to use says not compatible model #cu-vd10u s# 151y6000
Shortwater....
Try using DVD-R 4X or 8X or 16X ....seems any brand works. It did for me.
Sep 11, 2009 | JVC Everio Share Station DVD Burner Burner
Everio dvd burner will not accept discs
try using a disc cleaner on the unit and then try it
Jul 31, 2009 | JVC Everio Share Station DVD Burner Burner
Incompatible disc???
This device either needs a firmware upgrade or is actually faulty. It cannot be anything else.. Is it in warranty with JVC?
Jul 24, 2009 | JVC Everio Share Station DVD Burner Burner
D.V.D. Burner CU-VD10U
I have replace two share stations.Each time I try to burn dvds from my camercorder it doesnt copy.I have messed up several dvd.Cna you please tell me what the problem is.
Oct 24, 2008 | JVC Everio Share Station DVD Burner Burner
DVD Burner
Reinstall the driver for the burner and camera software.
Aug 26, 2008 | JVC Everio Share Station DVD Burner Burner
Error message - incompatible disc
I BUT A JVC EVERIO BURNER AND I CANT BURN MY VIDEOS FILES I insert the Disc in the Burner, it tries to recognize the disc and then comes up with , DISC ERROR CHANGE DISK
Jan 29, 2008 | JVC CU-VD10
JVC Everio G Camcorder Logo
967 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
