Question about Comet BXD2527 Pressure Washer Pump
Gas presure washer pump has no high pressure
  1. Sears model 580.768030 cleaning system has no high pressure when engine is running. Need to trouble shoot the pump.....any sugestions?
2 Suggested Answers
  • 40 Answers
SOURCE: no high power water pressure coming out
You should dismantle and clean the manifold from the pump , it is sticking. Common
Posted on Jul 03, 2009
Adjusting high and low water pressure
Clyde, Trouble shooting pressure washer links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Pressure Washer FAQ Low or No Flow Briggs Stratton
DIY Pressure Washer Repair Help Troubleshooting Sears PartsDirect
Troubleshooting Your Pressure Washer
Common Pressure Washer Repair Problems Pressure Cleaned
Jun 27, 2016 | Craftsman 2500 PSI Briggs & Stratton...
The presure washer head will not turn or will stop turner when engaged
The head probably needs some cleaning. I use a spray bottle of general cleaner. Then I'll shoot some wd40 in the head.
Jun 09, 2014 | Homelite Pressure Washer. 2600 psi 2.3 GPM...
Had presure tostart cleaning @ then press. stopped just seem to have water press. thank you
if the motor is still running fine when this happened it is either a failure in the linkage between the gas motor and the pump. or the pump itself. if it looks like the motor does nothing whatsoever. it may be the link between the two. if the motor does a little bit, then the problem may be with the pump. Try turning off the engine while spraying and see if the pressure drops at all
Aug 08, 2011 | Honda Karcher G2400HH-R Pressure Washer
Wont reach high presure
The water admittance valve is stuck. Remove the valve spool from the bore and clean the bore with crocus cloth on a dowel rod. Replace the Orings and lube with a bit of plumber's grease and re-assemble. The Orings get dried out and deposits build on the walls of the bore. The valve is usually at right angles to the engine shaft on the back of the pump where the hose connects.
Jul 13, 2011 | Karcher 4000 PSI 36 GPM Gas Pressure...
Sears 2600 psi power washer
there should be a low presure tip for dispensing wash cleaner or if you have an adjustable wand turn it to low presure setting also make sure the suction tube is open some have a adjustable filter...good luck
Jul 25, 2010 | Briggs & Stratton 2200 PSI Gas Pressure...
I have a Blue Max high presure washer, 2200 psi.
Hi Greg. Walk into your nearest Lawn Mower parts supply with your engine model number (usually on the recoil) and they will have the replacement part or repair your old one. It is less expesive to have the old one repaired unless the support struts have broken. 2200 PSI should have a Honda GX160.
engine:
Here is another source....
http://www.northerntool.com/shop/tools/product_200327175_200327175
They can range from $32.00 to $68.00 depending on source.
Honda PN is: 28400-ZH8-013ZA (do net search this number) Or call your local Lawn Mower repair Supply with the number.
If you have a Briggs & Stratton engine I will need the ENGINE model number off of the air shroud just above the spark plug.
Thanks for using FixYa.
Kelly
Apr 05, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Hello, I have a couple year old brigs and strattion upright pressure washer. It has always ran great untill recently. It will run for a acouple minutes before dying, like it is starving for fuel. i give it...
Check the oil level in the engine itself. Verify that your oil reservoir is full, then try again.
You may also want to refer to the owners manual for other trouble shooting tips. Click this link to go to your manual.
http://www.pressurewashersdirect.com/manuals/020244%20manual_2.pdf
And remember
Automatic Cool Down System
(Thermal Relief)
If you run the engine on your pressure washer for
3-5 minutes without pressing the trigger on the spray gun,
circulating water in the pump can reach temperatures
above 125°F.The system engages to cool the pump by
discharging the warm water onto the ground
Mar 24, 2010 | Briggs & Stratton Gas Pressure Washer...
Electric or Gas?
Pressure washers are either electric or gasoline powered. Electric pressure washers are low maintenance and quiet. These generally are for light duty. They are handy where you need to work on small confined area, however you need to run power to them and have a pressurized water source. Also the National Electrical Code and Underwriters Laboratories now require ground fault circuit interrupters (GFCIs) be use when operating an electric pressure washer. Gas models are recommended for tasks that require more power, such as paint prep, heavy vehicle cleaning, or cleaning heavily soiled concrete.. Gas models start with PSI of 1750 and go as high as 4000. They also offer more portability, as they are not limited by electric cords. Also some gas models can draw water from a source other than the garden hose, which allows you to work away from a water line. All gas models have 4-cycle engines and run on regular unleaded gas.
Aug 27, 2008 | Briggs & Stratton Power Products 1539...
Comet BXD2527 Pressure Washer Pump Logo
811 people viewed this question
Top Comet Garden Experts
michael
michael
Joseph Hoffmann
John Trevino
Are you a Comet Garden Expert? Answer questions, earn points and help others
