Question about Samsung Washing Machines
My samung washing machine will not stop moving no matter what i do its damage the side and ive only had it 2 days
  • 943 Answers
Hi.. thanks for the question did you remove the shipping bolts. if they are not removed it will shake all over. look at the manual on how to do this. or call a tech from store you bought it from .should have been installed for free thanks the appliance doc
Posted on Oct 01, 2008
I am facing a new problem le is the code i get and its getting stop in middle of washing cloths
If top loader (you put washing in from top) try to fix by open the lid and move the clothes around.
You may find that the machine is off balance because more clothes are to one side , this will tend to make the machine stop to avoid damage.
Regards Craig
Feb 10, 2018 | Washing Machines
I just moved into a new place and hooked up my Roper 111-07 washing machine. I have notice that no matter what temperature I select for the rinse cycle, hot water is the only thing that comes out. I only...
Hello Stephanie Wells,
Since it is the "new place" that changed...
I would FIRST look to the COLD WATER supply
to make sure cold water INDEED comes out of the
MACHINE END of the hose.
Then move on to the cold water valve...
>> Take PICTURES before disassembly.
Not terribly expensive... Pretty easy to change.
(you may get your NEW PART as differently
connected than your old (PRESS FIT couplings
are replacing the OLD threaded type...
ALERT: PRESS collar in to release tubing)
HELPFUL VIDEOS:
Check these (USA) parts suppliers to
find your specific water valve
(even available through AMAZON)...
Let price/reputation be your guide...
ALL these folks peddle the same parts (opinion)
appliancepartspros
Search Over 2 1 Million Appliance Parts
AMAZON: Roper
285805 Roper Washer Washing Machine Inlet Water Valve Replacement
partselect
PartSelect Appliance Parts and Repair Help
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Good luck
Carnac the Magnificent
May 08, 2017 | Roper Washing Machines
When moving a front load washer down steps, should it not be tilted on its side?
Hello, Welcome to FixYa. If you have the transport bolts/pins in place, it won't matter as their function is to stabalize the unit and prevent damage during moving. If the bolts/pins are NOT present, the unit should be held perfectly straight up and down ( top UP ) to prevent any internal componets from bashing around and moved very carefully & gently. Hope that naswers you question or quells your concern. Thank you for choosing FixYa and good luck with your move. Please take a moment to rate the info provided and write a testimony if you feel it's warranted. Regards, Macmarkus :)
Feb 15, 2011 | AEG L74850M Washing Machine Front Load...
I have moved into a building with a brand new washing machine and every time I run the washer it moves around and it is starting to damage the machine and my walls. what can I do to stop this?
Hi from retired Englishman in France,
It is imperative that washing machines are absolutely 'level', especially most noticeable when carrying out the spin cycle.
You need, in a hurry, to have the 4 (probable) feet underneath adjusted so that all of them are FIRMLY on the floor. New machines in the UK and France come with an adjustment spanner- I will presume yours has.
The ones at the rear can be left alone provided they are 'locked' with a locking nut and will not rotate. Probably just one of the two at the front needs to be tightened down firmly to stop the machine being capably of being rocked by firm pushes. If it rocks from the right-hand side then it is the right-hand side which should be adjusted.Conversly the left-hand side.
Having this done will save potential damage to the washing machine dampers/shock absorbers which are part of the internal suspension of the drum.
Good luck,
John C
Jan 25, 2011 | LG Washing Machines
Asko 10505 runs through was cycle in approx. 30 seconds, then wont drain. Simply stops. It doesnt matter which cycle I start with, the dial moves quickly to stop. It fill with water and spins. ANY HELP...
hi sir' start the wash machine empty and see if it happens when nothing is in it.
2. When machine is off, open the top grab the centerpiece inside the wash machine and pull and push it slowly, does it move? (For safety unplug the machine)
3. Make sure machine is 100% level (front to back, left to right)
The most common thing is bad drum bearing, which force the wash machine out of whack when in spin / wash. Which are common and the best thing is to call Maytag.
thank u .........................................please rate
__________________
Sep 11, 2008 | Asko Washing Machines
Stop light flashing
i have a candy activa cm1 146. no matter what i do the stop light is always flashing. Ive emptied the machine, turned it off at the mains, checked the waste pipe and currently trying to empty the filter, whilst the light is flashing it will not work on any programs???
Dec 16, 2007 | Candy CN146 Front Load Washer
Shakes violently
The bearings of you machine are damaged or bad..You have to get em' replace..until then lowering the water pressure will solve this problem to some extent..
Oct 24, 2007 | Hotpoint First Edition FEW12 Front Load...
Zanussi washing machine.
i am a recently retired engineer of 20 years, and i have found that generally the numbers and letters are the same throughout, so the number 2 on one machine is the same as the number 2 on another make, so this rule applies for letters also, just remember what you used on your old machine and you cant go far wrong hope this helps
Sep 19, 2007 | Washing Machines
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
