Question about Toshiba e-Studio 232 Black and White Copier
TOSHIBA E STUDIO 351 C
Hi ,
I have moved my printer to new office and some how giving message close side door and i have check all the doors and closed please help
  • adwani98 Oct 01, 2008
    Thanks that was more then help 3rd door was out .
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Toshiba Master
  • 1,362 Answers
Check the bottom door on the right, I beleive there are three doors on the right, if not there is a door sensor loose.
Posted on Oct 01, 2008
  • CheckitRight
    CheckitRight Oct 01, 2008
    glad to be of service, please rate. TNX
Toshiba e-studio 28 copier
Check that all the door are well closed and in place.
Jul 15, 2008 | Toshiba e-Studio65 Copier
Close Front Cover For Toshiba E-studio 350
There are many possibles that can cause "Close Front Cover"
Check the front cover actuator, switch. If all covers, switches is working fine, probably power supply is faulty.
Dec 02, 2015 | Toshiba e-Studio 350 Copier
Door open symbol
Check for open front and side panel doors. If all are closed and sensors are good then lastly check the POWER SUPPLY BOARD..
Sep 28, 2014 | Toshiba E-Studio 166 Copier, Print, Scan...
Print head jam
Check the LCD on your printer control panel or the status monitor on your computer for an error message. If there is an error message, follow the instructions to clear it.
If there is no error message, or if the problem continues:
  1. Open the access door.
  2. Disconnect the power adapter from the back of the printer.
  3. CAUTION: Do not use force on the printhead carriage to move it. Gently move the printhead carriage from side to side to see that it moves freely and there are no obstructions.
  4. Remove any obstructions that may prevent the printhead carriage and ink cartridges from moving to the center position.
  5. Close the access door.
  6. Connect the power adapter to the printer.
  7. Remove the ink cartridges from the printhead.
  8. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
  9. firmly until you hear it click into position.
  10. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
  11. Close the printer access door.
  12. Press OK to clear the error.
  13. Make a print.
May 06, 2014 | Kodak Office Hero 6.1
How can i check the copy counter of toshiba e studio 181 copier machine
Date:06/04/2013Sir
My digital copier toshiba 181 showing page counting 179113 but when doing copy the previous reading is not increasing , it is stopped in 179113. could you give me suggestion to(Programe) reactivate the page counting.
Thanks
Golam Rabbani
Chittagong, Bangladesh
Apr 19, 2012 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
My machine toshiba e studio 167 showining error code 1 side cover open .but i checked their is not open any cover even frout & side cover .so plz give me a solution as soon.
hai friend it is a small problem ,. the problem is Sensor is not working. U have to do one thing
open right cover., and clean the roller dust., and rearrange all the doors in the printer,. then close tightly the main door., and put a support for not opening ., try it it will work.,
May 10, 2011 | Toshiba E-Studio167 Copier
Toshiba e studio 232 screen shows
is the finisher tray atach and connector plug in? it's possible that the connector was unplugged while the machine was on and an memory error apeared! if so, unplug the copier from power source, plug in the finisher, and plug in the power corde . if it won't work you shall check also if all doors of finisher are closed and if wasn't broken one of the sensors!
Nov 03, 2008 | Toshiba e-Studio 232 Black and White...
Toshiba e 350 "close finisher door"
Finisher door is the sorter. there is a switch or door in the sorter not closed (or triggered)
Aug 12, 2008 | Toshiba e-Studio 350 Copier
Toshiba e-Studio 232 Black and White Copier Logo
166 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
